FXO problem: each incoming ring treated as new call.
IP Phone rings once and call cancelled on each incoming ring.
Started several day ago. I suppose telephone provider changed something in PBX settings. Speaking with them is unproductive, hard to find real specialist.
Any suggestions to try on my side?
samara-lo7-2811#sho run | sect voice-port 0/0/1
input gain -6
cptone RU
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 300
connection plar 6999
Oct  3 11:44:11.908: htsp_process_event: [0/0/1, FXOLS_RINGING, E_DSP_SIG_0100]
Oct  3 11:44:11.908: fxols_ringing_not
Oct  3 11:44:11.908: htsp_timer_stop
Oct  3 11:44:11.908: htsp_timer_stop3 htsp_setup_ind
Oct  3 11:44:11.908: [0/0/1] get_local_station_id calling num= calling name= calling time=10/03 15:44  orig called=
Oct  3 11:44:11.908: TGRM: reg_invoke_tgrm_accept_call(1, TGRM_CALL_VOICE, TGRM_DIRECTION_IN, 0, 0, 1, 65535)
Oct  3 11:44:11.908: TGRM: Calling vtsp_tsp_call_setup_ind().
Oct  3 11:44:11.916: htsp_process_event: [0/0/1, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Oct  3 11:44:11.916: fxols_wait_setup_ack:
Oct  3 11:44:11.916: [0/0/1] set signal state = 0xC timestamp = 0
Oct  3 11:44:11.916: dsp_set_sig_state: [0/0/1] packet_len=12 channel_id=129 packet_id=39 state=0xC timestamp=0x0fxols_check_auto_call
Oct  3 11:44:11.924: htsp_timer_stop3
Oct  3 11:44:11.924: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
Oct  3 11:44:11.924: htsp_timer - 120000 msechtsp_setup_req
Oct  3 11:44:11.928: htsp_process_event: [50/0/25.1, EFXS_ONHOOK, E_HTSP_SETUP_REQ]efxs_onhook_setup
Oct  3 11:44:11.928: htsp_ephone_start_caller_id_tx calling num=2670000 calling name = called num=6999 orig called num=
Oct  3 11:44:11.928: [50/0/25.1] set signal state = 0x0 timestamp = 0
Oct  3 11:44:11.928: edsp_set_sig_state: [50/0/25.1] packet_len=12 channel_id=193 packet_id=39 state=0x0 timestamp=0x0
Oct  3 11:44:11.928: edsp_soutput: [50/0/25.1] DN=25 chnl=193
Oct  3 11:44:11.928: edsp_soutput: [50/0/25.1] DN=25 chnl=193  StationInsideRing
Oct  3 11:44:11.932: efxs_onhook_setup: local target is available
htsp_alerthtsp_alert_notify
Oct  3 11:44:11.944: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
Oct  3 11:44:12.168: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_DSP_SIG_1100]fxols_offhook_disc
Oct  3 11:44:12.168: htsp_timer2 - 350 msec
Oct  3 11:44:12.520: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
Oct  3 11:44:12.520: htsp_timer_stop
Oct  3 11:44:12.520: htsp_timer_stop2
Oct  3 11:44:12.520: htsp_timer_stop3
Oct  3 11:44:12.520: htsp_timer_stop3 htsp_release_req: cause 16, no_onhook 0
Oct  3 11:44:12.524: htsp_process_event: [50/0/25.1, EFXS_WAIT_OFFHOOK, E_HTSP_RELEASE_REQ]efxs_waitoff_release
Oct  3 11:44:12.524: [50/0/25.1] set signal state = 0x4 timestamp = 0
Oct  3 11:44:12.524: edsp_set_sig_state: [50/0/25.1] packet_len=12 channel_id=193 packet_id=39 state=0x4 timestamp=0x0
Oct  3 11:44:12.524: edsp_soutput: [50/0/25.1] DN=25 chnl=193
