Gatekeeper Locations issues on Call Manager Configurations
oksiazek
Level 5
Level 5
Hi ,
I have set-up a intercluster trunk with Gatekeeper controlled but my problem is that on the trunk configuration in the Call Manager , you need to specify the location of the trunk so that ( what I think) before to send the call to the gatekeeper , it will check if there is enough bandwidth to transfer the call to the gatekeeper but It doesn't care of this . Is it normal ?
What do you think ?
Call Manager version 4.2.3(sr3)
oksiazek
Level 5
Level 5
Hi again ,
I have found my issue .
To work successfully , we need only to redefine a new location different of all locations used in the Cluster , so that , we can analyse the bandwidth usage before to send the call to the trunk and after it is the gatekeeper who will do the CAC .
The bandwidth of this new location for the trunk can be unlimited because gatekeeper will do the management .
Olivier
