01-21-2009 04:12 AM - edited 03-15-2019 03:39 PM
We have VG224 Gateway registered on our CUCM through sccp. We have assigned 3 extension numbers to FXS ports. But when I add this extensions to the Line group and call to the pilot number, I've heard fast busy.
01-21-2009 06:28 AM
Hi Tauke,
This was nicely answered by Andrew;
"The VG224 ports are "logged out" of Hunt Groups by default.
If you put a tick in the "Logged into Hunt Group" box at the Device Level on the VG224 that will fix it."
Hope this helps!
Rob
01-21-2009 08:43 PM
Hi Rob,
Thanks for quick response, it helps!
thanks in advance.
