H323 Call Routing - 911
ggerhard
I'm missing something here in this config....
If we dial 10 digits the call goes out the FXO port just fine, 911 gives us a fast-busy.
configs below along w/ the debugs..   weird thing is on the 911 call it appears to be changing the called number and calling number....
config:
Current configuration : 6529 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service sequence-numbers
hostname Ball
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 300000
logging console critical
enable secret 5 $1$jQUY$SdW8OgOkgDnXH5Au5GHhQ1
no aaa new-model
crypto pki trustpoint tti
revocation-check crl
rsakeypair tti
crypto pki trustpoint TP-self-signed-1275929792
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1275929792
revocation-check none
rsakeypair TP-self-signed-1275929792
crypto pki certificate chain tti
crypto pki certificate chain TP-self-signed-1275929792
certificate self-signed 01
  3082024C 308201B5 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323735 39323937 3932301E 170D3131 30373132 31343435
  30305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32373539
  32393739 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100DC3D CA074470 922DDB00 BFB8479C C2C985E5 E7E607BC 29E29426 DAC68DEF
  4B1106F7 0F22EA07 F78BCF41 5F5CA342 BB764BDE 1A1B7EB8 7AF1FD1F BD0BF0B9
  96B23428 2D6C8E45 11E70E92 D45B3728 00F7082F 508FC058 04AF32A8 7E3D6EB4
  F9270627 B9C42F20 9416C6A9 E8991EC7 CBE2A237 3F676A05 E326EBBC 9C215598
  830F0203 010001A3 74307230 0F060355 1D130101 FF040530 030101FF 301F0603
  551D1104 18301682 1442616C 6C2E6462 69736572 76696365 732E636F 6D301F06
  03551D23 04183016 8014A288 03701404 59072011 4EB37AE7 96DFDF08 38DB301D
  0603551D 0E041604 14A28803 70140459 0720114E B37AE796 DFDF0838 DB300D06
  092A8648 86F70D01 01040500 03818100 470493CF 9EA0F433 DC15C2D9 EA288D43
  1F6CFAB6 373286EA 40E9166E C394604B 9A283227 B0A53F55 F5854EB7 5FB7285B
  EB2CEBFB 5C6160C0 CD488F10 BF46BE7C 995B10F9 1A510C8D 97DE8E6F 65843DEA
  61E84252 45980509 318F8398 3800C9FF B448A42C 44A4AB42 A4B05A1A E44CB646
  43886F38 D09EE75A DA1082A9 C0CBEC43
        quit
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.4.3.250 10.4.3.254
ip dhcp pool Ball-Voice
   network 10.4.3.128 255.255.255.128
   default-router 10.4.3.129
   dns-server 10.0.1.52 10.0.1.39
   option 150 ip 10.0.100.13 10.0.100.12
   domain-name dbiservices.com
ip cef
no ip bootp server
no ip domain lookup
ip domain name dbiservices.com
no ipv6 cef
voice service voip
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice-card 0
codec complexity high
crypto ipsec client ezvpn EzVPN
connect auto
group RemoteOffice key dBiVPN$123
mode network-extension
peer 64.111.143.34
username Pineville password dbi$vpn@cc355
xauth userid mode local
archive
log config
  hidekeys
ip tcp synwait-time 10
ip ftp source-interface Vlan40
ip ftp username cisco
ip ftp password cisco
class-map match-any voice-signaling
match  dscp cs3
match  dscp af31
class-map match-any voice-traffic
match  dscp ef
match  dscp cs5
policy-map LAN-QOS
class voice-traffic
  set dscp ef
    priority percent 10
class voice-signaling
  set dscp cs3
policy-map WAN-QOS
class voice-traffic
    priority percent 25
  set dscp ef
    bandwidth 64
  set dscp cs3
interface FastEthernet0
switchport access vlan 40
switchport voice vlan 41
interface FastEthernet1
spanning-tree portfast
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan40
ip address 10.4.3.1 255.255.255.128
ip helper-address 10.0.1.20
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
crypto ipsec client ezvpn EzVPN inside
interface Vlan41
ip address 10.4.3.129 255.255.255.128
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.99.254
ip route 0.0.0.0 0.0.0.0 dhcp
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 10.0.0.0 0.255.255.255
snmp-server community D3Ang3loSnMp_Pub RO 61
snmp-server community D3Ang3loSnMp_Priv RW 61
snmp-server location DeAngelo Brothers Ball LA
snmp-server contact DeAngelo Brothers IT Dept.
snmp-server enable traps tty
control-plane
voice-port 0
voice-port 1
voice-port 2
voice-port 3
voice-port 4
connection plar 4300
caller-id enable
ccm-manager fallback-mgcp
no ccm-manager fax protocol cisco
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
sccp local Vlan41
sccp ccm 10.0.100.12 identifier 2 priority 2 version 5.0.1
sccp ccm 10.0.100.13 identifier 1 priority 1 version 5.0.1
sccp
sccp ccm group 1
bind interface Vlan41
associate ccm 1 priority 1
associate profile 1 register Ball881
dial-peer voice 201010 voip
preference 1
destination-pattern 4300
voice-class codec 1
session target ipv4:10.0.100.13
dtmf-relay h245-alphanumeric
dial-peer voice 200010 voip
preference 2
voice-class codec 1
session target ipv4:10.0.100.12
dial-peer voice 100 pots
preference 1
destination-pattern .T
port 4
Call attempts, to a 10 digit # and to 9,911
Ball#debug voip dialpeer
voip dialpeer default debugging is on
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#debug h225 q931
H.225 Q931 IE Details debugging is on
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#term mon
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
  Q931 Message IE Decodes
Protocol Discriminator : 0x08
CRV Length             : 2
CRV Value              : 0x012C
Message Type           : 0x05: SETUP
Bearer Capability: Length Of IE=3
Data 8090A2
Calling Party Number: Length Of IE=12
Data 008133313836343131353432
Called Party Number: Length Of IE=4
Data 80393131
User-User: Length Of IE=188
Data 0520B0060008914A000501401F00420061006C006C00200052006500630065007000740069006F006E0020                                            002D002000340033003000300000000000000000000000000000000000000000000022C0B50000120F436973636F                                            43616C6C4D616E61676572003100010100C44000229CAF3D6621302C01B2020A04038200D50D800007000A00640D                                            06B8110000229CAF3D6621302C01B2020A040382010001000100010010A00100140140B50000120D820400200400                                            01030003000103
000131: *Feb 17 19:44:13.092 UTC: //-1/00229CAF2C01/DPM/dpAssociateIncomingPeerCore:
   Calling Number=3186411542, Called Number=911, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
000132: *Feb 17 19:44:13.092 UTC: //-1/00229CAF2C01/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
000133: *Feb 17 19:44:13.092 UTC: //-1/00229CAF2C01/DPM/dpAssociateIncomingPeerCore:
000134: *Feb 17 19:44:13.092 UTC: //-1/00229CAF2C01/DPM/dpAssociateIncomingPeerCore:
000135: *Feb 17 19:44:13.096 UTC: //-1/00229CAF2C01/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=911, Peer Info Type=DIALPEER_INFO_SPEECH
000136: *Feb 17 19:44:13.096 UTC: //-1/00229CAF2C01/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=911
000137: *Feb 17 19:44:13.096 UTC: //-1/00229CAF2C01/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
000138: *Feb 17 19:44:13.096 UTC: //-1/00229CAF2C01/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=100
000139: *Feb 17 19:44:13.096 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=911, Called Number=911, Peer Info Type=DIALPEER_INFO_SPEECH
000140: *Feb 17 19:44:13.096 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000141: *Feb 17 19:44:13.096 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000142: *Feb 17 19:44:13.096 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
000143: *Feb 17 19:44:13.096 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000144: *Feb 17 19:44:13.096 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000145: *Feb 17 19:44:13.096 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000146: *Feb 17 19:44:13.096 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
000147: *Feb 17 19:44:13.096 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=911, Called Number=, Voice-Interface=0x0,
000148: *Feb 17 19:44:13.096 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
000149: *Feb 17 19:44:13.096 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000150: *Feb 17 19:44:13.096 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000151: *Feb 17 19:44:13.096 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000152: *Feb 17 19:44:13.100 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
000153: *Feb 17 19:44:13.100 UTC: //-1/00229CAF2C01/DPM/dpMatchPeersCore:
000154: *Feb 17 19:44:13.100 UTC: //-1/00229CAF2C01/DPM/dpMatchPeersCore:
000155: *Feb 17 19:44:13.100 UTC: //-1/00229CAF2C01/DPM/dpMatchPeersCore:
000156: *Feb 17 19:44:13.100 UTC: //-1/00229CAF2C01/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
CRV Length             : 2
CRV Value              : 0x812C
Message Type           : 0x02: CALL_PROC
User-User: Length Of IE=57
Data 0521C0060008914A00042800B500001240013C05010000ADD9FC5634E5110C110000229CAF3D6621302C01                                            B2020A0403820100010010800100
CRV Length             : 2
CRV Value              : 0x812C
Message Type           : 0x5A: RELEASE_COMP
Cause: Length Of IE=2
Data 80A2
User-User: Length Of IE=34
Data 052580060008914A00041100110000229CAF3D6621302C01B2020A04038210800100
CRV Length             : 2
CRV Value              : 0x012D
Data 8090A2
