IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6167 Views
  • 14 replies
I try to install Attendant Console,I make all the settings like in this document: http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803f3a8b.html#wp293921. user: ac (accociate with ACpilot and 2 IP Pho...
hi when i have two NICs on my laptop one for LAN and the other for WLAN for ip communicator what should i configure in device name the MAC of the LAN NIC or the MAC of WLAN i've tested this when i configure device name of LAN MAC and i connected thro...
If an incoming call via an H323 Gateway is placed on hold after 10 mins or more conversation, the call is "lost", both sides getting white noise. If the call is placed on hold after 9:59 it's fine & can be put on hold again for up to 10 mins before t...
I have a customer that does not have enough switch ports and his budget is running tight. He was wondering if he can daisy chain the phones at least two phones to one port on the switch. He wanted me to find out if there "other customers" ran into ...
jgittins1 by Level 1
  • 1809 Views
  • 4 replies
Hello!Is there a way to authorize calls without forced authorization codes?I want to configure a phone to use a authorization code before making any calls(no matter where the call is being made - national, mobile, international).
