Gateway to Gateway H.323 trunk
bvial1989
I'm fairly new to the callmanager and was after some advice/direction on trying to set up the following lab environment.
I have a 2821 gateway connected to the PSTN via PRI ISDN. Callmanager 4.2 setup and able to make outgoing calls.
Now, I have added another callmanager (seperate cluster) to the same internal network and was wanting to connect it to a second 2821 router. I was wanting connect this second gateway to the first gateway via a H.323 trunk. Some advice on how to begin setting this up?
First gateway: 2821 router
internal IP: 192.168.1.1
external PSTN: PRI ISDN
Second gateway: 2821 router
internal IP: 192.168.1.2
Do I setup a H.323 trunk between 192.168.1.1 and 192.168.1.2 and can I then route calls the the first callmanager that then will route external calls out the first gateway's PSTN link.
Thanks in advance...
gogasca
Level 10
Level 10
PSTN -- 2821-A --- 2821B --- CCM2
This 2821 should allow connections from h323 to h323.
You only need to create dial-peers in both routers...
in 2821B doing the dialplan that match dial-peer pots in 2821A.
in 2821A dial-peer VOIP for incoming calls from PSTN to CCM2.
Thanks for the reply.
How do I create an endpoint on the 2821B? It is only connected via ethernet port (not to PSTN).
