Gatekeeper and FXO registration.
roger.gomez
I have a network with at least 20 GK registered to two DGK. In each GK are register 15-20 GW equipped with FXS card, connected to the local PBX. In this way I can use all phone connected to these PBX and with 4 to 8 lines I can redirect traffic trough the wan. On each GK are registered all the dial-peer assigned to those FXS port.
so-suc#show gatekeeper endpoints
                    GATEKEEPER ENDPOINT REGISTRATION
CallSignalAddr  Port  RASSignalAddr   Port  Zone Name         Type    Flags
172.24.255.205  1720  172.24.255.205  64379 GK_2315_SUC-CENTR VOIP-GW
    E164-ID: 2315
    H323-ID: GW_2315_SUC-CENTRO
   Voice Capacity Max.=  Avail.=  Current.= 0
But the FXO interfaces are not registered; for this reason I can’t not reach these dial-peers remotely. I found that just de FXS interface is capable of register with the GK. What I need is some idea of how can I do reachable from different zones the dial-peers configured to user the port of the FXO card. Any help is appreciated.
roger.gomez
Problem solved.
I used Technology Prefix to register the gateway equiped with FXO in the Gatekeeper and work fine.
