FXO Gateway
We have to connect 28 POTS lines to Cisco System. Does 43XX series router support 28 port  FXO card ? Is there any separate router for 28 FXO ports or we have to buy 2 Voice gateway to full fill the requirements.
Jitender Bhandari
Hi Madhav,
43XX will support FXO, check the link below for details.
http://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
JB
Another helpful link to answer your question.
http://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
JB
It seem that it can support only 12 FXO port on one router. So to full fill 28 ports requirements  we need to buy 3 X 43XX router ?
Does Cisco has separate FXO gateway which can support more than 20+ FXO ports ?
Check the below link for detail
http://www.cisco.com/c/en/us/products/collateral/unified-communications/tdm-gateways/data-sheet-c78-729824.html
Tables 8 through 10 give information about connectivity and CPU performance on the unified communications routers.
Table 8.       Maximum Physical DS-0 Connectivity on the Cisco Unified Communications Routers*
Cisco router
2901
2911
2921
2951
3925
3945
3925E
3945E
4321
4331
4351
4431
4451
FXS
16
40
40
64
64
112
60
108
8
8
20**
12
20**
FXO and CAMA
16
28
28
40
40
64
36
60
8
8
20**
12
20**
E&M
8
12
12
16
16
24
14
22
Analog DID
16
32
32
48
48
80
44
76
8
8
20**
12
20**
BRI ports
8
16
16
24
24
40
22
38
T1/E1 ports
8
20
20
24
24
32
20
28
8
16
40**
24
40**
T1 channels
192
480
480
576
576
768
480
672
192
368
920**
576
960**
E1 channels
240
600
600
720
720
960
600
840
240
480
1200**
720
1200**
* This table contains physical connectivity numbers. You should also use CPU performance as a guide to determine how many voice calls can actually be supported on each platform.
JB
