FXO - line configuration using H.323 CUCM version 9.X
Steffymurphy
Hi Team,
I have cisco 2911 voice supported router
I have 2 FXO ports on which I have connected 2 lines and I am planning to make a PSTN call using my Cisco IP phone
I tried with MGCP but due to caller ID issue, I am now planning to go for H.323.
Can any one send me a link or guide to configure the same using H.323?
I have cisco IP phone 2
CUCM version 9.1.2
Voice gateway 2911
Connection PLAR number 450001 and 450002
Also with debug commands with respect to only FXO troubleshooting incase of call failure etc. like debugccapi inout etc.
Steffy
Steffymurphy
Please help !!!
Using this IP phone I wanted to make a PSTN call and  for incoming call my PLAR will be 450001
and voice port is 0/0/1 to which the FXO line is connected.
Please help me with dial-peer config also to make outbound and inbound calls
There's plenty of information if you care to search CSC or google
https://supportforums.cisco.com/discussion/11674361/fxo-and-need-plar-config
http://www.gossamer-threads.com/lists/cisco/nsp/87077
java
if this helps, please rate
