Faxing using the fxs port UC500
roydennemans
Hello
I would like to use one FXS port for faxing. Fax starts to dial out but gives a communication error after some time.
Inbound to the fax routes to the voicemail.
Kind regards,
10 Replies 10
paolo bevilacqua
try:
network-clock-participate wic 1
network-clock-select 1 BRi 1/1/0
Is it not possible to have fax call routed automatically inbound to FXS, you have to dedicate an external number for that.
Hello, the network-clock settings work for outbound faxing.
How do I set a direct external number from BRI number block to the FXS port?
I remember you have the ports in so called "sccp mode". So configure as it if was an extension.
I can not get it stable. I will try to use an ATA instead.
Thanks for your help
Hello again,
TAC told me it's possible to use the FXS without ATA, I would need to use:
network-clock-participate wic 3
network-clock-select 1 BRI0/1/0
voice service pots
text relay fax rate disable
fax rate disable
Change FXS to
type ata instead of anl
However, I get the following error (busy tone)
on incoming:
Feb 29 15:35:35.139: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to up
Feb 29 15:35:35.223: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x2E
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '2*********'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '2*********'
Feb 29 15:35:35.235: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xAE
Channel ID i = 0x89
Exclusive, B1
Feb 29 15:35:35.251: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xAE
Cause i = 0x8091 - User busy
Feb 29 15:35:35.347: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x2E
Feb 29 15:35:35.351: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA
E
Feb 29 15:35:45.383: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Feb 29 15:36:02.607: ISDN BR0/1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Feb 29 15:36:02.659: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to down
Outgoing works fine!
That depends by the how numbers are set, for some reason the cme cannot associate the called number to your FXS extension.
Can you repeat what the problem is? I had some issues with faxing with an uc500 and solved them...maybe i can help you.
Met.
I can not "call" the FXS ports. I have connected (for troubleshooting) a regular analog phone which (same as the fax) can call out, but it does this with a anonymous number.
If I call the extension from another Cisco IP Phone I receive voicemail or when this is not configured busy tone. I can call other Cisco IP phone extensions, but it does this (again) with a anonymous number
Almost default config from Cisco still does not work, (below)
ephone-dn 5
number 301 no-reg primary
label 301
description PhoneA Analog
name PhoneA Analog
call-forward busy 333
call-forward noan 333 timeout 10
ephone-dn 6 dual-line
number 302 no-reg primary
label 302
description PhoneB Analog
name PhoneB Analog
ephone-dn 7 dual-line
number 303 no-reg primary
label 303
description PhoneC Analog
name PhoneC Analog
ephone-dn 8 dual-line
number 304 no-reg primary
label 304
description PhoneD Analog
name PhoneD Analog
ephone 1
device-security-mode none
video
mac-address ****.8EB0.0000
username "PhoneA"
type anl
button 1:5
ephone 2
video
mac-address ****.8EB0.0001
username "PhoneB"
type anl
button 1:6
ephone 3
video
mac-address ****.8EB0.0002
username "PhoneC"
type anl
button 1:7
ephone 4
video
mac-address ****.8EB0.0003
username "PhoneD"
type anl
button 1:8
Hi there roy,
I am having this similar problem on two locations with an UC520. I can configure the dial-peer so that there can be send faxes out but then nothing gets in. When i make the configuration for the incoming then nothing can be send out. I also have the problem that i cannot call the analogue extensions.