Data 80393131
Data 0520B0060008914A000501401F00420061006C006C00200052006500630065007000740069006F006E0020                                            002D002000340033003000300000000000000000000000000000000000000000000022C0B50000120F436973636F                                            43616C6C4D616E61676572003100010100C4400030C3B6496621302D01B3020A04038200D50D800007000A00640D                                            06B811000030C3B6496621302D01B3020A040382010001000100010010A00100140140B50000120D820400200400                                            01030003000103
000157: *Feb 17 19:44:25.124 UTC: //-1/0030C3B62D01/DPM/dpAssociateIncomingPeerCore:
000158: *Feb 17 19:44:25.124 UTC: //-1/0030C3B62D01/DPM/dpAssociateIncomingPeerCore:
000159: *Feb 17 19:44:25.124 UTC: //-1/0030C3B62D01/DPM/dpAssociateIncomingPeerCore:
000160: *Feb 17 19:44:25.124 UTC: //-1/0030C3B62D01/DPM/dpAssociateIncomingPeerCore:
000161: *Feb 17 19:44:25.128 UTC: //-1/0030C3B62D01/DPM/dpMatchPeersCore:
000162: *Feb 17 19:44:25.128 UTC: //-1/0030C3B62D01/DPM/dpMatchPeersCore:
000163: *Feb 17 19:44:25.128 UTC: //-1/0030C3B62D01/DPM/dpMatchPeersCore:
000164: *Feb 17 19:44:25.128 UTC: //-1/0030C3B62D01/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
000165: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000166: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000167: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000168: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
000169: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000170: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000171: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000172: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
000173: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
000174: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
000175: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000176: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000177: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000178: *Feb 17 19:44:25.128 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
000179: *Feb 17 19:44:25.128 UTC: //-1/0030C3B62D01/DPM/dpMatchPeersCore:
000180: *Feb 17 19:44:25.128 UTC: //-1/0030C3B62D01/DPM/dpMatchPeersCore:
000181: *Feb 17 19:44:25.128 UTC: //-1/0030C3B62D01/DPM/dpMatchPeersCore:
000182: *Feb 17 19:44:25.128 UTC: //-1/0030C3B62D01/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
CRV Length             : 2
CRV Value              : 0x812D
Data 0521C0060008914A00042800B500001240013C05010000ADD9FC56B2EA110C11000030C3B6496621302D01                                            B3020A0403820100010010800100
CRV Length             : 2
CRV Value              : 0x812D
Data 80A2
Data 052580060008914A0004110011000030C3B6496621302D01B3020A04038210800100
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
CRV Length             : 2
CRV Value              : 0x012E
Data 8090A2
Calling Party Number: Length Of IE=6
Data 008134333030
Called Party Number: Length Of IE=12
Data 803133313838343036363337
User-User: Length Of IE=192
Data 0520B0060008914A000501401F00420061006C006C00200052006500630065007000740069006F006E0020002D002000340033003000300000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E61676572003100010500464BB73996A0004955D9836621302E01B4020A04038200D50D800007000A00640D06B81100004955D9836621302E01B4020A040382010001000100010010A00100140140B50000120D82040020040001030003000103
000183: *Feb 17 19:45:23.436 UTC: //-1/004955D92E01/DPM/dpAssociateIncomingPeerCore:
   Calling Number=4300, Called Number=13188406637, Voice-Interface=0x0,
000184: *Feb 17 19:45:23.436 UTC: //-1/004955D92E01/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=201010
000185: *Feb 17 19:45:23.436 UTC: //-1/004955D92E01/DPM/dpAssociateIncomingPeerCore:
000186: *Feb 17 19:45:23.436 UTC: //-1/004955D92E01/DPM/dpAssociateIncomingPeerCore:
000187: *Feb 17 19:45:23.440 UTC: //-1/004955D92E01/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=13188406637, Peer Info Type=DIALPEER_INFO_SPEECH
000188: *Feb 17 19:45:23.440 UTC: //-1/004955D92E01/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=13188406637
000189: *Feb 17 19:45:23.440 UTC: //-1/004955D92E01/DPM/dpMatchPeersCore:
000190: *Feb 17 19:45:23.440 UTC: //-1/004955D92E01/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
000191: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=13188406637, Called Number=13188406637, Peer Info Type=DIALPEER_INFO_SPEECH
000192: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000193: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000194: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
000195: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000196: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000197: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000198: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
000199: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=13188406637, Called Number=, Voice-Interface=0x0,
000200: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
000201: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000202: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000203: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
000204: *Feb 17 19:45:23.440 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
000205: *Feb 17 19:45:23.440 UTC: //-1/004955D92E01/DPM/dpMatchPeersCore:
000206: *Feb 17 19:45:23.440 UTC: //-1/004955D92E01/DPM/dpMatchPeersCore:
000207: *Feb 17 19:45:23.440 UTC: //-1/004955D92E01/DPM/dpMatchPeersCore:
000208: *Feb 17 19:45:23.440 UTC: //-1/004955D92E01/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
CRV Length             : 2
CRV Value              : 0x812E
Data 0521C0060008914A00042800B500001240013C05010000ADD9FC56E28E110C1100004955D9836621302E01B4020A0403820100010010800100
CRV Length             : 2
CRV Value              : 0x812E
Data 80A2
Data 052580060008914A000411001100004955D9836621302E01B4020A04038210800100
Ball#
Ball#
Ball#
Ball#
CRV Length             : 2
CRV Value              : 0x012F
Data 8090A2
Data 80393131
Data 0520B0060008914A000501401F00420061006C006C00200052006500630065007000740069006F006E0020002D002000340033003000300000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E61676572003100010100C440801C31FF266F21302F01BF020A04038200D50D800007000A00640D06B81100801C31FF266F21302F01BF020A040382010001000100010010A00100140140B50000120D82040020040001030003000103
000244: *Feb 17 20:22:14.148 UTC: //-1/801C31FF2F01/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Ball Reception - 4300
   ----- ccCallInfo IE subfields -----
   cisco-ani=3186411542
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
000245: *Feb 17 20:22:14.148 UTC: //-1/801C31FF2F01/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x867581A8, Call Info(
   Calling Number=3186411542,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=911(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=725
000246: *Feb 17 20:22:14.148 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000247: *Feb 17 20:22:14.148 UTC: :cc_get_feature_vsa malloc success
000248: *Feb 17 20:22:14.148 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000249: *Feb 17 20:22:14.148 UTC:  cc_get_feature_vsa count is 1
000250: *Feb 17 20:22:14.148 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000251: *Feb 17 20:22:14.148 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:2275987968,feature_id:693
000252: *Feb 17 20:22:14.148 UTC: //725/801C31FF2F01/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=3186411542(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=911(TON=Unknown, NPI=Unknown))
000253: *Feb 17 20:22:14.148 UTC: //725/801C31FF2F01/CCAPI/cc_process_call_setup_ind:
   Event=0x86DCD638
000254: *Feb 17 20:22:14.148 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 911
000255: *Feb 17 20:22:14.152 UTC: //725/801C31FF2F01/CCAPI/ccCallSetContext:
   Context=0x8634FFF4
000256: *Feb 17 20:22:14.152 UTC: //725/801C31FF2F01/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 725 with tag 0 to app "_ManagedAppProcess_Default"
000257: *Feb 17 20:22:14.152 UTC: //725/801C31FF2F01/CCAPI/ccCallProceeding:
000258: *Feb 17 20:22:14.152 UTC: //725/801C31FF2F01/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=100, Params=0x8634F184, Progress Indication=NULL(0)
000259: *Feb 17 20:22:14.152 UTC: //725/801C31FF2F01/CCAPI/ccCheckClipClir:
   In: Calling Number=3186411542(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
000260: *Feb 17 20:22:14.152 UTC: //725/801C31FF2F01/CCAPI/ccCheckClipClir:
   Out: Calling Number=3186411542(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
000261: *Feb 17 20:22:14.152 UTC: //725/801C31FF2F01/CCAPI/ccCallSetupRequest:
   Destination Pattern=.T, Called Number=911, Digit Strip=TRUE
000262: *Feb 17 20:22:14.152 UTC: //725/801C31FF2F01/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=Ball Reception - 4300, Final Destination Flag=TRUE,
   Guid=801C31FF-266F-2130-2F01-BF020A040382, Outgoing Dial-peer=100
000263: *Feb 17 20:22:14.152 UTC: //725/801C31FF2F01/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