Oct  3 11:44:12.524: edsp_soutput: [50/0/25.1] DN=25 chnl=193 StationRingOff
Oct  3 11:44:12.524: TGRM: reg_invoke_tgrm_call_update(50, 0, 25, 65535, 0, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
Oct  3 11:44:12.536: edsprm_close_cleanuphtsp_release_req: cause 16, no_onhook 0
Oct  3 11:44:12.540: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ]fxols_offhook_release
Oct  3 11:44:12.540: htsp_timer_stop
Oct  3 11:44:12.540: htsp_timer_stop2
Oct  3 11:44:12.540: htsp_timer_stop3
Oct  3 11:44:12.540: [0/0/1] set signal state = 0x4 timestamp = 0
Oct  3 11:44:12.544: dsp_set_sig_state: [0/0/1] packet_len=12 channel_id=129 packet_id=39 state=0x4 timestamp=0x0
Oct  3 11:44:12.544: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Oct  3 11:44:12.544: htsp_timer - 2000 msec
Oct  3 11:44:12.544: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
Oct  3 11:44:12.544: flex_dsprm_close_cleanup
Oct  3 11:44:14.544: htsp_process_event: [0/0/1, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Oct  3 11:44:14.544: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
Oct  3 11:44:14.544: dsp_req_sig_state: [0/0/1] packet_len=8 channel_id=129 packet_id=40
Oct  3 11:44:14.548: htsp_process_event: [0/0/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
Oct  3 11:44:15.808: htsp_process_event: [0/0/1, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Oct  3 11:44:15.808: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_PENDING, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Oct  3 11:44:15.808: htsp_timer - 125 msec
Oct  3 11:44:15.936: htsp_process_event: [0/0/1, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Oct  3 11:44:15.936: htsp_timer - 10000 msec
Oct  3 11:44:17.940: htsp_process_event: [0/0/1, FXOLS_RINGING, E_DSP_SIG_0100]
Oct  3 11:44:17.940: fxols_ringing_not
Oct  3 11:44:17.940: htsp_timer_stop
Oct  3 11:44:17.940: htsp_timer_stop3 htsp_setup_ind
Oct  3 11:44:17.940: [0/0/1] get_local_station_id calling num= calling name= calling time=10/03 15:44  orig called=
Oct  3 11:44:17.940: TGRM: reg_invoke_tgrm_accept_call(1, TGRM_CALL_VOICE, TGRM_DIRECTION_IN, 0, 0, 1, 65535)
Oct  3 11:44:17.940: TGRM: Calling vtsp_tsp_call_setup_ind().
Oct  3 11:44:17.948: htsp_process_event: [0/0/1, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Oct  3 11:44:17.948: fxols_wait_setup_ack:
Oct  3 11:44:17.948: [0/0/1] set signal state = 0xC timestamp = 0
Oct  3 11:44:17.948: dsp_set_sig_state: [0/0/1] packet_len=12 channel_id=129 packet_id=39 state=0xC timestamp=0x0fxols_check_auto_call
Oct  3 11:44:17.956: htsp_timer_stop3
Oct  3 11:44:17.956: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
Oct  3 11:44:17.956: htsp_timer - 120000 msechtsp_setup_req
Oct  3 11:44:17.960: htsp_process_event: [50/0/25.1, EFXS_ONHOOK, E_HTSP_SETUP_REQ]efxs_onhook_setup
Oct  3 11:44:17.960: htsp_ephone_start_caller_id_tx calling num=2670000 calling name = called num=6999 orig called num=
