FXO hangs When call is disconnected before IVR using AA on AIM-CUE Ends
alanhong
     Hi All,
                I have a CCME and AIM-CUE ,
Call flow is  PSTN----> CCME FXO-----> IVR(AA on AIM-CUE)----- --->Extention or Operator
Call complete normal if the pattern above is followed.but if a caller calls in and Disconnect the call during IVR withusing any option or completing IVR ,FXO lines hangs until voice-port is shut and no shut is done ,any advise ?
thanks
5 Replies 5
acampbell
You are encountering a common issue with FXO disconnect.
Please see the following link.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
You should be able to apply the fixes from here.
Alex
Regards, Alex. Please rate useful posts.
Yes but there is no issue on normal call forwarded to Ip phone , only when call is forwarded to AA and user cuts before listening to IVR or press some options key this happens
Can we see the config of the FXO voice ports
Alex
Thanks again fro taking time on this
voice class dualtone-detect-params 1
freq-max-deviation 25
freq-max-power 0
freq-min-power 13
freq-power-twist 4
cadence-variation 4
voice class custom-cptone UAE-CUSTOM-FETEX
dualtone disconnect
  frequency 425
  cadence 375 375
voice class custom-cptone UAE-CUSTOM-ERICSSON
dualtone disconnect
  frequency 425
  cadence 325 325
voice class custom-cptone UAE-CUSTOM-SIEMENS
dualtone disconnect
  frequency 425
  cadence 425 325 250 500
voice class custom-cptone UAE-CUSTOM-ALCATEL
dualtone disconnect
  frequency 425
  cadence 375 375
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone UAE-CUSTOM-ALCATEL
supervisory dualtone-detect-params 1
input gain 14
timeouts call-disconnect 5
timeouts wait-release 5
timing hookflash-out 50
connection plar opx 5055
caller-id enable
dial-peer voice 5055 voip
destination-pattern 5055
session protocol sipv2
session target ipv4:172.25.0.5 (ip of CUE AA)
dtmf-relay h245-alphanumeric sip-notify
codec g711ulaw
no vad
Thanks for posting the config.
This looks good to me.
The issue is that although the caller via the FXO has cleared the FXO has not seen a disconnect signal either via a tone or a voltage change.
After looking through this document
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t2/feature/guide/ft_ansds.html#wp171953
I think you should try adding this line of config to your voice port
voice-port 0/0/0
supervisory answer dualtone medium
There does appear to be a difference when the call was taken to the IVR -AA rather than an IP phone.
Alex