000264: *Feb 17 20:22:14.152 UTC: //725/801C31FF2F01/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x86E100A0, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=3186411542,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=911(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=100, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
000265: *Feb 17 20:22:14.152 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000266: *Feb 17 20:22:14.152 UTC: :cc_get_feature_vsa malloc success
000267: *Feb 17 20:22:14.152 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000268: *Feb 17 20:22:14.152 UTC:  cc_get_feature_vsa count is 2
000269: *Feb 17 20:22:14.152 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000270: *Feb 17 20:22:14.152 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:2275987744,feature_id:694
000271: *Feb 17 20:22:14.156 UTC: //726/801C31FF2F01/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
000272: *Feb 17 20:22:14.156 UTC: //726/801C31FF2F01/CCAPI/ccCallSetContext:
   Context=0x8634F134
000273: *Feb 17 20:22:14.156 UTC: //725/801C31FF2F01/CCAPI/ccSaveDialpeerTag:
CRV Length             : 2
CRV Value              : 0x812F
Data 0521C0060008914A00042800B500001240013C05010000ADD9FC56BD32110C1100801C31FF266F21302F01BF020A0403820100010010800100
000274: *Feb 17 20:22:14.156 UTC: //726/801C31FF2F01/CCAPI/cc_api_call_proceeding:
   Interface=0x86E100A0, Progress Indication=NULL(0)
000275: *Feb 17 20:22:15.408 UTC: //726/801C31FF2F01/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x86E100A0, Call Id=726
000276: *Feb 17 20:22:15.408 UTC: //726/801C31FF2F01/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
000277: *Feb 17 20:22:15.408 UTC: //725/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
000278: *Feb 17 20:22:15.408 UTC: //726/801C31FF2F01/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=726
000279: *Feb 17 20:22:15.408 UTC: //726/801C31FF2F01/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
000280: *Feb 17 20:22:15.408 UTC: //726/801C31FF2F01/CCAPI/ccCallDisconnect:
   Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
000281: *Feb 17 20:22:15.412 UTC: //726/801C31FF2F01/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x86E100A0, Tag=0x0, Call Id=726,
   Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
000282: *Feb 17 20:22:15.412 UTC: //726/801C31FF2F01/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
000283: *Feb 17 20:22:15.412 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000284: *Feb 17 20:22:15.412 UTC: :cc_free_feature_vsa freeing 87A8D118
000285: *Feb 17 20:22:15.412 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000286: *Feb 17 20:22:15.412 UTC:  vsacount in free is 1
000287: *Feb 17 20:22:15.412 UTC: //725/801C31FF2F01/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
000288: *Feb 17 20:22:15.412 UTC: //725/801C31FF2F01/CCAPI/ccCallDisconnect:
000289: *Feb 17 20:22:15.412 UTC: //725/801C31FF2F01/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
CRV Length             : 2
CRV Value              : 0x812F
Data 80A2
Data 052580060008914A000411001100801C31FF266F21302F01BF020A04038210800100
000290: *Feb 17 20:22:15.416 UTC: //725/801C31FF2F01/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x867581A8, Tag=0x0, Call Id=725,
000291: *Feb 17 20:22:15.416 UTC: //725/801C31FF2F01/CCAPI/cc_api_call_disconnect_done:
000292: *Feb 17 20:22:15.416 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000293: *Feb 17 20:22:15.416 UTC: :cc_free_feature_vsa freeing 87A8D1F8
000294: *Feb 17 20:22:15.416 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000295: *Feb 17 20:22:15.416 UTC:  vsacount in free is 0
Can you have a look at post
https://supportforums.cisco.com/thread/2213848
Suffering from the same isue as you.
Looks to be a cabling/Service provider issue.
I cant understand why your other call works when the voice port is reporting "fxols_power_denial_detected"
because this means it is not seeing the correct voltage on the telephone line.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
19 Replies 19
acampbell
This looks to be due digit stripping on
your dial peer 100.
preference 1
port 4
You have .T as your patern
Looking at you long dialled number 13188406637
that is 11 digits so the first digit (1) is being dropped
resulting in 10 digits to line 3188406637
When we look at the 911 call only 11 will be sent to line
This will be an incomplete number for the service provider
In my opinion as 911 is so important you should build
a dial peer just for the emergency service.
dial-peer voice 911 pots
description *** EMERGENCY SERVICE ***
preference 1
incoming called-number .
destination-pattern 911
no digit-strip
port 4
If you are actually sending 9911 to the gateway
then use this instead
preference 1
destination-pattern 9911
forward-digits 3
port 4
Alex.
Will try this as soon as they are in the office, thanks ALEX.
Alex,
Seems the calls are not hitting the 911 dial-peer, they are still hitting dial-peer 100 according to the debugs.
User is dialing 9911 from an IP phone.
preference 1
port 4
preference 1
destination-pattern 9.911
port 4
FAST BUSY
006003: *Feb 18 14:42:53.012 UTC: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 0 Event 0x1
006004: *Feb 18 14:42:53.016 UTC: //-1/xxxxxxxxxxxx/H323/cch323_get_new_ccb: ccb (0x87BF6B7C) is in use
006005: *Feb 18 14:42:53.016 UTC: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
006006: *Feb 18 14:42:53.016 UTC: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x87A9F0AC, len=221, msgPtr=0x87ABA6D0
006007: *Feb 18 14:42:53.016 UTC: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.225
CRV Length             : 2
CRV Value              : 0x0135
Data 8090A2
Data 80393131
Data 0520B0060008914A000501401F00420061006C006C00200052006500630065007000740069006F006E0020002D002000340033003000300000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E61676572003100010100C44000FFB1C21F7131303501FF020A04038200D50D800007000A00640D06B8110000FFB1C21F7131303501FF020A040382010001000100010010A00100140140B50000120D82040020040001030003000103
006008: *Feb 18 14:42:53.020 UTC: //-1/xxxxxxxxxxxx/H323/cch323_extract_signaled_carriers: Entry
006009: *Feb 18 14:42:53.020 UTC: //943/00FFB1C23501/H323/cch323_determine_source_ip_group_info: No Source IP group match with Src CarrierId/Zone ID
006010: *Feb 18 14:42:53.020 UTC: //943/00FFB1C23501/H323/cch323_determine_source_ip_group_info: No Source IP group matched with rte id/zone_id/acl
006011: *Feb 18 14:42:53.020 UTC: //-1/xxxxxxxxxxxx/H323/cch323_determine_source_group: Entry
006012: *Feb 18 14:42:53.020 UTC: //943/00FFB1C23501/H323/cch323_determine_source_ip_group_info: No Source IP group match with Incoming Called Number
006013: *Feb 18 14:42:53.020 UTC: //-1/xxxxxxxxxxxx/H323/cch323_determine_source_group: Entry
006014: *Feb 18 14:42:53.020 UTC: //943/00FFB1C23501/H323/cch323_determine_source_ip_group_info: No Source IP group match with Destination pattern
006015: *Feb 18 14:42:53.020 UTC: //-1/00FFB1C23501/DPM/dpAssociateIncomingPeerCore:
006016: *Feb 18 14:42:53.020 UTC: //-1/00FFB1C23501/DPM/dpAssociateIncomingPeerCore:
006017: *Feb 18 14:42:53.020 UTC: //-1/xxxxxxxxxxxx/H323/cch323_associate_incoming_peer: timeout = 1, reason = -1
006018: *Feb 18 14:42:53.020 UTC: //943/00FFB1C23501/H323/common_idle_setupInd_hdlr: ccb ccm bits = system[0x0028]
006019: *Feb 18 14:42:53.020 UTC: //-1/00FFB1C23501/DPM/dpAssociateIncomingPeerCore:
006020: *Feb 18 14:42:53.020 UTC: //-1/00FFB1C23501/DPM/dpAssociateIncomingPeerCore:
006021: *Feb 18 14:42:53.020 UTC: //-1/xxxxxxxxxxxx/H323/cch323_associate_incoming_peer: timeout = 1, reason = -1
006022: *Feb 18 14:42:53.020 UTC: //943/00FFB1C23501/H323/h323_gw_setup_ind: is_overlap = 0, info_complete = 0
006023: *Feb 18 14:42:53.020 UTC: //-1/00FFB1C23501/CCAPI/cc_api_display_ie_subfields:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
006024: *Feb 18 14:42:53.020 UTC: //-1/00FFB1C23501/CCAPI/cc_api_call_setup_ind_common:
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=943
006025: *Feb 18 14:42:53.020 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006026: *Feb 18 14:42:53.020 UTC: :cc_get_feature_vsa malloc success
006027: *Feb 18 14:42:53.020 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006028: *Feb 18 14:42:53.020 UTC:  cc_get_feature_vsa count is 1
006029: *Feb 18 14:42:53.020 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006030: *Feb 18 14:42:53.020 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:2270469880,feature_id:906
006031: *Feb 18 14:42:53.020 UTC: //943/00FFB1C23501/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
006032: *Feb 18 14:42:53.020 UTC: //-1/xxxxxxxxxxxx/H323/cch323_create_call_info_type_container:
cch323_create_call_info_type_container: creating callInfoType container for callID = 943
006033: *Feb 18 14:42:53.020 UTC: //943/00FFB1C23501/H323/cch323_update_carriers_in_call_info: tg_label_flag 0x0
006034: *Feb 18 14:42:53.020 UTC: //943/00FFB1C23501/CCAPI/cc_process_call_setup_ind:
   Event=0x86DCD638
006035: *Feb 18 14:42:53.020 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
006036: *Feb 18 14:42:53.024 UTC: //943/00FFB1C23501/CCAPI/ccCallSetContext:
   Context=0x8634C4F4
006037: *Feb 18 14:42:53.024 UTC: //943/00FFB1C23501/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 943 with tag 0 to app "_ManagedAppProcess_Default"
006038: *Feb 18 14:42:53.024 UTC: //943/00FFB1C23501/CCAPI/ccCallProceeding:
006039: *Feb 18 14:42:53.024 UTC: //-1/00FFB1C23501/DPM/dpMatchPeersCore:
006040: *Feb 18 14:42:53.024 UTC: //-1/00FFB1C23501/DPM/dpMatchPeersCore:
006041: *Feb 18 14:42:53.024 UTC: //-1/00FFB1C23501/DPM/dpMatchPeersCore:
006042: *Feb 18 14:42:53.024 UTC: //-1/00FFB1C23501/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006043: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006044: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006045: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006046: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006047: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006048: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006049: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006050: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006051: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006052: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006053: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006054: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006055: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006056: *Feb 18 14:42:53.024 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006057: *Feb 18 14:42:53.024 UTC: //-1/00FFB1C23501/DPM/dpMatchPeersCore:
006058: *Feb 18 14:42:53.024 UTC: //-1/00FFB1C23501/DPM/dpMatchPeersCore:
006059: *Feb 18 14:42:53.024 UTC: //-1/00FFB1C23501/DPM/dpMatchPeersCore:
006060: *Feb 18 14:42:53.024 UTC: //-1/00FFB1C23501/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006061: *Feb 18 14:42:53.024 UTC: //943/00FFB1C23501/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=100, Params=0x8634E2C4, Progress Indication=NULL(0)
006062: *Feb 18 14:42:53.028 UTC: //943/00FFB1C23501/CCAPI/ccCheckClipClir:
006063: *Feb 18 14:42:53.028 UTC: //943/00FFB1C23501/CCAPI/ccCheckClipClir:
006064: *Feb 18 14:42:53.028 UTC: //943/00FFB1C23501/CCAPI/ccCallSetupRequest:
006065: *Feb 18 14:42:53.028 UTC: //943/00FFB1C23501/CCAPI/ccCallSetupRequest:
   Guid=00FFB1C2-1F71-3130-3501-FF020A040382, Outgoing Dial-peer=100
006066: *Feb 18 14:42:53.028 UTC: //943/00FFB1C23501/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
006067: *Feb 18 14:42:53.028 UTC: //943/00FFB1C23501/CCAPI/ccIFCallSetupRequestPrivate:
006068: *Feb 18 14:42:53.028 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006069: *Feb 18 14:42:53.028 UTC: :cc_get_feature_vsa malloc success
006070: *Feb 18 14:42:53.028 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006071: *Feb 18 14:42:53.028 UTC:  cc_get_feature_vsa count is 2
006072: *Feb 18 14:42:53.028 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006073: *Feb 18 14:42:53.028 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:2270469656,feature_id:907
006074: *Feb 18 14:42:53.028 UTC: //944/00FFB1C23501/CCAPI/ccIFCallSetupRequestPrivate:
006075: *Feb 18 14:42:53.028 UTC: //944/00FFB1C23501/CCAPI/ccCallSetContext:
   Context=0x8634E274
006076: *Feb 18 14:42:53.028 UTC: //943/00FFB1C23501/CCAPI/ccSaveDialpeerTag:
006077: *Feb 18 14:42:53.028 UTC: //943/00FFB1C23501/H323/cch323_do_set_dialpeer_tag: gw_id=1
006078: *Feb 18 14:42:53.028 UTC: //944/00FFB1C23501/CCAPI/cc_api_call_proceeding:
006079: *Feb 18 14:42:53.028 UTC: //943/00FFB1C23501/H323/cch323_do_call_proceeding: gw_id=1
006080: *Feb 18 14:42:53.032 UTC: //943/00FFB1C23501/H323/cch323_do_call_proceeding: gw_id=1
CRV Length             : 2
CRV Value              : 0x8135
Data 0521C0060008914A00042800B500001240013C05010000ADD9FC56F832110C110000FFB1C21F7131303501FF020A0403820100010010800100
006081: *Feb 18 14:42:54.280 UTC: //944/00FFB1C23501/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x86E100A0, Call Id=944
006082: *Feb 18 14:42:54.280 UTC: //944/00FFB1C23501/CCAPI/cc_api_call_disconnected:
006083: *Feb 18 14:42:54.280 UTC: //943/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
006084: *Feb 18 14:42:54.280 UTC: //944/00FFB1C23501/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=944
006085: *Feb 18 14:42:54.280 UTC: //944/00FFB1C23501/CCAPI/ccCallDisconnect:
006086: *Feb 18 14:42:54.280 UTC: //944/00FFB1C23501/CCAPI/ccCallDisconnect:
006087: *Feb 18 14:42:54.284 UTC: //944/00FFB1C23501/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x86E100A0, Tag=0x0, Call Id=944,
006088: *Feb 18 14:42:54.284 UTC: //944/00FFB1C23501/CCAPI/cc_api_call_disconnect_done:
006089: *Feb 18 14:42:54.284 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006090: *Feb 18 14:42:54.284 UTC: :cc_free_feature_vsa freeing 87549E10
006091: *Feb 18 14:42:54.284 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006092: *Feb 18 14:42:54.284 UTC:  vsacount in free is 1
006093: *Feb 18 14:42:54.284 UTC: //-1/xxxxxxxxxxxx/H323/cch323_post_call_statistics: callID=943
006094: *Feb 18 14:42:54.284 UTC: //943/00FFB1C23501/CCAPI/ccCallDisconnect:
006095: *Feb 18 14:42:54.284 UTC: //943/00FFB1C23501/CCAPI/ccCallDisconnect:
006096: *Feb 18 14:42:54.284 UTC: //943/00FFB1C23501/CCAPI/cc_api_get_transfer_info:
006097: *Feb 18 14:42:54.284 UTC: //943/00FFB1C23501/H323/cch323_do_call_disconnect: gw_id=1, discCause=34
006098: *Feb 18 14:42:54.284 UTC: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x9 internal event to H225 SM
CRV Length             : 2
CRV Value              : 0x8135
Data 80A2
Data 052580060008914A00041100110000FFB1C21F7131303501FF020A04038210800100
006099: *Feb 18 14:42:54.284 UTC: //943/00FFB1C23501/H323/cch323_call_generic_cleanup: Disconnected flag 1
006100: *Feb 18 14:42:54.284 UTC: //943/00FFB1C23501/H323/cch323_store_call_history_entry: Call Active Playout Mode: 0,Init 0, Min 0, Max 0, Fax 0
006101: *Feb 18 14:42:54.284 UTC: //943/00FFB1C23501/H323/cch323_store_call_history_entry: Call History Playout Mode: 0,Init 0, Min 0, Max 0, Fax 0
006102: *Feb 18 14:42:54.288 UTC: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 2
006103: *Feb 18 14:42:54.288 UTC: //-1/xxxxxxxxxxxx/H323/cch323_cleanup_xport: hashDestroy for TcpFDTbl
006104: *Feb 18 14:42:54.288 UTC: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 3
006105: *Feb 18 14:42:54.288 UTC: //943/00FFB1C23501/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x867581A8, Tag=0x0, Call Id=943,
006106: *Feb 18 14:42:54.288 UTC: //943/00FFB1C23501/CCAPI/cc_api_call_disconnect_done:
006107: *Feb 18 14:42:54.288 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006108: *Feb 18 14:42:54.288 UTC: :cc_free_feature_vsa freeing 87549EF0
006109: *Feb 18 14:42:54.288 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006110: *Feb 18 14:42:54.288 UTC:  vsacount in free is 0
006111: *Feb 18 14:42:54.288 UTC: //-1/xxxxxxxxxxxx/H323/cch323_call_generic_cleanup: Freeing ccb (0x87BF6B7C)
NEW CONFIG
FAST BUSY
preference 1
port 4
preference 1
port 4
forward-digits 3
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 101 in
login local
length 0
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
006114: *Feb 18 14:54:59.287 UTC: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 0 Event 0x1
006115: *Feb 18 14:54:59.287 UTC: //-1/xxxxxxxxxxxx/H323/cch323_get_new_ccb: ccb (0x87BF6B7C) is in use
006116: *Feb 18 14:54:59.291 UTC: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
006117: *Feb 18 14:54:59.291 UTC: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x87A9EDF4, len=221, msgPtr=0x86695D1C
006118: *Feb 18 14:54:59.291 UTC: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.225
CRV Length             : 2
CRV Value              : 0x0136
Data 8090A2
Data 80393131
Data 0520B0060008914A000501401F00420061006C006C00200052006500630065007000740069006F006E0020002D002000340033003000300000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E61676572003100010100C44000CE6C73F5733130360101020A04038200D50D800007000A00640D06B8110000CE6C73F5733130360101020A040382010001000100010010A00100140140B50000120D82040020040001030003000103
006119: *Feb 18 14:54:59.291 UTC: //-1/xxxxxxxxxxxx/H323/cch323_extract_signaled_carriers: Entry
006120: *Feb 18 14:54:59.291 UTC: //945/00CE6C733601/H323/cch323_determine_source_ip_group_info: No Source IP group match with Src CarrierId/Zone ID
006121: *Feb 18 14:54:59.291 UTC: //945/00CE6C733601/H323/cch323_determine_source_ip_group_info: No Source IP group matched with rte id/zone_id/acl
006122: *Feb 18 14:54:59.291 UTC: //-1/xxxxxxxxxxxx/H323/cch323_determine_source_group: Entry
006123: *Feb 18 14:54:59.291 UTC: //945/00CE6C733601/H323/cch323_determine_source_ip_group_info: No Source IP group match with Incoming Called Number
006124: *Feb 18 14:54:59.291 UTC: //-1/xxxxxxxxxxxx/H323/cch323_determine_source_group: Entry
006125: *Feb 18 14:54:59.291 UTC: //945/00CE6C733601/H323/cch323_determine_source_ip_group_info: No Source IP group match with Destination pattern
006126: *Feb 18 14:54:59.291 UTC: //-1/00CE6C733601/DPM/dpAssociateIncomingPeerCore:
006127: *Feb 18 14:54:59.291 UTC: //-1/00CE6C733601/DPM/dpAssociateIncomingPeerCore:
