02-23-2015 01:59 PM - edited 03-17-2019 02:05 AM
i have to configure a gateway Vg320 over CUCM 10.5, anyone could give an example configuration?
When i configure the CUCM config doesn´t download to the gateway,
I can see the below error when i write "sh ccm-manager config-download"
CCM MANAGER APPLICATION IS NOT CONFIGURED
Thanks Anna.
Solved! Go to Solution.
02-23-2015 05:46 PM
Sounds like you might be having an ip address to name resolution issue on the VG. Try putting an "ip host" entry in the VG for Communications Manger.
Let me know if this helps. -Dennis
02-23-2015 05:27 PM
And exactly what have you configured in the GW???
02-24-2015 08:56 AM
Thanks Dennis, Jaime,
The problem was that i have configured in CUCM web (Device config) a domain name as "xxxxxx.com" and the correct is "gw.xxxxx.com"
thanks.
02-23-2015 05:46 PM
