IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5945 Views
  • 14 replies
Hello,     I'm curious to know more about NIC teaming for CUCM 8 servers.  From what I understand, running the command set network failover enable will enable this feature, but am wondering how this affects the licenses I've already uploaded (as they...
Hi GuysI am trying to design an SRST function for one of my customers who have CUCMBE that connects to the PSTN via a CUBE router configured for hardware MTP. The SRST gateway will also connect to the PSTN using a SIP trunk but I am confused as to ho...
ianwarb by Level 1
  • 701 Views
  • 2 replies
I just upgraded a UCCX system from 8.0.2.SU1 to 8.0.2.SU2.  After upgrade a couple services have are now stuck in partial service on primary server (User Manager and Application Manager).  Also now when I login it says that I'm running on temporary l...
I needed to call CME from CM through CUBE and GKhere is my conf:CUBE:interface Loopback0 ip address 177.1.254.1 255.255.255.255 h323-gateway voip interface h323-gateway voip id CUBE ipaddr 177.1.254.1 1719 h323-gateway voip h323-id CUBE-HQ h323-gatew...
Buenas,Tebgo configurado un Linksys SPA8000 con la version de firmware 5.1.12, configure 4 cuentas en este equipo y al realizar más de 3 llamadas simultaneas comienzo con problemas de retardo y entrecortes enlas llamadas.Cambie el firmware al 6.1.3 y...