006128: *Feb 18 14:54:59.291 UTC: //-1/xxxxxxxxxxxx/H323/cch323_associate_incoming_peer: timeout = 1, reason = -1
006129: *Feb 18 14:54:59.291 UTC: //945/00CE6C733601/H323/common_idle_setupInd_hdlr: ccb ccm bits = system[0x0028]
006130: *Feb 18 14:54:59.291 UTC: //-1/00CE6C733601/DPM/dpAssociateIncomingPeerCore:
006131: *Feb 18 14:54:59.291 UTC: //-1/00CE6C733601/DPM/dpAssociateIncomingPeerCore:
006132: *Feb 18 14:54:59.291 UTC: //-1/xxxxxxxxxxxx/H323/cch323_associate_incoming_peer: timeout = 1, reason = -1
006133: *Feb 18 14:54:59.291 UTC: //945/00CE6C733601/H323/h323_gw_setup_ind: is_overlap = 0, info_complete = 0
006134: *Feb 18 14:54:59.291 UTC: //-1/00CE6C733601/CCAPI/cc_api_display_ie_subfields:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
006135: *Feb 18 14:54:59.295 UTC: //-1/00CE6C733601/CCAPI/cc_api_call_setup_ind_common:
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=945
006136: *Feb 18 14:54:59.295 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006137: *Feb 18 14:54:59.295 UTC: :cc_get_feature_vsa malloc success
006138: *Feb 18 14:54:59.295 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006139: *Feb 18 14:54:59.295 UTC:  cc_get_feature_vsa count is 1
006140: *Feb 18 14:54:59.295 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006141: *Feb 18 14:54:59.295 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:2275987968,feature_id:908
006142: *Feb 18 14:54:59.295 UTC: //945/00CE6C733601/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
006143: *Feb 18 14:54:59.295 UTC: //-1/xxxxxxxxxxxx/H323/cch323_create_call_info_type_container:
cch323_create_call_info_type_container: creating callInfoType container for callID = 945
006144: *Feb 18 14:54:59.295 UTC: //945/00CE6C733601/H323/cch323_update_carriers_in_call_info: tg_label_flag 0x0
006145: *Feb 18 14:54:59.295 UTC: //945/00CE6C733601/CCAPI/cc_process_call_setup_ind:
   Event=0x86DCD638
006146: *Feb 18 14:54:59.295 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
006147: *Feb 18 14:54:59.295 UTC: //945/00CE6C733601/CCAPI/ccCallSetContext:
   Context=0x8634B634
006148: *Feb 18 14:54:59.295 UTC: //945/00CE6C733601/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 945 with tag 0 to app "_ManagedAppProcess_Default"
006149: *Feb 18 14:54:59.299 UTC: //945/00CE6C733601/CCAPI/ccCallProceeding:
006150: *Feb 18 14:54:59.299 UTC: //-1/00CE6C733601/DPM/dpMatchPeersCore:
006151: *Feb 18 14:54:59.299 UTC: //-1/00CE6C733601/DPM/dpMatchPeersCore:
006152: *Feb 18 14:54:59.299 UTC: //-1/00CE6C733601/DPM/dpMatchPeersCore:
006153: *Feb 18 14:54:59.299 UTC: //-1/00CE6C733601/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006154: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006155: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006156: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006157: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006158: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006159: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006160: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006161: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006162: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006163: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006164: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006165: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006166: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006167: *Feb 18 14:54:59.299 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006168: *Feb 18 14:54:59.299 UTC: //-1/00CE6C733601/DPM/dpMatchPeersCore:
006169: *Feb 18 14:54:59.299 UTC: //-1/00CE6C733601/DPM/dpMatchPeersCore:
006170: *Feb 18 14:54:59.299 UTC: //-1/00CE6C733601/DPM/dpMatchPeersCore:
006171: *Feb 18 14:54:59.299 UTC: //-1/00CE6C733601/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006172: *Feb 18 14:54:59.299 UTC: //945/00CE6C733601/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=100, Params=0x8634A7C4, Progress Indication=NULL(0)
006173: *Feb 18 14:54:59.299 UTC: //945/00CE6C733601/CCAPI/ccCheckClipClir:
006174: *Feb 18 14:54:59.299 UTC: //945/00CE6C733601/CCAPI/ccCheckClipClir:
006175: *Feb 18 14:54:59.303 UTC: //945/00CE6C733601/CCAPI/ccCallSetupRequest:
006176: *Feb 18 14:54:59.303 UTC: //945/00CE6C733601/CCAPI/ccCallSetupRequest:
   Guid=00CE6C73-F573-3130-3601-01020A040382, Outgoing Dial-peer=100
006177: *Feb 18 14:54:59.303 UTC: //945/00CE6C733601/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
006178: *Feb 18 14:54:59.303 UTC: //945/00CE6C733601/CCAPI/ccIFCallSetupRequestPrivate:
006179: *Feb 18 14:54:59.303 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006180: *Feb 18 14:54:59.303 UTC: :cc_get_feature_vsa malloc success
006181: *Feb 18 14:54:59.303 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006182: *Feb 18 14:54:59.303 UTC:  cc_get_feature_vsa count is 2
006183: *Feb 18 14:54:59.303 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006184: *Feb 18 14:54:59.303 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:2275987744,feature_id:909
006185: *Feb 18 14:54:59.303 UTC: //946/00CE6C733601/CCAPI/ccIFCallSetupRequestPrivate:
006186: *Feb 18 14:54:59.303 UTC: //946/00CE6C733601/CCAPI/ccCallSetContext:
   Context=0x8634A774
006187: *Feb 18 14:54:59.303 UTC: //945/00CE6C733601/CCAPI/ccSaveDialpeerTag:
006188: *Feb 18 14:54:59.303 UTC: //945/00CE6C733601/H323/cch323_do_set_dialpeer_tag: gw_id=1
006189: *Feb 18 14:54:59.303 UTC: //945/00CE6C733601/H323/cch323_do_call_proceeding: gw_id=1
006190: *Feb 18 14:54:59.303 UTC: //945/00CE6C733601/H323/cch323_do_call_proceeding: gw_id=1
CRV Length             : 2
CRV Value              : 0x8136
Data 0521C0060008914A00042800B500001240013C05010000ADD9FC56BECB110C110000CE6C73F5733130360101020A0403820100010010800100
006191: *Feb 18 14:54:59.307 UTC: //946/00CE6C733601/CCAPI/cc_api_call_proceeding:
006192: *Feb 18 14:55:00.559 UTC: //946/00CE6C733601/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x86E100A0, Call Id=946
006193: *Feb 18 14:55:00.559 UTC: //946/00CE6C733601/CCAPI/cc_api_call_disconnected:
006194: *Feb 18 14:55:00.559 UTC: //945/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
006195: *Feb 18 14:55:00.559 UTC: //946/00CE6C733601/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=946
006196: *Feb 18 14:55:00.559 UTC: //946/00CE6C733601/CCAPI/ccCallDisconnect:
006197: *Feb 18 14:55:00.559 UTC: //946/00CE6C733601/CCAPI/ccCallDisconnect:
006198: *Feb 18 14:55:00.563 UTC: //946/00CE6C733601/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x86E100A0, Tag=0x0, Call Id=946,
006199: *Feb 18 14:55:00.563 UTC: //946/00CE6C733601/CCAPI/cc_api_call_disconnect_done:
006200: *Feb 18 14:55:00.563 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006201: *Feb 18 14:55:00.563 UTC: :cc_free_feature_vsa freeing 87A8D118
006202: *Feb 18 14:55:00.563 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006203: *Feb 18 14:55:00.563 UTC:  vsacount in free is 1
006204: *Feb 18 14:55:00.563 UTC: //-1/xxxxxxxxxxxx/H323/cch323_post_call_statistics: callID=945
006205: *Feb 18 14:55:00.563 UTC: //945/00CE6C733601/CCAPI/ccCallDisconnect:
006206: *Feb 18 14:55:00.563 UTC: //945/00CE6C733601/CCAPI/ccCallDisconnect:
006207: *Feb 18 14:55:00.563 UTC: //945/00CE6C733601/CCAPI/cc_api_get_transfer_info:
006208: *Feb 18 14:55:00.563 UTC: //945/00CE6C733601/H323/cch323_do_call_disconnect: gw_id=1, discCause=34
006209: *Feb 18 14:55:00.563 UTC: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x9 internal event to H225 SM
CRV Length             : 2
CRV Value              : 0x8136
Data 80A2
Data 052580060008914A00041100110000CE6C73F5733130360101020A04038210800100
006210: *Feb 18 14:55:00.567 UTC: //945/00CE6C733601/H323/cch323_call_generic_cleanup: Disconnected flag 1
006211: *Feb 18 14:55:00.567 UTC: //945/00CE6C733601/H323/cch323_store_call_history_entry: Call Active Playout Mode: 0,Init 0, Min 0, Max 0, Fax 0
006212: *Feb 18 14:55:00.567 UTC: //945/00CE6C733601/H323/cch323_store_call_history_entry: Call History Playout Mode: 0,Init 0, Min 0, Max 0, Fax 0
006213: *Feb 18 14:55:00.567 UTC: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 2
006214: *Feb 18 14:55:00.567 UTC: //-1/xxxxxxxxxxxx/H323/cch323_cleanup_xport: hashDestroy for TcpFDTbl
006215: *Feb 18 14:55:00.567 UTC: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 3
006216: *Feb 18 14:55:00.567 UTC: //945/00CE6C733601/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x867581A8, Tag=0x0, Call Id=945,
006217: *Feb 18 14:55:00.567 UTC: //945/00CE6C733601/CCAPI/cc_api_call_disconnect_done:
006218: *Feb 18 14:55:00.567 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006219: *Feb 18 14:55:00.567 UTC: :cc_free_feature_vsa freeing 87A8D1F8
006220: *Feb 18 14:55:00.567 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006221: *Feb 18 14:55:00.567 UTC:  vsacount in free is 0
006222: *Feb 18 14:55:00.567 UTC: //-1/xxxxxxxxxxxx/H323/cch323_call_generic_cleanup: Freeing ccb (0x87BF6B7C)
Can you fix your dial peer
preference 1
port 4
Change this to 2 dial peers as below:-
no dial-peer voice 9911 pots
preference 1
forward-digits 3
port 4
preference 1
forward-digits 3
port 4
Alex.
