07-21-2014 02:01 AM - edited 03-16-2019 11:28 PM
Hi ,
i ahve cucm 10 with mgcp gateway 3925...
it has 4 port fxo card..in which analog line is connected...
incoming to line is ok..but wen dialing outside with line, it gives silence in begin and then busy tone and disconnect it..
what could be issue...?
see attached logs and router config..
Solved! Go to Solution.
07-23-2014 02:45 AM
after apply last given configuration, caller-id still not coming.. and also incoming call rings continuous after disconnect from caller party...
see latest config..
QCCI-CME-001#sh run
Building configuration...
Current configuration : 8790 bytes
! Last configuration change at 10:04:02 Qatar Wed Jul 23 2014
! NVRAM config last updated at 10:04:02 Qatar Wed Jul 23 2014
version 15.2
service timestamps debug datetime localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname QCCI-CME-001
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 16000 informational
no logging console
enable secret 4 bC.97maQjMFAWcNEUZ5wrSbEE9alO/zx06K.p6ZF/WU
aaa new-model
aaa authentication login QCCI_admin group tacacs+ local
aaa authorization console
aaa authorization config-commands
aaa authorization exec QCCI_admin group tacacs+ none
aaa authorization commands 15 QCCI_admin group tacacs+ none
aaa accounting exec QCCI_admin start-stop group tacacs+
aaa accounting commands 15 QCCI_admin start-stop group tacacs+
aaa accounting network QCCI_admin start-stop group tacacs+
aaa accounting connection QCCI_admin start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
clock timezone Qatar 3 12
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
ip domain name qcci.com
no ipv6 cef
isdn switch-type primary-4ess
crypto pki trustpoint TP-self-signed-4292674433
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4292674433
revocation-check none
rsakeypair TP-self-signed-4292674433
crypto pki certificate chain TP-self-signed-4292674433
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 34323932 36373434 3333301E 170D3134 30323236 31323032
35345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 32393236
37343433 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100B988 0B48D01A EED93263 42FC19F9 AC6CA49B 1CDEB849 71B4B3FC C2B594DE
FDA84E89 E124FF01 0FE8A120 4874AB86 D221ECF9 92B07929 CFD5189A 7B600D57
ABC0578D 5300571E 2AF5B3D3 3B15E993 D1BF8DB8 A893EF10 C43D732A 8F3BF3AB
42898596 093C6035 EE631E45 2CB67EB8 50A8C7DB B393671A 258529FD DB67B93B
B9450203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14ABE834 308D994F 7024F6C9 93739A38 148AC85E BD301D06
03551D0E 04160414 ABE83430 8D994F70 24F6C993 739A3814 8AC85EBD 300D0609
2A864886 F70D0101 05050003 81810000 2F00E462 B9F10201 62961F81 A38902F5
2BEDFD5E 221FFDE2 A65FAA41 9021A968 D78DCC3E 63F859A2 B6257984 83713C17
3079C634 C469013C E3437C49 E11C80FC 31EA1DDC D6EBE76E A51D5FA9 E86B088D
9CE5563F 018427EC CE1DA52A DA68C777 E4C3E0BB 8E496DC0 7689EFD7 01FAD4BE
611576CE 70A39A17 4C62AE5B 050E71
quit
voice-card 0
dspfarm
dsp services dspfarm
license udi pid C3900-SPE100/K9 sn FOC175239KV
hw-module pvdm 0/0
username qcci privilege 15 password 7 1503080F0D7B7977691376
username emergency privilege 7 secret 4 TZaKnZj9mkiPyhL5k6EOop3mGAdDwt/MTqlTnFaAtME
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-20 service mgcp
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description VSS Gi1/1/28