Oct  3 11:44:17.960: [50/0/25.1] set signal state = 0x0 timestamp = 0
Oct  3 11:44:17.960: edsp_set_sig_state: [50/0/25.1] packet_len=12 channel_id=193 packet_id=39 state=0x0 timestamp=0x0
Oct  3 11:44:17.960: edsp_soutput: [50/0/25.1] DN=25 chnl=193
Oct  3 11:44:17.960: edsp_soutput: [50/0/25.1] DN=25 chnl=193  StationInsideRing
Oct  3 11:44:17.960: efxs_onhook_setup: local target is available
Oct  3 11:44:17.972: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
Oct  3 11:44:18.200: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_DSP_SIG_1100]fxols_offhook_disc
Oct  3 11:44:18.200: htsp_timer2 - 350 msec
Oct  3 11:44:18.552: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
Oct  3 11:44:18.552: htsp_timer_stop
Oct  3 11:44:18.552: htsp_timer_stop2
Oct  3 11:44:18.552: htsp_timer_stop3
Oct  3 11:44:18.552: htsp_timer_stop3 htsp_release_req: cause 16, no_onhook 0
Oct  3 11:44:18.556: htsp_process_event: [50/0/25.1, EFXS_WAIT_OFFHOOK, E_HTSP_RELEASE_REQ]efxs_waitoff_release
Oct  3 11:44:18.556: [50/0/25.1] set signal state = 0x4 timestamp = 0
Oct  3 11:44:18.556: edsp_set_sig_state: [50/0/25.1] packet_len=12 channel_id=193 packet_id=39 state=0x4 timestamp=0x0
Oct  3 11:44:18.556: edsp_soutput: [50/0/25.1] DN=25 chnl=193
Oct  3 11:44:18.556: edsp_soutput: [50/0/25.1] DN=25 chnl=193 StationRingOff
Oct  3 11:44:18.556: TGRM: reg_invoke_tgrm_call_update(50, 0, 25, 65535, 0, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
Oct  3 11:44:18.564: edsprm_close_cleanuphtsp_release_req: cause 16, no_onhook 0
Oct  3 11:44:18.572: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ]fxols_offhook_release
Oct  3 11:44:18.572: htsp_timer_stop
Oct  3 11:44:18.572: htsp_timer_stop2
Oct  3 11:44:18.572: htsp_timer_stop3
Oct  3 11:44:18.572: [0/0/1] set signal state = 0x4 timestamp = 0
Oct  3 11:44:18.572: dsp_set_sig_state: [0/0/1] packet_len=12 channel_id=129 packet_id=39 state=0x4 timestamp=0x0
Oct  3 11:44:18.572: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Oct  3 11:44:18.572: htsp_timer - 2000 msec
Oct  3 11:44:18.572: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
Oct  3 11:44:18.576: flex_dsprm_close_cleanup
Oct  3 11:44:20.572: htsp_process_event: [0/0/1, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Oct  3 11:44:20.572: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
Oct  3 11:44:20.572: dsp_req_sig_state: [0/0/1] packet_len=8 channel_id=129 packet_id=40
Oct  3 11:44:20.572: htsp_process_event: [0/0/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
Oct  3 11:44:21.252: htsp_process_event: [50/0/16.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
Oct  3 11:44:21.252: [50/0/16.1] get_local_station_id calling num=9964495 calling name=Ten I.L calling time=10/03 15:44  orig called=
Oct  3 11:44:21.252: TGRM: reg_invoke_tgrm_accept_call(0, TGRM_CALL_VOICE, TGRM_DIRECTION_IN, 50, 0, 16, 65535)
Oct  3 11:44:21.252: TGRM: Calling vtsp_tsp_call_setup_ind().
