Grep in IOS Output
fb_webuser
Level 6
Level 6
I would like to campaign for "grep" support in the Cisco IOS! It would be really awesome to type a command like sh run to get the configs for all dial-peers with a specific session target ip.
Posted by WebUser Billy Bryant from Cisco Support Community App
8 Replies 8
Aaron Harrison
You mean like this?
show run | i dial-peer|session-target
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
danplacek
Level 4
Level 4
include (or 'i') will include all lines that match the criteria.
section (or 's') will include entire sections that match.
Ex:
sh run | s dial-peer
sh run | i load
It is not quite as powerful as grep... but still very useful.
In addition to include and section - begin and exclude can also be used to pipe the output in IOS:
sh run | begin dial-peer                  <<< it will show output begin from the config from dial-peers
sh ip int brief | exclude unassigned   << when you try to do sh ip int brief and intrested in ip info only
Also if you need to get multiple sections:
show run | section dial-peer |dspf     - should show only dial-peer and dsp farm configs.
For include with multiple lines Aaron had already posted above.
I think these all should give you a lot of flexibility - when you want to view only a section from show run.
For me this was my mistake. I haven't route to do anything.
Leo Laohoo
Cisco IOS supports regular expressions.  So you don't necessariyly have to use grep/egrep.
mrana0101
Hello fb_webuser
GREP is possible to run with show commands by enabling Cisco IOS Shell
try following:
conf t
shell processing full
exit
terminal shell (in exec mode)
now it is possible to run show commands with grep.
for example:
R1-2901#sh ver | grep 'cisco'
Technical Support: http://www.cisco.com/techsupport http://www.cisco.com/wwl/export/crypto/tool/stqrg.html export@cisco.com.
hope this helps :)
Ahsan Rana
Ahsan Rana
Thanks!!!
Ahsan Rana