Alex, same, but seems to be hitting the correct dial-peer now...
also not sure if this is normal operation:
     1: Dial-peer Tag=911
     2: Dial-peer Tag=100
006664: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
why does it say calling and called is 911???
Ball#sh run | b dial-peer
preference 1
voice-class codec 1
preference 2
voice-class codec 1
preference 1
port 4
preference 1
port 4
forward-digits 3
preference 1
port 4
forward-digits 3
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 101 in
login local
length 0
end
Ball#
Ball#
Ball#
Ball#term mon
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
006620: *Feb 18 15:47:48.387 UTC: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 0 Event 0x1
006621: *Feb 18 15:47:48.387 UTC: //-1/xxxxxxxxxxxx/H323/cch323_get_new_ccb: ccb (0x87BF6B7C) is in use
006622: *Feb 18 15:47:48.387 UTC: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
006623: *Feb 18 15:47:48.387 UTC: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x87A9EF50, len=221, msgPtr=0x8772F388
006624: *Feb 18 15:47:48.387 UTC: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.225
CRV Length             : 2
CRV Value              : 0x0138
Data 8090A2
Data 80393131
Data 0520B0060008914A000501401F00420061006C006C00200052006500630065007000740069006F006E0020002D002000340033003000300000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E61676572003100010100C440006BE4D457803130380115020A04038200D50D800007000A00640D06B81100006BE4D457803130380115020A040382010001000100010010A00100140140B50000120D82040020040001030003000103
006625: *Feb 18 15:47:48.391 UTC: //-1/xxxxxxxxxxxx/H323/cch323_extract_signaled_carriers: Entry
006626: *Feb 18 15:47:48.391 UTC: //956/006BE4D43801/H323/cch323_determine_source_ip_group_info: No Source IP group match with Src CarrierId/Zone ID
006627: *Feb 18 15:47:48.391 UTC: //956/006BE4D43801/H323/cch323_determine_source_ip_group_info: No Source IP group matched with rte id/zone_id/acl
006628: *Feb 18 15:47:48.391 UTC: //-1/xxxxxxxxxxxx/H323/cch323_determine_source_group: Entry
006629: *Feb 18 15:47:48.391 UTC: //956/006BE4D43801/H323/cch323_determine_source_ip_group_info: No Source IP group match with Incoming Called Number
006630: *Feb 18 15:47:48.391 UTC: //-1/xxxxxxxxxxxx/H323/cch323_determine_source_group: Entry
006631: *Feb 18 15:47:48.391 UTC: //956/006BE4D43801/H323/cch323_determine_source_ip_group_info: No Source IP group match with Destination pattern
006632: *Feb 18 15:47:48.391 UTC: //-1/006BE4D43801/DPM/dpAssociateIncomingPeerCore:
   Calling Number=
3186411542
006633: *Feb 18 15:47:48.391 UTC: //-1/006BE4D43801/DPM/dpAssociateIncomingPeerCore:
006634: *Feb 18 15:47:48.391 UTC: //-1/xxxxxxxxxxxx/H323/cch323_associate_incoming_peer: timeout = 1, reason = -1
006635: *Feb 18 15:47:48.391 UTC: //956/006BE4D43801/H323/common_idle_setupInd_hdlr: ccb ccm bits = system[0x0028]
006636: *Feb 18 15:47:48.391 UTC: //-1/006BE4D43801/DPM/dpAssociateIncomingPeerCore:
   Calling Number=
3186411542
006637: *Feb 18 15:47:48.391 UTC: //-1/006BE4D43801/DPM/dpAssociateIncomingPeerCore:
006638: *Feb 18 15:47:48.391 UTC: //-1/xxxxxxxxxxxx/H323/cch323_associate_incoming_peer: timeout = 1, reason = -1
006639: *Feb 18 15:47:48.391 UTC: //956/006BE4D43801/H323/h323_gw_setup_ind: is_overlap = 0, info_complete = 0
006640: *Feb 18 15:47:48.391 UTC: //-1/006BE4D43801/CCAPI/cc_api_display_ie_subfields:
   cisco-ani=
3186411542
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
006641: *Feb 18 15:47:48.391 UTC: //-1/006BE4D43801/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=
3186411542
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=956
006642: *Feb 18 15:47:48.391 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006643: *Feb 18 15:47:48.391 UTC: :cc_get_feature_vsa malloc success
006644: *Feb 18 15:47:48.391 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006645: *Feb 18 15:47:48.391 UTC:  cc_get_feature_vsa count is 1
006646: *Feb 18 15:47:48.391 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006647: *Feb 18 15:47:48.391 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:
2272984256
,feature_id:919
006648: *Feb 18 15:47:48.391 UTC: //956/006BE4D43801/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
3186411542
006649: *Feb 18 15:47:48.391 UTC: //-1/xxxxxxxxxxxx/H323/cch323_create_call_info_type_container:
cch323_create_call_info_type_container: creating callInfoType container for callID = 956
006650: *Feb 18 15:47:48.395 UTC: //956/006BE4D43801/H323/cch323_update_carriers_in_call_info: tg_label_flag 0x0
006651: *Feb 18 15:47:48.395 UTC: //956/006BE4D43801/CCAPI/cc_process_call_setup_ind:
   Event=0x86DCD638
006652: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
006653: *Feb 18 15:47:48.395 UTC: //956/006BE4D43801/CCAPI/ccCallSetContext:
   Context=0x86350EB4
006654: *Feb 18 15:47:48.395 UTC: //956/006BE4D43801/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 956 with tag 0 to app "_ManagedAppProcess_Default"
006655: *Feb 18 15:47:48.395 UTC: //956/006BE4D43801/CCAPI/ccCallProceeding:
006656: *Feb 18 15:47:48.395 UTC: //-1/006BE4D43801/DPM/dpMatchPeersCore:
006657: *Feb 18 15:47:48.395 UTC: //-1/006BE4D43801/DPM/dpMatchPeersCore:
006658: *Feb 18 15:47:48.395 UTC: //-1/006BE4D43801/DPM/dpMatchPeersCore:
006659: *Feb 18 15:47:48.395 UTC: //-1/006BE4D43801/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
preference 1
voice-class codec 1
preference 2
voice-class codec 1
preference 1
port 4
preference 1
port 4
forward-digits 3
preference 1
port 4
forward-digits 3
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 101 in
login local
length 0
end
Ball#
Ball#
Ball#
Ball#term mon
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
CRV Length             : 2
CRV Value              : 0x0138
Data 8090A2
Data 80393131
   Calling Number=
3186411542
   Calling Number=
3186411542
   cisco-ani=
3186411542
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   Calling Number=
3186411542
2272984256
,feature_id:919
   Set Up Event Sent;
3186411542
   Event=0x86DCD638
   Context=0x86350EB4
   Result=SUCCESS(0)
006660: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006661: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006662: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006663: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006665: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006666: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006667: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006668: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006669: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006670: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006671: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006672: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006673: *Feb 18 15:47:48.395 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006674: *Feb 18 15:47:48.399 UTC: //-1/006BE4D43801/DPM/dpMatchPeersCore:
006675: *Feb 18 15:47:48.399 UTC: //-1/006BE4D43801/DPM/dpMatchPeersCore:
006676: *Feb 18 15:47:48.399 UTC: //-1/006BE4D43801/DPM/dpMatchPeersCore:
006677: *Feb 18 15:47:48.399 UTC: //-1/006BE4D43801/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006678: *Feb 18 15:47:48.399 UTC: //956/006BE4D43801/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=911, Params=0x86348A44, Progress Indication=NULL(0)
006679: *Feb 18 15:47:48.399 UTC: //956/006BE4D43801/CCAPI/ccCheckClipClir:
   In: Calling Number=
3186411542
006680: *Feb 18 15:47:48.399 UTC: //956/006BE4D43801/CCAPI/ccCheckClipClir:
3186411542
006681: *Feb 18 15:47:48.399 UTC: //956/006BE4D43801/CCAPI/ccCallSetupRequest:
   Destination Pattern=911, Called Number=911, Digit Strip=TRUE
006682: *Feb 18 15:47:48.399 UTC: //956/006BE4D43801/CCAPI/ccCallSetupRequest:
   Calling Number=
3186411542
   Guid=006BE4D4-5780-3130-3801-15020A040382, Outgoing Dial-peer=911
006683: *Feb 18 15:47:48.399 UTC: //956/006BE4D43801/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=
3186411542
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
006684: *Feb 18 15:47:48.399 UTC: //956/006BE4D43801/CCAPI/ccIFCallSetupRequestPrivate:
3186411542
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=911, Call Count On=FALSE,
006685: *Feb 18 15:47:48.399 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006686: *Feb 18 15:47:48.399 UTC: :cc_get_feature_vsa malloc success
006687: *Feb 18 15:47:48.399 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006688: *Feb 18 15:47:48.399 UTC:  cc_get_feature_vsa count is 2
006689: *Feb 18 15:47:48.399 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006690: *Feb 18 15:47:48.399 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:
2272984032
,feature_id:920
006691: *Feb 18 15:47:48.399 UTC: //957/006BE4D43801/CCAPI/ccIFCallSetupRequestPrivate:
006692: *Feb 18 15:47:48.399 UTC: //957/006BE4D43801/CCAPI/ccCallSetContext:
   Context=0x863489F4
006693: *Feb 18 15:47:48.399 UTC: //956/006BE4D43801/CCAPI/ccSaveDialpeerTag:
006694: *Feb 18 15:47:48.399 UTC: //956/006BE4D43801/H323/cch323_do_set_dialpeer_tag: gw_id=1
006695: *Feb 18 15:47:48.403 UTC: //957/006BE4D43801/CCAPI/cc_api_call_proceeding:
006696: *Feb 18 15:47:48.403 UTC: //956/006BE4D43801/H323/cch323_do_call_proceeding: gw_id=1
006697: *Feb 18 15:47:48.403 UTC: //956/006BE4D43801/H323/cch323_do_call_proceeding: gw_id=1
CRV Length             : 2
CRV Value              : 0x8138
Data 0521C0060008914A00042800B500001240013C05010000ADD9FC56AE3E110C1100006BE4D457803130380115020A0403820100010010800100
006698: *Feb 18 15:47:49.651 UTC: //957/006BE4D43801/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x86E100A0, Call Id=957
006699: *Feb 18 15:47:49.651 UTC: //957/006BE4D43801/CCAPI/cc_api_call_disconnected:
006700: *Feb 18 15:47:49.651 UTC: //956/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
006701: *Feb 18 15:47:49.651 UTC: //957/006BE4D43801/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=957
006702: *Feb 18 15:47:49.651 UTC: //957/006BE4D43801/CCAPI/ccCallDisconnect:
006703: *Feb 18 15:47:49.651 UTC: //957/006BE4D43801/CCAPI/ccCallDisconnect:
006704: *Feb 18 15:47:49.651 UTC: //957/006BE4D43801/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x86E100A0, Tag=0x0, Call Id=957,
006705: *Feb 18 15:47:49.655 UTC: //957/006BE4D43801/CCAPI/cc_api_call_disconnect_done:
006706: *Feb 18 15:47:49.655 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006707: *Feb 18 15:47:49.655 UTC: :cc_free_feature_vsa freeing 877AFBD8
006708: *Feb 18 15:47:49.655 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006709: *Feb 18 15:47:49.655 UTC:  vsacount in free is 1
006710: *Feb 18 15:47:49.655 UTC: //956/006BE4D43801/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=100, Params=0x86358504, Progress Indication=NULL(0)
006711: *Feb 18 15:47:49.655 UTC: //956/006BE4D43801/CCAPI/ccCheckClipClir:
   In: Calling Number=
3186411542
006712: *Feb 18 15:47:49.655 UTC: //956/006BE4D43801/CCAPI/ccCheckClipClir:
3186411542
006713: *Feb 18 15:47:49.655 UTC: //956/006BE4D43801/CCAPI/ccCallSetupRequest:
006714: *Feb 18 15:47:49.655 UTC: //956/006BE4D43801/CCAPI/ccCallSetupRequest:
   Calling Number=
3186411542
   Guid=006BE4D4-5780-3130-3801-15020A040382, Outgoing Dial-peer=100
006715: *Feb 18 15:47:49.655 UTC: //956/006BE4D43801/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=
3186411542
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
006716: *Feb 18 15:47:49.655 UTC: //956/006BE4D43801/CCAPI/ccIFCallSetupRequestPrivate:
3186411542
006717: *Feb 18 15:47:49.655 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006718: *Feb 18 15:47:49.655 UTC: :cc_get_feature_vsa malloc success
006719: *Feb 18 15:47:49.655 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006720: *Feb 18 15:47:49.655 UTC:  cc_get_feature_vsa count is 2
006721: *Feb 18 15:47:49.655 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006722: *Feb 18 15:47:49.655 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:
2272984032
,feature_id:921
006723: *Feb 18 15:47:49.655 UTC: //958/006BE4D43801/CCAPI/ccIFCallSetupRequestPrivate:
006724: *Feb 18 15:47:49.655 UTC: //958/006BE4D43801/CCAPI/ccCallSetContext:
   Context=0x863584B4
006725: *Feb 18 15:47:49.655 UTC: //956/006BE4D43801/CCAPI/ccSaveDialpeerTag:
006726: *Feb 18 15:47:49.655 UTC: //956/006BE4D43801/H323/cch323_do_set_dialpeer_tag: gw_id=1
006727: *Feb 18 15:47:49.659 UTC: //958/006BE4D43801/CCAPI/cc_api_call_proceeding:
006728: *Feb 18 15:47:50.911 UTC: //958/006BE4D43801/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x86E100A0, Call Id=958
006729: *Feb 18 15:47:50.911 UTC: //958/006BE4D43801/CCAPI/cc_api_call_disconnected:
006730: *Feb 18 15:47:50.911 UTC: //956/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
006731: *Feb 18 15:47:50.911 UTC: //958/006BE4D43801/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=958
006732: *Feb 18 15:47:50.911 UTC: //958/006BE4D43801/CCAPI/ccCallDisconnect:
006733: *Feb 18 15:47:50.911 UTC: //958/006BE4D43801/CCAPI/ccCallDisconnect:
006734: *Feb 18 15:47:50.911 UTC: //958/006BE4D43801/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x86E100A0, Tag=0x0, Call Id=958,
006735: *Feb 18 15:47:50.915 UTC: //958/006BE4D43801/CCAPI/cc_api_call_disconnect_done:
006736: *Feb 18 15:47:50.915 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006737: *Feb 18 15:47:50.915 UTC: :cc_free_feature_vsa freeing 877AFBD8
006738: *Feb 18 15:47:50.915 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006739: *Feb 18 15:47:50.915 UTC:  vsacount in free is 1
006740: *Feb 18 15:47:50.915 UTC: //-1/xxxxxxxxxxxx/H323/cch323_post_call_statistics: callID=956
006741: *Feb 18 15:47:50.915 UTC: //956/006BE4D43801/CCAPI/ccCallDisconnect:
006742: *Feb 18 15:47:50.915 UTC: //956/006BE4D43801/CCAPI/ccCallDisconnect:
006743: *Feb 18 15:47:50.915 UTC: //956/006BE4D43801/CCAPI/cc_api_get_transfer_info:
006744: *Feb 18 15:47:50.915 UTC: //956/006BE4D43801/H323/cch323_do_call_disconnect: gw_id=1, discCause=34
006745: *Feb 18 15:47:50.915 UTC: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x9 internal event to H225 SM
CRV Length             : 2
CRV Value              : 0x8138
Data 80A2
Data 052580060008914A000411001100006BE4D457803130380115020A04038210800100
006746: *Feb 18 15:47:50.915 UTC: //956/006BE4D43801/H323/cch323_call_generic_cleanup: Disconnected flag 1
006747: *Feb 18 15:47:50.915 UTC: //956/006BE4D43801/H323/cch323_store_call_history_entry: Call Active Playout Mode: 0,Init 0, Min 0, Max 0, Fax 0
006748: *Feb 18 15:47:50.915 UTC: //956/006BE4D43801/H323/cch323_store_call_history_entry: Call History Playout Mode: 0,Init 0, Min 0, Max 0, Fax 0
006749: *Feb 18 15:47:50.919 UTC: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 2
006750: *Feb 18 15:47:50.919 UTC: //-1/xxxxxxxxxxxx/H323/cch323_cleanup_xport: hashDestroy for TcpFDTbl
006751: *Feb 18 15:47:50.919 UTC: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 3
006752: *Feb 18 15:47:50.919 UTC: //956/006BE4D43801/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x867581A8, Tag=0x0, Call Id=956,
006753: *Feb 18 15:47:50.919 UTC: //956/006BE4D43801/CCAPI/cc_api_call_disconnect_done:
006754: *Feb 18 15:47:50.919 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006755: *Feb 18 15:47:50.919 UTC: :cc_free_feature_vsa freeing 877AFCB8
006756: *Feb 18 15:47:50.919 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006757: *Feb 18 15:47:50.919 UTC:  vsacount in free is 0
006758: *Feb 18 15:47:50.919 UTC: //-1/xxxxxxxxxxxx/H323/cch323_call_generic_cleanup: Freeing ccb (0x87BF6B7C) Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   In: Calling Number=
3186411542
3186411542
   Calling Number=
3186411542
   ccCallSetupRequest:
   cisco-ani=
3186411542
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3186411542
2272984032
,feature_id:920
   Context=0x863489F4
  Q931 Message IE Decodes
Protocol Discriminator : 0x08
CRV Length             : 2
CRV Value              : 0x8138
   In: Calling Number=
3186411542
3186411542
   Calling Number=
3186411542
   ccCallSetupRequest:
   cisco-ani=
3186411542
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3186411542
2272984032
,feature_id:921
   Context=0x863584B4
CRV Length             : 2
CRV Value              : 0x8138
Data 80A2
Any updates???