Oct  3 11:44:21.256: TGRM: reg_invoke_tgrm_call_update(50, 0, 16, 65535, 0, TGRM_CALL_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Oct  3 11:44:21.264: edsp_soutput: [50/0/16.1] DN=16 chnl=121
Oct  3 11:44:21.264: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_OPEN_VOICE_CHANNEL
Oct  3 11:44:21.264: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_ENC_CONFIG 2
Oct  3 11:44:21.268: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_SET_VOICE_PLAYOUT_DELAY
Oct  3 11:44:21.268: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_ECHO_CANCELLER_CONTROL
Oct  3 11:44:21.268: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_VOICE_MODE codec=1 vad=0 size=160 edsp_state=0
Oct  3 11:44:21.268: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_SET_GAINS
Oct  3 11:44:21.268: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_DTMF_MODE
Oct  3 11:44:21.268: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_CP_TONE_ON 4 dir 1
Oct  3 11:44:21.268: htsp_process_event: [50/0/16.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
Oct  3 11:44:21.604: edsp_soutput: [50/0/16.1] DN=16 chnl=121
Oct  3 11:44:21.604: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_CP_TONE_OFF
Oct  3 11:44:21.604: htsp_digit_ready(50/0/16.1): digit = 6
Oct  3 11:44:21.604: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_DTMF_MODE
Oct  3 11:44:21.792: htsp_process_event: [0/0/1, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Oct  3 11:44:21.792: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_PENDING, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Oct  3 11:44:21.792: htsp_timer - 125 msec
Oct  3 11:44:21.804: htsp_digit_ready(50/0/16.1): digit = 0
Oct  3 11:44:21.920: htsp_process_event: [0/0/1, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Oct  3 11:44:21.920: htsp_timer - 10000 msec
Oct  3 11:44:22.004: htsp_digit_ready(50/0/16.1): digit = 2
Oct  3 11:44:22.204: htsp_digit_ready(50/0/16.1): digit = 0
Oct  3 11:44:22.220: htsp_timer_stop3
Oct  3 11:44:22.220: htsp_process_event: [50/0/16.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
Oct  3 11:44:22.220: [50/0/16.1] set signal state = 0x8 timestamp = 0
Oct  3 11:44:22.220: edsp_set_sig_state: [50/0/16.1] packet_len=12 channel_id=121 packet_id=39 state=0x8 timestamp=0x0
Oct  3 11:44:22.220: edsp_soutput: [50/0/16.1] DN=16 chnl=121
Oct  3 11:44:22.220: edsp_soutput: [50/0/16.1] DN=16 chnl=121 EFXS_PROCEEDINGhtsp_setup_req
Oct  3 11:44:22.224: htsp_process_event: [50/0/11.1, EFXS_ONHOOK, E_HTSP_SETUP_REQ]efxs_onhook_setup
Oct  3 11:44:22.224: htsp_ephone_start_caller_id_tx calling num=9964495 calling name =Ten I.L called num=6020 orig called num=
Oct  3 11:44:22.224: [50/0/11.1] set signal state = 0x0 timestamp = 0
Oct  3 11:44:22.228: edsp_set_sig_state: [50/0/11.1] packet_len=12 channel_id=81 packet_id=39 state=0x0 timestamp=0x0
Oct  3 11:44:22.228: edsp_soutput: [50/0/11.1] DN=11 chnl=81
Oct  3 11:44:22.228: edsp_soutput: [50/0/11.1] DN=11 chnl=81  StationInsideRing
Oct  3 11:44:22.228: efxs_onhook_setup: local target is available
htsp_alerthtsp_alert_notifyhtsp_call_feature:feature 25
htsp_call_feature: caller id enable 0x3 call_connected 0
Oct  3 11:44:22.244: htsp_process_event: [50/0/16.1, EFXS_OFFHOOK, E_HTSP_CALLERID_WAITING]
Oct  3 11:44:22.244: efxs_callerid_update
Oct  3 11:44:22.244: efxs_callerid_update process caller_id_string
Oct  3 11:44:22.244: efxs_callerid_update process caller_id_string OK
Oct  3 11:44:22.244: efxs_callerid_update number= [6020] name= [Ryabchikova L.N.]
Oct  3 11:44:22.244: edsp_soutput: [50/0/16.1] DN=16 chnl=121
Oct  3 11:44:22.244: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_CP_TONE_ON 1 dir 1
Oct  3 11:44:23.964: htsp_process_event: [0/0/1, FXOLS_RINGING, E_DSP_SIG_0100]
Oct  3 11:44:23.964: fxols_ringing_not
Oct  3 11:44:23.964: htsp_timer_stop
Oct  3 11:44:23.964: htsp_timer_stop3 htsp_setup_ind
Oct  3 11:44:23.964: [0/0/1] get_local_station_id calling num= calling name= calling time=10/03 15:44  orig called=
Oct  3 11:44:23.968: TGRM: reg_invoke_tgrm_accept_call(1, TGRM_CALL_VOICE, TGRM_DIRECTION_IN, 0, 0, 1, 65535)
Oct  3 11:44:23.968: TGRM: Calling vtsp_tsp_call_setup_ind().
