Forwarding Calls with Caller ID
atlanta79
I forward calls from my office phone (Cisco IP Phone 7962) to my cell phone.
Forwarded calls do not appear on my cell phone with the original caller's Caller ID. It only shows my office phone number.
Is there a way to forward calls with Caller ID?
Thank you.
aateek singh
Similar post go here
https://communities.cisco.com/thread/38299
you can also check
Calling Party Selection, leave it to Originator and t
The Solution for MGCP is to use:
Redirecting Party Transformation CSS
This setting allows you to transform the redirecting party number on the device to another format such as DID or E164 format. Cisco Unified Communications Manager includes the transformed number in the Redirecting Number Information Element of H.323 setup message sent out of Cisco Unified Communications Manager. Make sure that the Redirecting Party Transformation CSS that you choose contains either the calling or called party transformation pattern that you want to assign to this H.323 gateway.
Note
If you configure the Redirecting Party Transformation CSS as None and also uncheck the Use Device Pool Redirecting Party CSS check box, the transformation does not match and does not get applied. Ensure that you configure the Redirecting Party Transformation CSS in a non-null partition that is not used for routing.
  1. Create a new CSS , example RedirectingCSS
  2. Create a new Partitiion, example RedirectingPT
  3. Create multiple calling party transformation patterns:
4. Simply create a matching pattern for your DNs (example XXX) and check the Use Calling Party's External Phone Number Mask.
5.On the PRI, go to PRI Protocol Type Specific Information and  uncheck the Use Device Pool Redirecting Party Transformation CSS and also select the new  Redirecting Party Transformation CSS
6.Save, Reset and Test.
On H323 or SIP, you could use translation rules.
Aateek Singh
Network Engineer
Spooster IT Services
