Dear All,I can't add supervisor as Primary Supervisor in the Team Configuration menu.What is wrong in my configuration? Thanks in advanceBahlul
Hi,I want to use a cisco "881 voice" with my CUCM v9.1.This router, have a mgcp configuration and it's "ok", but i can't configure the BRI and the FXS with the CUCM.It's possible to use the 881 with mgcp and configure fxs and bri?Thanks.
Hello,I have a question about this pattern in my dial-peer:dial-peer voice 1 pots destination-pattern 01[2-8] port 0/0/0 forward-digits 2dial-peer voice 43 pots destination-pattern 0[123459]........ port 0/0/0 forward-digits 10 When I call 01XXXXXX18...
Dear Sir; we have old series MCS-7825-H2-ECS1 which i want to utilize as cucm subscriber . we are currently using cucm 9.1. recently i have upgraded RAM to 4 GB and then tried to install ESXi 5.0 but it is not showing raid volume , showing two disks...
I forward calls from my office phone (Cisco IP Phone 7962) to my cell phone. Forwarded calls do not appear on my cell phone with the original caller's Caller ID. It only shows my office phone number.Is there a way to forward calls with Caller ID?Than...
Dear All,I have CISCO2921-CME-SRST/K9 bundle, with ISM-SRE-300 Unity module.CCME 8.6, CUE 8.6 versions.I'm facing a problem that outside caller make the call to our network, Auto Attendant receive the call & transfer as per required extension.Our ins...
Hi,Can anybody guide me on converting the SCCP to H323 in Cisco ATA 186 Analog Telephone Adaptor?Regards,
HAI WE ARE ORDERING FOR CME ON ISR G2 PART NOCISCO C2901-CME-SRST/K9 COMING WITH BUNDLE 25 CME-SRST LICENSE.IS IT MEANS WE CAN RUN ANY 25 PHONES /USERS WITH OUT ADDING ANY PHONE LICENCE LIKE SW-CCME-UL-8942= OR SW-CCME-UL-6921 .WE DONT WANT SRS...
Hi all,When configuring the lines on an IP phone you can specify the "Ring Setting (Phone Idle)" and "Ring Setting (Phone Active)" parameters. One of the options you can choose is "System Default". My question is where do you set the "System Defau...
hi all,i received a 7916 expansion module but it didn't come with the power adapter.i heard (or maybe read) somewhere that you can use the power adapter of Cisco APs.i tried to google but giving me cisco vendor site.anyone can confirm the alternate m...
We have 2 buildings with Cisco VoIP and 1 building with Avaya Digital, however, all 3 voicemail accounts are on the Cisco Unity. Whenever our Avaya Server resets, the MWI lights do not come on when a user has a voicemail. In the past, I have gone t...
Hi all,In my scenario, I have several remote locations, each with their own T1-PRI connection to the PSTN via Cisco voice gateways.The call flow has the caller calling a PSTN number at the remote location. This call hits a CUCM translation pattern a...
Has anyone successfully setup a SIP trunk between CUCM and a Panasonic PBX? Guides on the Panasonic side seem to be differing and limited.
Hello everyone. I am facing an issue right now. The last weekend we upgrade our customer cucm cluster. The cluster has 7 servers but finally we were able to upgrade 5 of the 7. 2 of them failed. I remove the servers from the publisher and turn them o...
I have a 2801 router with cme and a four ports FXO card, I have a 800 toll free with three lines, any idea on how to configure this type of service?Is just one telephone number asocciate with 3 physical lines on three port int he cisco fxo card.
Subject | Author | Posted |
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM | ||
05-16-2025 12:03 AM |
User | Count |
6 | |
4 | |
2 | |
2 | |
1 |