Oct  3 11:44:23.972: htsp_process_event: [0/0/1, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Oct  3 11:44:23.972: fxols_wait_setup_ack:
Oct  3 11:44:23.972: [0/0/1] set signal state = 0xC timestamp = 0
Oct  3 11:44:23.972: dsp_set_sig_state: [0/0/1] packet_len=12 channel_id=129 packet_id=39 state=0xC timestamp=0x0fxols_check_auto_call
Oct  3 11:44:23.980: htsp_timer_stop3
Oct  3 11:44:23.980: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
Oct  3 11:44:23.980: htsp_timer - 120000 msechtsp_setup_req
Oct  3 11:44:23.984: htsp_process_event: [50/0/25.1, EFXS_ONHOOK, E_HTSP_SETUP_REQ]efxs_onhook_setup
Oct  3 11:44:23.984: htsp_ephone_start_caller_id_tx calling num=2670000 calling name = called num=6999 orig called num=
Oct  3 11:44:23.984: [50/0/25.1] set signal state = 0x0 timestamp = 0
Oct  3 11:44:23.984: edsp_set_sig_state: [50/0/25.1] packet_len=12 channel_id=193 packet_id=39 state=0x0 timestamp=0x0
Oct  3 11:44:23.984: edsp_soutput: [50/0/25.1] DN=25 chnl=193
Oct  3 11:44:23.984: edsp_soutput: [50/0/25.1] DN=25 chnl=193  StationInsideRing
Oct  3 11:44:23.988: efxs_onhook_setup: local target is available
Oct  3 11:44:24.000: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
Oct  3 11:44:24.224: htsp_process_event: [50/0/11.1, EFXS_WAIT_OFFHOOK, E_DSP_SIG_1100]efxs_waitoff_offhook
Oct  3 11:44:24.224: [50/0/11.1] set signal state = 0x4 timestamp = 0
Oct  3 11:44:24.224: edsp_set_sig_state: [50/0/11.1] packet_len=12 channel_id=81 packet_id=39 state=0x4 timestamp=0x0
Oct  3 11:44:24.224: edsp_soutput: [50/0/11.1] DN=11 chnl=81
Oct  3 11:44:24.224: edsp_soutput: [50/0/11.1] DN=11 chnl=81 StationRingOff htsp_dial
Oct  3 11:44:24.224: htsp_process_event: [50/0/11.1, EFXS_CONNECT, E_DSP_DIALING_DONE]
Oct  3 11:44:24.224: htsp_call_bridged invoked
Oct  3 11:44:24.228: htsp_call_bridged invoked
Oct  3 11:44:24.228: edsp_soutput: [50/0/16.1] DN=16 chnl=121
Oct  3 11:44:24.228: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_CP_TONE_OFF
Oct  3 11:44:24.232: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_DSP_SIG_1100]fxols_offhook_disc
Oct  3 11:44:24.232: htsp_timer2 - 350 msec
Oct  3 11:44:24.232: edsp_soutput: [50/0/11.1] DN=11 chnl=81
Oct  3 11:44:24.232: edsp_soutput: [50/0/11.1] DN=11 chnl=81 MSG_RX_OPEN_VOICE_CHANNEL
Oct  3 11:44:24.232: edsp_soutput: [50/0/11.1] DN=11 chnl=81 MSG_RX_ENC_CONFIG 2
Oct  3 11:44:24.232: edsp_soutput: [50/0/11.1] DN=11 chnl=81 MSG_RX_SET_VOICE_PLAYOUT_DELAY
Oct  3 11:44:24.232: edsp_soutput: [50/0/11.1] DN=11 chnl=81 MSG_RX_ECHO_CANCELLER_CONTROL
Oct  3 11:44:24.232: edsp_soutput: [50/0/11.1] DN=11 chnl=81 MSG_RX_VOICE_MODE codec=1 vad=0 size=160 edsp_state=0
Oct  3 11:44:24.236: edsp_soutput: [50/0/11.1] DN=11 chnl=81
Oct  3 11:44:24.236: edsp_soutput: [50/0/11.1] DN=11 chnl=81 MSG_RX_ECHO_CANCELLER_CONTROL