ip address 192.168.6.3 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip default-gateway 192.168.6.1
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 192.168.6.1
ip tacacs source-interface GigabitEthernet0/0
ip access-list standard telnet
permit 192.168.1.0 0.0.0.255
permit 192.168.2.0 0.0.0.255
permit 192.168.4.0 0.0.0.255
permit 192.168.15.0 0.0.0.255
permit 10.25.1.0 0.0.0.255
permit 10.25.10.0 0.0.0.255
permit 192.168.5.0 0.0.0.255
logging source-interface GigabitEthernet0/0
logging host 192.168.15.251
nls resp-timeout 1
cpd cr-id 1
snmp-server community cacti RO
snmp-server enable traps entity-sensor threshold
snmp-server host 192.168.15.115 cacti
tacacs-server host 192.168.15.36
tacacs-server directed-request
tacacs-server key 7 142631282524787B757A626772425744575215
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
supervisory disconnect dualtone mid-call
timeouts call-disconnect 5
timing hookflash-out 50
timing guard-out 1000
station-id number 44678237
caller-id enable
caller-id alerting dsp-pre-allocate
voice-port 0/2/1
caller-id enable
voice-port 0/2/2
caller-id enable
voice-port 0/2/3
ccm-manager redundant-host 192.168.5.5
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.5.6
ccm-manager config
mgcp
mgcp call-agent 192.168.5.6 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 192.168.5.6 identifier 1 priority 1 version 7.0
sccp ccm 192.168.5.5 identifier 2 priority 2 version 7.0
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register qcci-xcoder
dspfarm profile 1 transcode
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 4
associate application SCCP
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1
dial-peer voice 999020 pots
service mgcpapp
answer-address .T
port 0/2/0
dial-peer voice 999021 pots
service mgcpapp
answer-address .T
port 0/2/1
dial-peer voice 999022 pots
service mgcpapp
answer-address .T
port 0/2/2
gatekeeper
shutdown
banner login ^CC
* This system is for the use of authorized users only. Individuals using *
* this computer system without authority, or in excess of their authority, *
* are subject to having all of their activities on this system monitored *
* and recorded by system personnel. In the course of monitoring individuals *
* improperly using this system, or in the course of system maintenance, the *
* activities of authorized users may also be monitored. Anyone using this *
* system expressly consents to such monitoring and is advised that if such *
* monitoring reveals possible criminal activity, system personnel may *
* provide the evidence of such monitoring to law enforcement officials. *
^C
line con 0
exec-timeout 15 0
logging synchronous
login authentication QCCI_admin
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class telnet in
exec-timeout 15 0
privilege level 15
transport input telnet ssh
line vty 5 15
exec-timeout 15 0
scheduler allocate 20000 1000
ntp server 10.25.1.1
end
07-23-2014 03:19 AM
As i inform you MGCP has a big problem regarding caller id , so we go to H323 solution.Can you share with me which cptone you use , or which country you are locate ?.We need to configure cptone command under voice-port
please rate all useful information
07-23-2014 03:36 AM
i am in qatar...
07-21-2014 03:59 AM
ice-port 0/2/0
timeouts wait-release 5
caller-id enable
voice-port 0/2/1
caller-id enable
voice-port 0/2/2
caller-id enable
07-21-2014 04:01 AM
outbound call log..
