01-09-2015 05:41 AM - edited 03-17-2019 01:32 AM
Hi All,
I am testing the GDPR between CUCM 10.5 cluster [10.5.2.10000-5 ]. In my ILS network I have 1 Hub & 1 spoke.
Dial plans are synchronized from Hub Cluster to Spoke Cluster .But it's not happening from spoke cluster to Hub. In the Hub cluster ILS logs I could able to see that spoke sending the update message . Due to some reason patterns are not updated in Hub cluster.
What should I check for further troubleshooting ?
Thanks in Advance !!!
04-02-2015 08:33 AM
I have the same problem, but in the other way. Directory URI's are synced from hub to spoke and from spoke to hub. Advertised patterns created on spoke sync to hub, but advertised patterns created on hub never show up on spoke.
Spoke: 10.5.2.10000-5
Hub: 10.5.2.11900-3
04-07-2015 05:02 AM
Hi Peter !
did you able to fix this issue ? . Please share if available.
