Forward Call to Other Extension Number
abdulhakam
Anyone can help me ? I still new with the CUCM, can anyone guide me how to set forward call to other extension number only you the last 4 digit number. Example : 047366015 instead we put full number I want to only put 6015 & forward.
Is that possible ?
Thank You.
Absolutely possible. You’d need to create translation pattern(s) in a partition that the directory number(s) has access to in its call forward CSS that translates from the 4 digit format to the actual number.
Response Signature
Response Signature
Hi, Thank You for the reply so this can be done in CUCM ? I check under Call Routing -> Translation Patter. Is that correct ?
Yes that would be the correct place to look.
Response Signature
Thank for the reply, just tested and it works. Thank You
