Gateway MGCP with a VIC2-2FXS
leandro.perez
I have a Gateway 2801 MGCP with a VIC2-2FXS, well this gateway when run MGCP only detect one FXS in the UCM, I think that is a BUG
the first port
Cisco MGCP FXS Port Registered with x.x.x.x
the second port
Cisco MGCP FXS Port Rejected x.x.x.x
The Router Version 12.4(13r)T
IOS Router c2801-advipservicesk9-mz.124-22.T.bin
The UCM System version: 6.1.2.9961-1
Any suggestion for this problem??
Brandon Buffin
Make sure you have both ports configured in the gateway configuration in CUCM under Device > Gateway.
Brandon
Yes I'm pretty sure
but I think is other configuration that fail
do you have dial-peers with application mgcpapp for those ports??
java
if this helps, please rate
java
Well friends this is a bug on the version the UCM System version: 6.1.2.9961-1
The MGCP Protocol when try to detect a FXS este falló. with two interfaces
thanks for help me