Oct  3 11:44:24.236: edsp_soutput: [50/0/11.1] DN=11 chnl=81 MSG_RX_SET_GAINS
Oct  3 11:44:24.236: edsp_soutput: [50/0/16.1] DN=16 chnl=121
Oct  3 11:44:24.236: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_IDLE_MODE
Oct  3 11:44:24.236: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_ENC_CONFIG 2
Oct  3 11:44:24.236: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_SET_VOICE_PLAYOUT_DELAY
Oct  3 11:44:24.236: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_ECHO_CANCELLER_CONTROL
Oct  3 11:44:24.236: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_VOICE_MODE codec=1 vad=0 size=160 edsp_state=2
Oct  3 11:44:24.240: edsp_soutput: [50/0/16.1] DN=16 chnl=121
Oct  3 11:44:24.240: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_ECHO_CANCELLER_CONTROL
Oct  3 11:44:24.240: edsp_soutput: [50/0/16.1] DN=16 chnl=121 MSG_RX_SET_GAINS
Oct  3 11:44:24.240: htsp_process_event: [50/0/11.1, EFXS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]efxs_connect_cutthru
Oct  3 11:44:24.240: [50/0/11.1] set signal state = 0x7 timestamp = 0
Oct  3 11:44:24.240: edsp_set_sig_state: [50/0/11.1] packet_len=12 channel_id=81 packet_id=39 state=0x7 timestamp=0x0
Oct  3 11:44:24.240: edsp_soutput: [50/0/11.1] DN=11 chnl=81
Oct  3 11:44:24.240: edsp_soutput: [50/0/11.1] DN=11 chnl=81 EFXS_OPEN_VOICE_PATH count=1
Oct  3 11:44:24.240: htsp_process_event: [50/0/16.1, EFXS_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]efxs_offhook_cutthru
Oct  3 11:44:24.240: [50/0/16.1] set signal state = 0x7 timestamp = 0
Oct  3 11:44:24.240: edsp_set_sig_state: [50/0/16.1] packet_len=12 channel_id=121 packet_id=39 state=0x7 timestamp=0x0
Oct  3 11:44:24.240: edsp_soutput: [50/0/16.1] DN=16 chnl=121 EFXS_OPEN_VOICE_PATH count=1htsp_connect: no_offhook 0 call_connected 0
Oct  3 11:44:24.256: edsp_soutput: [50/0/16.1] DN=16 chnl=121
Oct  3 11:44:24.256: edsp_soutput: [50/0/16.1] DN=16 chnl=121htsp_call_feature:feature 25
htsp_call_feature: caller id enable 0x3 call_connected 1
Oct  3 11:44:24.256: htsp_process_event: [50/0/16.1, EFXS_OFFHOOK, E_HTSP_CONNECT]efxs_offhook_connect
Oct  3 11:44:24.256: [50/0/16.1] set signal state = 0x6 timestamp = 0
Oct  3 11:44:24.256: edsp_set_sig_state: [50/0/16.1] packet_len=12 channel_id=121 packet_id=39 state=0x6 timestamp=0x0
Oct  3 11:44:24.256: edsp_soutput: [50/0/16.1] DN=16 chnl=121 EFXS_RVS_BATTERY
Oct  3 11:44:24.260: htsp_process_event: [50/0/16.1, EFXS_CONNECT, E_HTSP_CALLERID_WAITING]
Oct  3 11:44:24.260: efxs_callerid_update
Oct  3 11:44:24.260: efxs_callerid_update process caller_id_string
Oct  3 11:44:24.260: efxs_callerid_update process caller_id_string OK
Oct  3 11:44:24.260: efxs_callerid_update number= [6020] name= [Ryabchikova L.N.]