QCCI-CME-001#
Jul 21 14:12:30 Qatar: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x2A471E4, Interface Type=6, Destination=50114712, Mode=0x9,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=50114712(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=A0000000029da00e000000F5)
Jul 21 14:12:30 Qatar: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 21 14:12:30 Qatar: :cc_get_feature_vsa malloc success
Jul 21 14:12:30 Qatar: cc_get_feature_vsa count is 1
Jul 21 14:12:30 Qatar: :FEATURE_VSA attributes are: feature_name:0,feature_time:48805760,feature_id:571
Jul 21 14:12:30 Qatar: //571/10B5ADA38114/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Jul 21 14:12:30 Qatar: //571/10B5ADA38114/CCAPI/ccCallSetContext:
Context=0x2E671B0
Interface=0x2844AA0, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
Jul 21 14:12:30 Qatar: cc_get_feature_vsa count is 2
Jul 21 14:12:30 Qatar: :FEATURE_VSA attributes are: feature_name:0,feature_time:48805088,feature_id:572
Jul 21 14:12:30 Qatar: //572/10B5ADA38114/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Jul 21 14:12:30 Qatar: //572/10B5ADA38114/CCAPI/ccCallSetContext:
Context=0x2E66FA0
Jul 21 14:12:30 Qatar: //572/10B5ADA38114/CCAPI/cc_api_call_connected:
Interface=0x2844AA0, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Jul 21 14:12:30 Qatar: //571/10B5ADA38114/CCAPI/cc_api_call_proceeding:
Interface=0x2A471E4, Progress Indication=NULL(0)
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/cc_api_call_cut_progress:
Interface=0x2A471E4, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Cause Value=0
Call Entry(Responsed=TRUE)
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/ccCallModify:
Nominator=0x1000, Params=0x1005AB0, Call Id=571
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/ccCallReportDigits:
(callID=0x23B, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=571
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x2A471E4, callID=0x23B, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x2A471E4, Call Id=571
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0x23B, gcid=0-0-0-0, tag=0x0)
Jul 21 14:12:34 Qatar: //572/10B5ADA38114/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0x23C, gcid=0-0-0-0, tag=0x0)
Conference Id=0xFFFFFFFF, Call Id1=571, Call Id2=572, Tag=0x0
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/cc_api_bridge_done:
Conference Id=0xF9, Source Interface=0x2A471E4, Source Call Id=571,
Destination Call Id=572, Disposition=0x0, Tag=0xFFFFFFFF
Jul 21 14:12:34 Qatar: //572/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Jul 21 14:12:34 Qatar: call_info mainst_callID:0x23C, peer_callID:0x23B, confID:0xF9, spi_type:6, media_flo_thru:1, media_passthru:1, num_streams:1, swmtpmsp_present:0
Jul 21 14:12:34 Qatar: //572/10B5ADA38114/CCAPI/cc_api_bridge_done:
Conference Id=0xF9, Source Interface=0x2844AA0, Source Call Id=572,
Destination Call Id=571, Disposition=0x0, Tag=0x0
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0xF9, Destination Call Id=572)
Call Entry(Conference Id=0xF9, Destination Call Id=571)
Jul 21 14:12:34 Qatar: confID:0xF9; callEntry1 callID1:0x23B, type:6; callEntry2 callID2:0x23C, type:9
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/cc_api_caps_ind:
Destination Interface=0x2844AA0, Destination Call Id=572, Source Call Id=571,
Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
Jul 21 14:12:34 Qatar: //572/10B5ADA38114/CCAPI/cc_api_caps_ind:
Destination Interface=0x2A471E4, Destination Call Id=571, Source Call Id=572,
Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
Modem=0x2, Codec Bytes=160, Signal Type=2)
Jul 21 14:12:34 Qatar: //572/10B5ADA38114/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=9127)
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/cc_api_caps_ack:
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x2A471E4, Call Id=571
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/cc_api_voice_mode_event:
Call Id=571
Call Entry(Context=0x2E671B0)
