02-01-2017 12:39 AM - edited 03-17-2019 09:21 AM
I am stuck-up with a new location configuration .we have h.323 gateway with two fxo lines .from call manager end I have made all configuration working . but I am unaware about h.323 gateway configuration . tried configuring gateway as attached but no luck . call doesn't go through . can anyone suggest me ?
02-01-2017 01:59 AM
Can you share the "debug voice ccapi inout" from the gateway for a test outbound call. If the call reaches the gateway then the gateway part needs to be checked, specially the dial-peers and port config which will send the call out. At first look the config looks complete but debug can tell why the call is failing.
Manish
02-01-2017 08:28 PM
Hi manish,
Thank u for replying. Just now saw ur comnents but now i am out of office. I will share you the debug output tomorrow. I had reconfigured the gateway with basic commands. Now outgoing and incoming calls works fine. But they are not able to hear from other end. Also i could hear echo of my voice when they called me . Now I could see transcoder and MTP in unregistered status .
Swathy