Oct  3 11:44:24.584: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
Oct  3 11:44:24.584: htsp_timer_stop
Oct  3 11:44:24.584: htsp_timer_stop2
Oct  3 11:44:24.584: htsp_timer_stop3
Oct  3 11:44:24.584: htsp_timer_stop3 htsp_release_req: cause 16, no_onhook 0
Oct  3 11:44:24.588: htsp_process_event: [50/0/25.1, EFXS_WAIT_OFFHOOK, E_HTSP_RELEASE_REQ]efxs_waitoff_release
Oct  3 11:44:24.588: [50/0/25.1] set signal state = 0x4 timestamp = 0
Oct  3 11:44:24.588: edsp_set_sig_state: [50/0/25.1] packet_len=12 channel_id=193 packet_id=39 state=0x4 timestamp=0x0
Oct  3 11:44:24.588: edsp_soutput: [50/0/25.1] DN=25 chnl=193
Oct  3 11:44:24.588: edsp_soutput: [50/0/25.1] DN=25 chnl=193 StationRingOff
Oct  3 11:44:24.588: TGRM: reg_invoke_tgrm_call_update(50, 0, 25, 65535, 0, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
Oct  3 11:44:24.600: edsprm_close_cleanuphtsp_release_req: cause 16, no_onhook 0
Oct  3 11:44:24.604: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ]fxols_offhook_release
Oct  3 11:44:24.604: htsp_timer_stop
Oct  3 11:44:24.604: htsp_timer_stop2
Oct  3 11:44:24.604: htsp_timer_stop3
Oct  3 11:44:24.604: [0/0/1] set signal state = 0x4 timestamp = 0
Oct  3 11:44:24.604: dsp_set_sig_state: [0/0/1] packet_len=12 channel_id=129 packet_id=39 state=0x4 timestamp=0x0
Oct  3 11:44:24.604: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Oct  3 11:44:24.604: htsp_timer - 2000 msec
Oct  3 11:44:24.604: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
Oct  3 11:44:24.608: flex_dsprm_close_cleanup
Oct  3 11:44:26.604: htsp_process_event: [0/0/1, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Oct  3 11:44:26.604: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
Oct  3 11:44:26.604: dsp_req_sig_state: [0/0/1] packet_len=8 channel_id=129 packet_id=40
Oct  3 11:44:26.604: htsp_process_event: [0/0/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
Oct  3 11:44:27.820: htsp_process_event: [0/0/1, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Oct  3 11:44:27.820: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_PENDING, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Oct  3 11:44:27.820: htsp_timer - 125 msec
Oct  3 11:44:27.948: htsp_process_event: [0/0/1, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Oct  3 11:44:27.948: htsp_timer - 10000 msec
Oct  3 11:44:29.996: htsp_process_event: [0/0/1, FXOLS_RINGING, E_DSP_SIG_0100]
Oct  3 11:44:29.996: fxols_ringing_not
Oct  3 11:44:29.996: htsp_timer_stop
Oct  3 11:44:29.996: htsp_timer_stop3 htsp_setup_ind
Oct  3 11:44:29.996: [0/0/1] get_local_station_id calling num= calling name= calling time=10/03 15:44  orig called=
Oct  3 11:44:29.996: TGRM: reg_invoke_tgrm_accept_call(1, TGRM_CALL_VOICE, TGRM_DIRECTION_IN, 0, 0, 1, 65535)
Oct  3 11:44:29.996: TGRM: Calling vtsp_tsp_call_setup_ind().
