Flash 7960G using PoE from 3750
Azlord_Cisco
Beginner
Beginner
I would like to configure a couple of 7960G's using a 3750 switch but currently stuck on upgrade screen.
I have performed a hard reset of both phones and connected both to a 3750 switch with vanilla settings. The switch is the only source of power. I have connected the switch to a pc running TFTP server hosting the 7960 SIP files in the .zip downloaded from Cisco and a generic CNF file I found on the net.
I am stuck on the upgrade screen. My questions are:
1. Do I need to use an external power pack to flash the phone or does PoE suffice?
2. Can the phone can get files via the switch/pc set up?
3. Am I missing something?
Leo Laohoo
Hall of Fame Community Legend Hall of Fame Community Legend
PoE will suffice.
Yes.
DHCP Option 150
Leo Laohoo
PoE will suffice.
Yes.
DHCP Option 150
Recognize Your Peers
