h.323 and SIP on same gateway
Pawan Arora
I am using 2911 voice gateway with FXO cards running on H.323 protocols. Now I want to terminate a SIP line on my gateway, can anyone please confirm whether we can configure the H.323 and SIP protocol on same gateway. If yes, can you please suggest the requirement/configuration. Is there any document from Cisco for the same.
Manish Prasad
Level 5
Level 5
Hi Pawan,
You need to define protocol under dial-peer. Create an incoming and outgoing dial-peer with session protocol as SIP and point it towards relevant call server (CME or CUCM).
Here is one example of CUBE VG configuration.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/99863-cube-config.html.
Manish
