FL-CUBEE-25
Dmitry.Pyrkov
Hello all!
Need a help:)
We have bought Cisco 3925-V/K9.
On board we have Cisco uck9 license + FL-CUBEE-25.
Our client wants to check it. With license no broblem: show version or show lic.
But how to show him, than FL-CUBEE-25 is installed. We have only RTU paper.
As I understand we can use it. But how to show him it? Maybe we must to activate this RTU on Cisco device or something alse?
Thanks!
Manish Gogna
Hi Dmitry,
This is a pay-as-you-grow license as mentioned in the CUBE ordering guide
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-border-element/order_guide_c07_462222.html
Its not a platform license.
As long as the license shows RightToUse in the output on CUBE it is okay, you can check the similar explanation for RTU license for CME in the following doc.
Manish
- Do rate helpful posts -
Thank you for so quick answer!
When I type show lic rtu, the output from device- no RTU availible. How is it possible to activate this license? We must configure voice and then it will appear?
Or there is no license at all and all must work? And this FL-CUBEE-25 RTU only a paper confirming that we've payed for this license and can legaly using it? It is very intersting, because when we will by another license for 50 sessions we will get again this paper without any PAK etc.
Sorry for so stupid questions.
(+5 manish) Yes Dmitry, its a right to use license. You are not going to see anything on your router that says you have 25 licenses. So yes there is no license installed, and it will work.
Please rate all useful posts
