03-08-2018 02:14 AM - edited 03-17-2019 12:22 PM
I have a problem : after shutdown and no shutdown command the FXO hung, please do you have any solution ?
Foreign Exchange Office 0/2/0 Slot is 0, Sub-unit is 2, Port is 0
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
voice-port 0/2/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone AR-custom
no battery-reversal
timeouts ringing 15
timeouts wait-release 1
timing hookflash-out 50
timing guard-out 1000
caller-id enable
Solved! Go to Solution.
03-11-2018 09:11 PM
Dear Nipun ,
Thanks for your support, actually the issue has been resolved by (Reload).
Regards.
03-08-2018 04:59 AM
03-08-2018 05:05 AM
APC01FFRV01#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/1/0 -- fxo-ls up dorm idle on-hook y
0/1/1 -- fxo-ls up dorm idle on-hook y
0/1/2 -- fxo-ls up dorm idle on-hook y
0/1/3 -- fxo-ls up dorm idle on-hook y
0/2/0 -- fxo-ls up dorm idle on-hook y
0/2/1 -- fxo-ls up dorm idle on-hook y
0/2/2 -- fxo-ls up dorm idle on-hook y
0/2/3 -- fxo-ls up dorm idle on-hook y
50/0/2 1 efxs up dorm on-hook idle y
50/0/2 2 efxs up dorm on-hook idle y
50/0/3 1 efxs up dorm on-hook idle y
50/0/3 2 efxs up dorm on-hook idle y
50/0/4 1 efxs up dorm on-hook idle y
50/0/4 2 efxs up dorm on-hook idle y
50/0/5 1 efxs up dorm on-hook idle y
50/0/5 2 efxs up dorm on-hook idle y
50/0/6 1 efxs up dorm on-hook idle y
50/0/6 2 efxs up dorm on-hook idle y
50/0/31 1 efxs up dorm on-hook idle y
50/0/31 2 efxs up dorm on-hook idle y
PWR FAILOVER PORT PSTN FAILOVER PORT
APC01FFRV01#
APC01FFRV01#sh voice call summary
PORT CODEC VAD VTSP STATE VPM STATE
0/1/0 - - - FXOLS_ONHOOK
0/1/1 - - - FXOLS_ONHOOK
0/1/2 - - - FXOLS_ONHOOK
0/1/3 - - - FXOLS_ONHOOK
0/2/0 g711ulaw n S_WAIT_RELEASE FXOLS_ONHOOK
0/2/1 - - - FXOLS_ONHOOK
0/2/2 - - - FXOLS_ONHOOK
0/2/3 - - - FXOLS_ONHOOK
50/0/2 .1 - - - EFXS_ONHOOK
50/0/2 .2 - - - EFXS_ONHOOK
50/0/3 .1 - - - EFXS_ONHOOK
50/0/3 .2 - - - EFXS_ONHOOK
50/0/4 .1 - - - EFXS_ONHOOK
50/0/4 .2 - - - EFXS_ONHOOK
50/0/5 .1 - - - EFXS_ONHOOK
50/0/5 .2 - - - EFXS_ONHOOK
50/0/6 .1 - - - EFXS_ONHOOK
50/0/6 .2 - - - EFXS_ONHOOK
50/0/31 .1 - - - EFXS_ONHOOK
50/0/31 .2 - - - EFXS_ONHOOK
APC01FFRV01#
03-08-2018 05:22 AM
03-10-2018 10:49 PM - edited 03-11-2018 01:21 AM
Thanks Dear,,,
I already did "shut/no shut" many times, but i note that there are 2 active calls stuck on the port 0/2/0
APC01FFRV01#sh call active voice compact
<callID> A/O FAX T<sec> Codec type Peer Address IP R<ip>:<udp>
Total call-legs: 2
2158191 ANS T255782 g711ulaw TELE P580143471
2158238 ANS T255474 g711ulaw TELE P
APC01FFRV01#sh call active voice brief
Telephony call-legs: 2
SIP call-legs: 0
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 2
3CE1 : 2158191 1165192134ms.1 (*07:44:04.487 UTC Thu Mar 8 2018) +0 pid:14 Answer 580143471 active
dur 3d01h tx:463/77784 rx:40/6400 dscp:0 media:0 audio tos:0x0 video tos:0x0
Tele 0/2/0 (2158191) [0/2/0] tx:830/830/0ms g711ulaw noise:0 acom:3 i/0:-74/-69 dBm
3D1E : 2158238 1165500614ms.1 (*07:49:12.967 UTC Thu Mar 8 2018) +10 pid:14 Answer active
dur 3d01h tx:1656/277731 rx:139/22240 dscp:0 media:0 audio tos:0x0 video tos:0x0
Tele 0/2/0 (2158238) [0/2/0] tx:2820/2820/0ms g711ulaw noise:0 acom:3 i/0:0/-69 dBm
03-11-2018 05:50 AM
03-11-2018 09:11 PM
Dear Nipun ,
Regards.