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/cc_api_call_connected:
Interface=0x2A471E4, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Connection Handle=0
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/cc_process_notify_bridge_done:
Conference Id=0xF9, Call Id1=571, Call Id2=572
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/ccDigitDialStop:
Call Id=571
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/cc_api_dialing_complete:
Return Value=FALSE, Interface=0x2A471E4, Call Id=571
Call Id=571
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms)
Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/ccRestartDigitTimeoutMsec:
Digit Timeout=0, Call Id=571
Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
Jul 21 14:12:34 Qatar: //571/10B5ADA38114/CCAPI/ccCallModifyExtended:
Nominator=0x1005A18, Params=0x1004B38, Call Id=571
Jul 21 14:12:34 Qatar: //572/10B5ADA38114/CCAPI/ccCallModify:
Nominator=0x18E30, Params=0x1004D58, Call Id=572
Jul 21 14:12:34 Qatar: //572/10B5ADA38114/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x2844AA0, Call Id=572
Jul 21 14:12:38 Qatar: //571/10B5ADA38114/CCAPI/cc_handle_inter_digit_timer:
Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
Jul 21 14:12:46 Qatar: //571/10B5ADA38114/CCAPI/ccCallModifyExtended:
Jul 21 14:12:46 Qatar: //572/10B5ADA38114/CCAPI/ccCallModify:
Nominator=0x800, Params=0x1004D58, Call Id=572
Jul 21 14:12:46 Qatar: //571/10B5ADA38114/CCAPI/cc_api_call_modify_done:
Jul 21 14:12:46 Qatar: //572/10B5ADA38114/CCAPI/cc_api_call_modify_done:
Jul 21 14:12:46 Qatar: //572/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Jul 21 14:12:46 Qatar: call_info mainst_callID:0x23C, peer_callID:0x23B, confID:0xF9, spi_type:6, media_flo_thru:1, media_passthru:1, num_streams:1, swmtpmsp_present:0
Jul 21 14:12:46 Qatar: //571/10B5ADA38114/CCAPI/ccCallReportDigits:
(callID=0x23B, digit_event=0x0, enable=FALSE, consume=FALSE)
Jul 21 14:12:46 Qatar: //571/10B5ADA38114/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x2A471E4, callID=0x23B, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Jul 21 14:12:46 Qatar: //572/10B5ADA38114/CCAPI/ccGetCallStatistics:
Call Stats=0x3009700, Call Id=572
Jul 21 14:12:46 Qatar: //571/10B5ADA38114/CCAPI/ccConferenceDestroy:
Conference Id=0xF9, Tag=0x0
Jul 21 14:12:46 Qatar: confID:0xF9; callEntry1 callID1:0x23B, type:6; callEntry2 callID2:0x23C, type:9
Jul 21 14:12:46 Qatar: //571/10B5ADA38114/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=572, Disposition=0x0, Tag=0x0
Jul 21 14:12:46 Qatar: //572/10B5ADA38114/CCAPI/cc_api_bridge_drop_done:
Jul 21 14:12:46 Qatar: //571/10B5ADA38114/CCAPI/cc_generic_bridge_done:
Jul 21 14:12:46 Qatar: //571/10B5ADA38114/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jul 21 14:12:46 Qatar: //571/10B5ADA38114/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
Jul 21 14:12:46 Qatar: //572/10B5ADA38114/CCAPI/ccCallDisconnect:
Jul 21 14:12:46 Qatar: //572/10B5ADA38114/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2844AA0, Tag=0x0, Call Id=572,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Jul 21 14:12:46 Qatar: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 21 14:12:46 Qatar: :cc_free_feature_vsa freeing 2E8B4D8
Jul 21 14:12:46 Qatar: vsacount in free is 1
Jul 21 14:12:46 Qatar: //571/10B5ADA38114/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2A471E4, Tag=0x0, Call Id=571,
Jul 21 14:12:46 Qatar: :cc_free_feature_vsa freeing 2E8B778
Jul 21 14:12:46 Qatar: vsacount in free is 0
07-21-2014 04:02 AM
for incoming call logs..
CCI-CME-001#
QCCI-CME-001#
QCCI-CME-001#
QCCI-CME-001#
QCCI-CME-001#
Jul 21 14:13:51 Qatar: //-1/40E1E3D7825F/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=50114712
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Jul 21 14:13:51 Qatar: //-1/40E1E3D7825F/CCAPI/cc_api_call_setup_ind_common:
Interface=0x2A471E4, Call Info(
