Gatekeeper and FXO registration.
roger.gomez
I have a network with at least 20 GK registered to two DGK. In each GK are register 15-20 GW equipped with FXS card, connected to the local PBX. In this way I can use all phone connected to these PBX and with 4 to 8 lines I can redirect traffic trough the wan. On each GK are registered all the dial-peer assigned to those FXS port.
so-suc#show gatekeeper endpoints
                    GATEKEEPER ENDPOINT REGISTRATION
CallSignalAddr  Port  RASSignalAddr   Port  Zone Name         Type    Flags
172.24.255.205  1720  172.24.255.205  64379 GK_2315_SUC-CENTR VOIP-GW
    E164-ID: 2315
    H323-ID: GW_2315_SUC-CENTRO
   Voice Capacity Max.=  Avail.=  Current.= 0
But the FXO interfaces are not registered; for this reason I can’t not reach these dial-peers remotely. I found that just de FXS interface is capable of register with the GK. What I need is some idea of how can I do reachable from different zones the dial-peers configured to user the port of the FXO card. Any help is appreciated.
roger.gomez
Problem solved.
I used Technology Prefix to register the gateway equiped with FXO in the Gatekeeper and work fine.
Hi , could you please explain it for me in details, I have similar problem
I have 3 routers, R1 is the GK
R1#
interface FastEthernet0/0
  bandwidth 10000
  ip virtual-reassembly
  no ip mroute-cache
  duplex auto
  speed auto
  no cdp enable
gatekeeper
  zone local zone1 xxx.ru 192.168.1.1
  zone local zone2 xxx.ru
  zone prefix zone1 01...
  zone prefix zone2 02...
  gw-type-prefix 1#* default-technology
  no shutdown
Routers R2 and R3 has two IP phones and FXO connected to PBX
Configs similar for R2 and R3
R2#
  ip address 192.168.100.1 255.255.255.0
  no ip mroute-cache
  speed auto
  full-duplex
  no cdp enable
  h323-gateway voip interface
  h323-gateway voip id zone1 ipaddr 192.168.1.1 1719
  h323-gateway voip h323-id zone1
  h323-gateway voip bind srcaddr 192.168.100.1
voice-port 2/0
  cptone RU
  timeouts wait-release 5
  station-id name 1
  station-id number 01000
voice-port 2/1
  cptone RU
  station-id name 1
  station-id number 01001
dial-peer voice 11 pots
  destination-pattern 01...
  port 2/0
dial-peer voice 12 pots
  port 2/1
dial-peer voice 02 voip
  destination-pattern 02...
  session target ras
sh gatekeep endpoi  showa only ip phones (eFXS)
First of all forgive me for my English.
The idea is make each gateway with one or more FXO the default gateway for a technology prefix.
In my case is only one gateway so any call that reach this Gatekeeper is transfer to the Gateway, without the need to dial de prefix.
In my case I add to the gateway configuration in the interface:
h323-gateway voip tech-prefix 1#
And in my Gatekeeper configuration:
In any case tell me if this configuration works for you, because you can try to define static aliases, but I think in the case that your network grow that is not a good option.
Best Regard.
Date: Wed, 14 Apr 2010 07:11:04 -0600
To: rogerscuall@hotmail.com
Subject: New message: "Gatekeeper and FXO registration."
Roger Gomez,
A new message was posted in the Discussion thread "Gatekeeper and FXO registration.":
https://supportforums.cisco.com/message/3054090#3054090
Author : Krasnoperov
Profile : https://supportforums.cisco.com/people/Krasnoperov
Message:
