FXS ports in Line group
tauke.seiketov
We have VG224 Gateway registered on our CUCM through sccp. We have assigned 3 extension numbers to FXS ports. But when I add this extensions to the Line group and call to the pilot number, I've heard fast busy.
Rob Huffman
Hi Tauke,
This was nicely answered by Andrew;
"The VG224 ports are "logged out" of Hunt Groups by default.
If you put a tick in the "Logged into Hunt Group" box at the Device Level on the VG224 that will fix it."
Hope this helps!
Rob
Hi Rob,
Thanks for quick response, it helps!
thanks in advance.