Calling Number=50114712,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=999020, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jul 21 14:13:51 Qatar: //-1/40E1E3D7825F/CCAPI/ccCheckClipClir:
In: Calling Number=50114712(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=50114712(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jul 21 14:13:51 Qatar: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 21 14:13:51 Qatar: :cc_get_feature_vsa malloc success
Jul 21 14:13:51 Qatar: cc_get_feature_vsa count is 1
Jul 21 14:13:51 Qatar: :FEATURE_VSA attributes are: feature_name:0,feature_time:48805760,feature_id:573
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=50114712(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/cc_process_call_setup_ind:
Event=0x14596260
>>>>CCAPI handed cid 573 with tag 999020 to app "MGCPAPP"
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/ccCallSetContext:
Context=0x2E671B0
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/ccCallSetupAck:
Call Id=573
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x0
Call Entry(Connected=TRUE, Responsed=TRUE)
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/ccCallModify:
Nominator=0x1, Params=0x1005790, Call Id=573
Jul 21 14:13:51 Qatar: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jul 21 14:13:51 Qatar: cc_get_feature_vsa count is 2
Jul 21 14:13:51 Qatar: :FEATURE_VSA attributes are: feature_name:0,feature_time:48805088,feature_id:574
Jul 21 14:13:51 Qatar: //574/40E1E3D7825F/CCAPI/ccIFCallSetupRequestPrivate:
Jul 21 14:13:51 Qatar: //574/40E1E3D7825F/CCAPI/ccCallSetContext:
Context=0x2E66FA0
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x2A471E4, Call Id=573
Jul 21 14:13:51 Qatar: //574/40E1E3D7825F/CCAPI/cc_api_call_connected:
Connection Handle=0
Jul 21 14:13:51 Qatar: //574/40E1E3D7825F/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0x23E, gcid=0-0-0-0, tag=0x0)
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0x23D, gcid=40E1E3D7-FFD11E4-825FB71C-77153188, tag=0x0)
Conference Id=0xFFFFFFFF, Call Id1=574, Call Id2=573, Tag=0x0
Jul 21 14:13:51 Qatar: //574/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Jul 21 14:13:51 Qatar: call_info mainst_callID:0x23E, peer_callID:0x23D, confID:0xFA, spi_type:6, media_flo_thru:1, media_passthru:1, num_streams:1, swmtpmsp_present:0
Jul 21 14:13:51 Qatar: //574/40E1E3D7825F/CCAPI/cc_api_bridge_done:
Conference Id=0xFA, Source Interface=0x2844AA0, Source Call Id=574,
Destination Call Id=573, Disposition=0x0, Tag=0x0
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_bridge_done:
Conference Id=0xFA, Source Interface=0x2A471E4, Source Call Id=573,
Destination Call Id=574, Disposition=0x0, Tag=0xFFFFFFFF
Jul 21 14:13:51 Qatar: //574/40E1E3D7825F/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0xFA, Destination Call Id=573)
Call Entry(Conference Id=0xFA, Destination Call Id=574)
Jul 21 14:13:51 Qatar: confID:0xFA; callEntry1 callID1:0x23E, type:9; callEntry2 callID2:0x23D, type:6
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_caps_ind:
Destination Interface=0x2844AA0, Destination Call Id=574, Source Call Id=573,
Jul 21 14:13:51 Qatar: //574/40E1E3D7825F/CCAPI/cc_api_caps_ind:
Destination Interface=0x2A471E4, Destination Call Id=573, Source Call Id=574,
Jul 21 14:13:51 Qatar: //574/40E1E3D7825F/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7681)
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_caps_ack:
Jul 21 14:13:51 Qatar: //574/40E1E3D7825F/CCAPI/cc_process_notify_bridge_done:
Conference Id=0xFA, Call Id1=574, Call Id2=573
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_voice_mode_event:
Call Id=573
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/ccSetDigitTimeouts:
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/ccRestartDigitTimeoutMsec:
Digit Timeout=0, Call Id=573
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/ccCallReportDigits:
(callID=0x23D, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=573
