Hi,does anybody get 802.1x - EAP-TLS with IP-Phones ( e.g. 7962G ) on Microsoft NPS up and running?With ACS it is not a problem at all.thxSebastian
Hi all, I have an unknown problem with CME/Voice Gateway CDRs when using file accounting method. I have the primary destination an FTP server and the secondary one to write to Flash. The first issue is an error message I see in the logging as sho...
hi all which ios version is the best for cisco router 2811? in case of using this scenario: Panasonic TDA100 (PRI 0290) ---> (e1)< cisco 2811> (sip trunk) ----> softx3000 thanks in advance
Hi all,Can someone provide me the url for fastdial? The idea is to create an URL-button with the direct link.Kind regards,Norbert
Hi, This is my first 12.x build, a new build two server CUCM cluster, i.e. not an upgrade but a new install using the v12 OVA template. CUCM is 12.0.1.22900-11 which is the latest I could find. We've noticed that the admin web pages are seriously s...
hi all i have install recently cme gui and i have 2 type of phones (7945 and 7821) sccp and sip its showing only 7945 same as attached pics
Hi All I am trying to find the list of unassigned DN within a particular range using AXL or SQL query. Is there a method to find the list. Any help would be much appreciated.
cucm 11.5 we have the following: phoneA with three lines , line1 and 3 same number and different partitions and both in same pickup group phone B one line and same Pgroup , when I call phoneA line one then im unable to pickup the call using phone B ...
I have to configure auto attendant in CU for callers calling 800#. The 800 number is already forwarded to CTI route point 1000 in CM. I would like the AA to be configured for option to have the caller press 1 to dial by extension if they known it. I ...
Hi , we have situation when users complained that their phones were dialing to operator/main line after they check voicemail. We found out this might be because of users didn't hang up properly with their handset or headsets. Tests confirms, if we do...
I have 2 new Extension Mobility Services I want to add to all the phones in the cluster. Including Device Profiles. I cannot seem to subscribe this service via BAT. What about the check marking the Enterprise Service when creating the IP Phone Servic...
Hello Everyone, We have a mega CUCM cluster with 21 servers for our multi sites Clustering Over WAN deployment. Number of site: 20 with different area codes Number of users: 50000 CUCM Version: 10.5 CUBE (HA): ISR 43xx Current situation: Every si...
I have a SIP gateway that works with both inbound/outbound calls. However when I place an outbound call to an external source through the PSTN I can't pass DTMF. In call manager the route pattern sends calls to the SIP gateway via a SIP trunk in ca...
According to the RTP RFC (3550) Timestamp must increase in each RTP packets:"The timestamp reflects the sampling instant of the first octet in the RTP data packet. The sampling instant MUST be derived from a clock that increments monotonically and l...
Hello , I have a CUCM infrastructure and I have 2 PRA lines (2 x 30 Channels) which we are planning to terminate on a brand new Cisco 4351 . Our supplier quoted us 1 x 64-channel DSP module. Is that correct? They also quoted CUBE-10 license? ...
Subject | Author | Posted |
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM |
User | Count |
6 | |
3 | |
3 | |
2 | |
1 |
