gatekeeper prob
jones.jack
        i have a gatekeeper integrte with cucm v7 and i have two gateways .All configuration are ok and cucm & gateways are registered to gatekeeper ,my problem when i dial a number from ip phone which on cucm do not hit ip phone on of other branch  ,debug shows me the call is ok and call is reachable , any help.i use e1 as connection betweenvsites.
4 Accepted Solutions
islam.kamal
Level 10
Level 10
Based on your post that you did the below debugs and the call is ok
1- For gatekeeper ( debug gatekeeper main10). ok
2-For CuCM (debug ISDN q931) . ok you can see the correct calling number and correct called number  and the call reach to the other gateway.
please check the dial peers on the gateway which the call hit it  and the number of digits . I hope to share the configuration and the debugs also.
Thank you
please rate if this will help
Ok you create translation pattern and in pattern (1#.xxxx)  where xxxx is your extension number and in the below of the page you will find called party transformation - discard digit ( predot) . that is all
Thank you
Ok , you can create two dial peers one for GK route and other for your  local connection route as the below
dial-peer voice 1 pots
destination-pattern
port 1/1/1/
dial-peer voice 2 voip
destination-pattern
session target ras
preference 10
Thank you
Good Luck ,On CUCM you can do using route list . for example you have number : xxxxxx go out using GK then your local router .
1- cretae RL which will includes ( GK , standard local gateway).
2- on the route pattern (assign route list to the route list which you crated).
Thank you
8 Replies 8
islam.kamal
Level 10
Level 10
Thank you
i am sure that debugs are useless , let me  check your post.
thanks
how can i receive call on cucm witout 1#?.
Thank you
how can i do redundancy for calls using gatekeeper.for the gateway , eah gateway in each branch has E1 local connection?.
am sorry but i prepare for my ccie voice , i do not have any experience in gatekeeper?. thanks i will try all and send the feedback.
destination-pattern
port 1/1/1/
destination-pattern
session target ras
preference 10
Thank you
Thank you
