Bookmark
Subscribe
403
FXO TRUNKGROUP not bypass fxo port if the line is disconnected
Remon Adel
Dears
we face this issue , we have VG with 8 FXO ports used for PSTN calls , all these ports members of TRUNK Group which used for outside calls .when we  unplug the cable from line 1 and place an outbound call, it tries to go out of line 1 and I get a busy signal and call not try to go out through second line which has cable connected
we try these settings but same issue
voice-port x/x/x
cable-detect
How can we set the router up to bypass that port if the line is disconnected with out shut this port administratively ?
R0g22
Add "max-retry 5" under the trunk group and then test.
Hello Nipun Singh Raghav
unfortunately ,issue not fixed after applying this command . do have any other work around tested successfully  ?