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x2A471E4, callID=0x23D, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x2A471E4, Call Id=573
Nominator=0x1000, Params=0x10055B0, Call Id=573
Jul 21 14:13:51 Qatar: //573/40E1E3D7825F/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Ring Back,
Tone Direction=Network, Params=0x0, Call Id=573
Jul 21 14:13:55 Qatar: //573/40E1E3D7825F/CCAPI/cc_handle_inter_digit_timer:
Jul 21 14:13:59 Qatar: //573/40E1E3D7825F/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Jul 21 14:13:59 Qatar: //573/40E1E3D7825F/CCAPI/ccCallModify:
Jul 21 14:13:59 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_call_modify_done:
Jul 21 14:13:59 Qatar: //573/40E1E3D7825F/CCAPI/ccCallModifyExtended:
Nominator=0x1005A18, Params=0x1004B38, Call Id=573
Jul 21 14:13:59 Qatar: //574/40E1E3D7825F/CCAPI/ccCallModify:
Nominator=0x18E30, Params=0x1004D58, Call Id=574
Jul 21 14:13:59 Qatar: //574/40E1E3D7825F/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x2844AA0, Call Id=574
Jul 21 14:13:59 Qatar: //574/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Jul 21 14:13:59 Qatar: call_info mainst_callID:0x23E, peer_callID:0x23D, confID:0xFA, spi_type:6, media_flo_thru:1, media_passthru:1, num_streams:1, swmtpmsp_present:0
Jul 21 14:14:00 Qatar: //573/40E1E3D7825F/CCAPI/ccCallModifyExtended:
Jul 21 14:14:00 Qatar: //574/40E1E3D7825F/CCAPI/ccCallModify:
Nominator=0x800, Params=0x1004D58, Call Id=574
Jul 21 14:14:00 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_call_modify_done:
Jul 21 14:14:00 Qatar: //574/40E1E3D7825F/CCAPI/cc_api_call_modify_done:
Jul 21 14:14:00 Qatar: //574/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Jul 21 14:14:00 Qatar: call_info mainst_callID:0x23E, peer_callID:0x23D, confID:0xFA, spi_type:6, media_flo_thru:1, media_passthru:1, num_streams:1, swmtpmsp_present:0
Jul 21 14:14:00 Qatar: //573/40E1E3D7825F/CCAPI/ccCallReportDigits:
(callID=0x23D, digit_event=0x0, enable=FALSE, consume=FALSE)
Jul 21 14:14:00 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x2A471E4, callID=0x23D, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Jul 21 14:14:00 Qatar: //574/40E1E3D7825F/CCAPI/ccGetCallStatistics:
Call Stats=0x3009700, Call Id=574
Jul 21 14:14:00 Qatar: //574/40E1E3D7825F/CCAPI/ccConferenceDestroy:
Conference Id=0xFA, Tag=0x0
Jul 21 14:14:00 Qatar: confID:0xFA; callEntry1 callID1:0x23E, type:9; callEntry2 callID2:0x23D, type:6
Jul 21 14:14:00 Qatar: //574/40E1E3D7825F/CCAPI/cc_api_bridge_drop_done:
Jul 21 14:14:00 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=574, Disposition=0x0, Tag=0x0
Jul 21 14:14:00 Qatar: //574/40E1E3D7825F/CCAPI/cc_generic_bridge_done:
Jul 21 14:14:00 Qatar: //573/40E1E3D7825F/CCAPI/ccCallDisconnect:
Jul 21 14:14:00 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_get_transfer_info:
Jul 21 14:14:00 Qatar: //574/40E1E3D7825F/CCAPI/ccCallDisconnect:
Jul 21 14:14:00 Qatar: //574/40E1E3D7825F/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2844AA0, Tag=0x0, Call Id=574,
Jul 21 14:14:00 Qatar: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 21 14:14:00 Qatar: :cc_free_feature_vsa freeing 2E8B4D8
Jul 21 14:14:00 Qatar: vsacount in free is 1
Jul 21 14:14:00 Qatar: //573/40E1E3D7825F/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2A471E4, Tag=0x0, Call Id=573,
Jul 21 14:14:00 Qatar: :cc_free_feature_vsa freeing 2E8B778
Jul 21 14:14:0
07-21-2014 04:21 AM
We will try the following and i hope to success
1- under voice-ports
caller-id enable
sh
no sh
2-answer-address .T under MGCP dial-peer.
voice-port 0/2/0
caller-id enable
sh
no sh
exit
voice-port 0/2/1
caller-id enable
sh
no sh
voice-port 0/2/2
caller-id enable
sh
no sh
exit
answer-address .T
exit
answer-address .T
exit
answer-address .T
exit
answer-address .T
exit
answer-address .T
exit
no mgcp
mgcp
07-21-2014 02:20 AM
voice-port 0/2/0
signal groundStart
input gain 14
caller-id enable
ccm-manager mgcp
ccm-manager config
mgcp
mgcp sdp simple
no result...
same no sound first...after 5 second busy tone.,. and disconnect..
