FXO card will not forward calls to IP Phones
mrutledge
I have an FXO card that will not forward calls. The outside phone line has been tested and is working and the FXO card has been changed. Once the call hits the port on the FXO card the calling party hears a ringtone, but no IP phones at the location ring.
This port is set with connection plar opx. If you change to connection plar (no opx) the calling party hears one ring, and then a busy signal when the FXO card picks up the call.
The voice-port in question is 0/2/2.
voice-port 0/2/0
echo-cancel coverage 24
timing hookflash-out 500
connection plar 3320
voice-port 0/2/1
connection plar 3300
description 931-962-8816
voice-port 0/2/2
connection plar opx 8540
description 931-967-8943
voice-port 0/2/3
signal groundStart
description 931-692-8817
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.1.180.131 10.5.190.131
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.1.180.131
ccm-manager config
mgcp
mgcp call-agent 10.1.180.132 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
dial-peer voice 10 pots
preference 1
service default
destination-pattern 9.T
port 0/2/0
dial-peer voice 20 pots
preference 2
service default
port 0/2/1
dial-peer voice 30 pots
preference 3
service default
port 0/2/2
dial-peer voice 11 pots
preference 1
service default
destination-pattern 911
port 0/2/0
forward-digits 3
dial-peer voice 21 pots
preference 2
service default
port 0/2/1
forward-digits 3
dial-peer voice 31 pots
preference 3
service default
port 0/2/2
forward-digits 3
dial-peer voice 12 pots
preference 1
service default
destination-pattern 9911
port 0/2/1
forward-digits 3
dial-peer voice 22 pots
preference 2
service default
port 0/2/1
forward-digits 3
dial-peer voice 32 pots
preference 3
service default
port 0/2/2
forward-digits 3
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999022 pots
service mgcpapp
port 0/2/2
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
timeouts interdigit 4
ip source-address 10.5.189.1 port 2000
max-ephones 42
max-dn 144
time-zone 8
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
signal groundStart
ccm-manager mgcp
ccm-manager config
mgcp
mgcp sdp simple
preference 1
service default
port 0/2/0
preference 2
service default
port 0/2/1
preference 3
service default
port 0/2/2
preference 1
service default
port 0/2/0
forward-digits 3
preference 2
service default
port 0/2/1
forward-digits 3
preference 3
service default
port 0/2/2
forward-digits 3
preference 1
service default
port 0/2/1
forward-digits 3
preference 2
service default
port 0/2/1
forward-digits 3
preference 3
service default
port 0/2/2
forward-digits 3
service mgcpapp
port 0/2/0
service mgcpapp
port 0/2/1
service mgcpapp
port 0/2/2
service mgcpapp
port 0/2/3
max-ephones 42
max-dn 144
time-zone 8
9 Replies 9
Tommer Catlin
You are using MGCP, so how is CUCM configured for this line? Is CUCM configured to control the FXO ports?
FXO is setup in CUCM as a gateway and the ports are conifgured as endpoints in call manager (Version 7.1 - which is a recent ugrade).Call Mangaer is configured to ring two lines at a remote location by calling ext. 84540
Next question, can you do a debug voip ccapi inout and then do a term mon in your telnet screen.
Make the call again and if you see data, the call is getting from CUCM to the gateway.
If you get data, then debug dial-peers events. If the incoming number from CUCM is not matching a dial peer, then you know your issue.
Also check to see if your FXO are in fact registered
Okay. Debug is showing data when making the call and and the number does match a dial peer.
But, the port in question is not registered in CUCM. Port 0/2/3 is showing as registred and does work correctly.
How do I register this port?
I could be getting my versions mixed up, but it may show unregistered, which is fine. Can you clarify the call flow? Im thinking that you cant use the FXO and should use a FXS port. To me, if you are using PLAR with FXS port, you are making an IP phone call a number which sends the router. Router picks up the , picks the dial peer, hits the FXS port, takes the analog phone off hook. There should no ring, or one ring. I have used these in the past for door openers, or analog speaker device.
To the best of my knowledge the call flow goes like this or should: You call an outside number and it comes into the fxo card through port 2 via direct pots line and then transferred to internal call manager extension 8540. This extension has two IP Phone devices associated - and both phones should ring.
The most irritating thing is port 0/2/3 works exactly the way I want port 0/2/2 to work. They look to be setup the same in callmanager and I have had the voice ports set the same but that didn't solve the issue either.
If Im reading this correctly, you have a shared line on this number correct?  Im wondering if the shared line is affecting the PLAR at the other end.
Hi Mike,
I have run into your situation once before. The way I got the port register was basicallly to wipe out everything and rebuild.
Try deleting the gateway --> delete MGCP config --> delete mgcpapp dial-peers -->rebuild
Kind of a hassle but it worked for me.
Don
I have been thinking this is what I need to do as well. I'll work on it next week and let you know how it went. Thanks guys.