Oct  3 11:44:30.000: htsp_process_event: [0/0/1, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Oct  3 11:44:30.000: fxols_wait_setup_ack:
Oct  3 11:44:30.000: [0/0/1] set signal state = 0xC timestamp = 0
Oct  3 11:44:30.000: dsp_set_sig_state: [0/0/1] packet_len=12 channel_id=129 packet_id=39 state=0xC timestamp=0x0fxols_check_auto_call
Oct  3 11:44:30.008: htsp_timer_stop3
Oct  3 11:44:30.008: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
Oct  3 11:44:30.008: htsp_timer - 120000 msechtsp_setup_req
Oct  3 11:44:30.012: htsp_process_event: [50/0/25.1, EFXS_ONHOOK, E_HTSP_SETUP_REQ]efxs_onhook_setup
Oct  3 11:44:30.012: htsp_ephone_start_caller_id_tx calling num=2670000 calling name = called num=6999 orig called num=
Oct  3 11:44:30.012: [50/0/25.1] set signal state = 0x0 timestamp = 0
Oct  3 11:44:30.012: edsp_set_sig_state: [50/0/25.1] packet_len=12 channel_id=193 packet_id=39 state=0x0 timestamp=0x0
Oct  3 11:44:30.012: edsp_soutput: [50/0/25.1] DN=25 chnl=193
Oct  3 11:44:30.012: edsp_soutput: [50/0/25.1] DN=25 chnl=193  StationInsideRing
Oct  3 11:44:30.016: efxs_onhook_setup: local target is available
Oct  3 11:44:30.028: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
Oct  3 11:44:30.256: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_DSP_SIG_1100]fxols_offhook_disc
Oct  3 11:44:30.256: htsp_timer2 - 350 msec
Oct  3 11:44:30.608: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
Oct  3 11:44:30.608: htsp_timer_stop
Oct  3 11:44:30.608: htsp_timer_stop2
Oct  3 11:44:30.608: htsp_timer_stop3
Oct  3 11:44:30.612: htsp_timer_stop3 htsp_release_req: cause 16, no_onhook 0
Oct  3 11:44:30.612: htsp_process_event: [50/0/25.1, EFXS_WAIT_OFFHOOK, E_HTSP_RELEASE_REQ]efxs_waitoff_release
Oct  3 11:44:30.612: [50/0/25.1] set signal state = 0x4 timestamp = 0
Oct  3 11:44:30.612: edsp_set_sig_state: [50/0/25.1] packet_len=12 channel_id=193 packet_id=39 state=0x4 timestamp=0x0
Oct  3 11:44:30.612: edsp_soutput: [50/0/25.1] DN=25 chnl=193
Oct  3 11:44:30.612: edsp_soutput: [50/0/25.1] DN=25 chnl=193 StationRingOff
Oct  3 11:44:30.612: TGRM: reg_invoke_tgrm_call_update(50, 0, 25, 65535, 0, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
Oct  3 11:44:30.624: edsprm_close_cleanuphtsp_release_req: cause 16, no_onhook 0
Oct  3 11:44:30.632: htsp_process_event: [0/0/1, FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ]fxols_offhook_release
Oct  3 11:44:30.632: htsp_timer_stop
Oct  3 11:44:30.632: htsp_timer_stop2
Oct  3 11:44:30.632: htsp_timer_stop3
Oct  3 11:44:30.632: [0/0/1] set signal state = 0x4 timestamp = 0un a
Oct  3 11:44:30.632: dsp_set_sig_state: [0/0/1] packet_len=12 channel_id=129 packet_id=39 state=0x4 timestamp=0x0
Oct  3 11:44:30.632: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Oct  3 11:44:30.632: htsp_timer - 2000 msec
Oct  3 11:44:30.632: TGRM: reg_invoke_tgrm_call_update(0, 0, 1, 65535, 1, TGRM_CALL_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
Oct  3 11:44:30.636: flex_dsprm_close_cleanupll
8 Replies 8
paolo bevilacqua
Try reloading router and increase a litle the timeouts configured.
Which timeouts exactly?
increased call-disconnect and wait-release, shut down and unshut voice port.
didn't help
will try reloading at night
keitbr
It sounds like a polarity reversal on the FXO lines.  It is easy enough to test, simply flip the tip/ring lines and see if the problem resolves.
Is there a software command for that? This is a remote site, i don't have physical access.
There is no command and there is no polarity on loopstart FXO.
You should apply the steps I've indicated to you above.
Reverting polarity did not help.
Problem was bad connectivity on operator side. They have fixed contacts and it started to work as usual.
