01-13-2011 08:20 AM - edited 03-16-2019 02:51 AM
I have H323 Gateway configured as Gatway with UCM8.0. from some outgoing calls specially to mobile calls, we can't hear ringback on iphone until the called response.
for outgoing calls to fixe PSTN number, we hear the ringback.
for incomming calls i work fine. this is the gateway configuration. any idea?
SICPA#sh run
Building configuration...
Current configuration : 3951 bytes
version 12.4
boot-start-marker
boot-end-marker
card type e1 0 0
logging message-counter syslog
no aaa new-model
network-clock-participate wic 0
dot11 syslog
ip source-route
ip cef
no ipv6 cef
isdn switch-type primary-net5
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service pots
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol cisco
h323
no call service stop
voice class codec 100
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class dualtone-detect-params 77
freq-max-deviation 30
voice class custom-cptone morocco
dualtone disconnect
frequency 435
cadence 500 500
voice-card 0
codec complexity medium
username admin password 7 01100F175804545F701D
archive
log config
hidekeys
controller E1 0/0/0
pri-group timeslots 1-8,16
controller E1 0/0/1
translation-rule 10
Rule 0 ^212........... 00212
translation-rule 1
Rule 0 900 2000
Rule 1 902 2200
Rule 2 903 2300
Rule 3 905 2301
Rule 4 906 2302
Rule 5 904 2400
Rule 6 907 2401
Rule 7 908 2101
Rule 8 909 2102
translation-rule 3
Rule 0 910 2214
Rule 1 916 2208
Rule 2 911 2203
Rule 3 912 2204
Rule 4 913 2205
Rule 5 914 2206
Rule 6 915 2207
Rule 7 917 2209
Rule 8 918 2603
Rule 9 919 2210
translation-rule 9
Rule 1 999 2100
translation-rule 2
Rule 0 928 2504
Rule 1 920 2211
Rule 2 921 2212
Rule 3 924 2215
Rule 4 925 2216
Rule 5 926 2501
Rule 6 927 2502
Rule 7 929 2503
Rule 8 922 2505
Rule 9 923 2213
translation-rule 8
Rule 1 989 2600
interface FastEthernet0/0
ip address 10.7.15.1 255.255.255.0
duplex full
speed auto
no mop enabled
h323-gateway voip bind srcaddr 10.7.15.1
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.7.15.3
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
timeouts interdigit 4
timeouts wait-release 5
dial-peer voice 100 pots
destination-pattern 0T
progress_ind connect enable 8
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 201 pots
destination-pattern 1..
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 200 voip
destination-pattern 90.
translate-outgoing called 1
session target ipv4:10.7.15.2
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 199 voip
destination-pattern 91.
translate-outgoing called 3
codec g711ulaw
no vad
dial-peer voice 198 voip
destination-pattern 92.
translate-outgoing called 2
codec g711ulaw
no vad
dial-peer voice 197 voip
destination-pattern 99.
translate-outgoing called 9
codec g711ulaw
no vad
dial-peer voice 196 voip
destination-pattern 98.
translate-outgoing called 8
codec g711ulaw
no vad
gateway
timer receive-rtp 1200
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 25-Feb-09 17:55 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
SICPA uptime is 2 days, 9 hours, 58 minutes
System returned to ROM by reload at 10:16:11 UTC Thu Jan 6 2011
System image file is "flash:c2800nm-spservicesk9-mz.124-24.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID FCZ13187297
2 FastEthernet interfaces
9 Serial interfaces
2 Channelized/Clear E1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
191K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
01-13-2011 08:54 AM
Adil,
Try adding the following config:-
tone ringback alert-no-PI
progress_ind alert enable 8
progress_ind progress enable 8
Let me know how it goes,
Craig
PLEASE RATE HELPFUL POSTS!
01-14-2011 01:59 AM
hello,
I have appliying this configuration to my pots dial-peer. but the problem still appear rondomlly speciallyt fo all outgoing calls prefix by 06xxxxxxxx.
regards
Adil
01-14-2011 04:16 AM
Adil,
What type of device are in the 06xxxxxxxx range and by random what do you mean, dial first time and get ring back dial same number again and get no ringback?
You have the obvious config changes now.
Have you looked at http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094c33.shtml?
Craig