Hi Gerhard
Sorry for the delay
Looking through your latest trace there seems to be be an issue matching the incoming dial peer. (VOIP type)
and matching the default Dial peer 0
As you have now shown we are matching the new DP 911 as the outgoing DP
Can we try tidying up the peers now:
! *** This one is not needed as you have shown we now matching 911 ***
dial-peer voice 100 pots
dial-peer voice 201010 voip
dial-peer voice 200010 voip
Hopefully you should now be matching the VOIP type DPs
Alex.
Ok i now have this...
Can you explain what the incoming called-number has to do w/ the outbound calling?
I will have them test around 9am EST...   What debugs are the best to collect?
Anything more than i have been doing?
preference 1
destination-pattern 4300
voice-class codec 1
session target ipv4:10.0.100.13
dtmf-relay h245-alphanumeric
preference 2
voice-class codec 1
session target ipv4:10.0.100.12
preference 1
destination-pattern .T
port 4
preference 1
port 4
forward-digits 3
Gerhard,
Are you saying the issue is now fixed ?
Your question about the dial peers.
Every call whether it is inbound or outbound must use 2 dial peers.
1 for the incoming leg of the call set up and 1 for the outgoing set up.
In your original post you showed a GOOD call to a 10 digit number
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_DEST
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=100
These were selected by dial peer matching
so your CALLING PHONE No was 4300 that matched DP 201010
and your CALLED No was 13188406637 that mateches the .T in DP 100
When the calls to 911 arefailing they are not matching a usable I/C and O/G DP
when this happens you use a non deleteable DEFAULT DP "0" which is never really suitable
In you case the O/G patern with 911 is GOOD but there is no GOOD match for the VOIP incoming it
therefore use DP "0"
Have read through this:-
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html
It will help you understand how DPs are matched and in what order.
Alex.
Alex, No still getting the FAST BUSY... but now appears to be matching both incoming and outgoing DP's..
Any thoughts?
Ball#sh debug
DIALPEER:
  debug voip dialpeer error call is ON (filter is OFF)
  debug voip dialpeer error software is ON
  debug voip dialpeer inout is ON (filter is OFF)
H.225:
  H.225 Q931 IE Details debugging is on
CCH323 SPI: Session tracing is enabled (filter is OFF)
CCAPI:
  debug voip ccapi inout is ON (filter is OFF)
Ball#term mon
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
040759: *Feb 21 14:11:20.246 UTC: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 0 Event 0x1
040760: *Feb 21 14:11:20.246 UTC: //-1/xxxxxxxxxxxx/H323/cch323_get_new_ccb: ccb (0x87BF6B7C) is in use
040761: *Feb 21 14:11:20.246 UTC: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
040762: *Feb 21 14:11:20.246 UTC: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x87A9ED80, len=221, msgPtr=0x8784C254
040763: *Feb 21 14:11:20.246 UTC: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.225
CRV Length             : 2
CRV Value              : 0x0154
Message Type           : 0x05: SETUP
Bearer Capability: Length Of IE=3
Data 8090A2
Calling Party Number: Length Of IE=12
Data 008133313836343131353432
Called Party Number: Length Of IE=4
Data 80393131
User-User: Length Of IE=188
Data 0520B0060008914A000501401F00420061006C006C00200052006500630065007000740069006F006E0020002D002000340033003000300000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E61676572003100010100C44000A9FBDE435E7130540173020A04038200D50D800007000A00640D06B8110000A9FBDE435E7130540173020A040382010001000100010010A00100140140B50000120D82040020040001030003000103
040764: *Feb 21 14:11:20.250 UTC: //-1/xxxxxxxxxxxx/H323/cch323_extract_signaled_carriers: Entry
040765: *Feb 21 14:11:20.250 UTC: //1765/00A9FBDE5401/H323/cch323_determine_source_ip_group_info: No Source IP group match with Src CarrierId/Zone ID
040766: *Feb 21 14:11:20.250 UTC: //1765/00A9FBDE5401/H323/cch323_determine_source_ip_group_info: No Source IP group matched with rte id/zone_id/acl
040767: *Feb 21 14:11:20.250 UTC: //-1/xxxxxxxxxxxx/H323/cch323_determine_source_group: Entry
040768: *Feb 21 14:11:20.250 UTC: //1765/00A9FBDE5401/H323/cch323_determine_source_ip_group_info: No Source IP group match with Incoming Called Number
040769: *Feb 21 14:11:20.250 UTC: //-1/xxxxxxxxxxxx/H323/cch323_determine_source_group: Entry
040770: *Feb 21 14:11:20.250 UTC: //1765/00A9FBDE5401/H323/cch323_determine_source_ip_group_info: No Source IP group match with Destination pattern
040771: *Feb 21 14:11:20.250 UTC: //-1/00A9FBDE5401/DPM/dpAssociateIncomingPeerCore:
   Calling Number=3186411542, Called Number=911, Voice-Interface=0x0,
040772: *Feb 21 14:11:20.250 UTC: //-1/00A9FBDE5401/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=201010
040773: *Feb 21 14:11:20.250 UTC: //-1/xxxxxxxxxxxx/H323/cch323_associate_incoming_peer: timeout = 1, reason = 0
040774: *Feb 21 14:11:20.250 UTC: //1765/00A9FBDE5401/H323/cch323_set_preferred_codec: Using Voice Class Codec, tag = 1
040775: *Feb 21 14:11:20.250 UTC: //1765/00A9FBDE5401/H323/cch323_set_peer: peer: 87C8AFC4, peer->voice_peer_tag: 31132, ccb: 87BF6B7C
040776: *Feb 21 14:11:20.250 UTC: //1765/00A9FBDE5401/H323/cch323_set_peer: ccb h245addr bits = system[0x0007]
040777: *Feb 21 14:11:20.250 UTC: //1765/00A9FBDE5401/H323/cch323_set_peer: ccb ccm bits = system[0x0028]
040778: *Feb 21 14:11:20.250 UTC: //-1/00A9FBDE5401/DPM/dpAssociateIncomingPeerCore:
040779: *Feb 21 14:11:20.250 UTC: //-1/00A9FBDE5401/DPM/dpAssociateIncomingPeerCore:
040780: *Feb 21 14:11:20.250 UTC: //-1/xxxxxxxxxxxx/H323/cch323_associate_incoming_peer: timeout = 1, reason = 0
040781: *Feb 21 14:11:20.250 UTC: //1765/00A9FBDE5401/H323/h323_gw_setup_ind: is_overlap = 0, info_complete = 0
040782: *Feb 21 14:11:20.250 UTC: //-1/00A9FBDE5401/CCAPI/cc_api_display_ie_subfields:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
040783: *Feb 21 14:11:20.250 UTC: //-1/00A9FBDE5401/CCAPI/cc_api_call_setup_ind_common:
   Incoming Dial-peer=201010, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1765
040784: *Feb 21 14:11:20.250 UTC: //-1/00A9FBDE5401/CCAPI/ccCheckClipClir:
040785: *Feb 21 14:11:20.250 UTC: //-1/00A9FBDE5401/CCAPI/ccCheckClipClir:
040786: *Feb 21 14:11:20.254 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040787: *Feb 21 14:11:20.254 UTC: :cc_get_feature_vsa malloc success
040788: *Feb 21 14:11:20.254 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040789: *Feb 21 14:11:20.254 UTC:  cc_get_feature_vsa count is 1
040790: *Feb 21 14:11:20.254 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040791: *Feb 21 14:11:20.254 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:2271383096,feature_id:1706
040792: *Feb 21 14:11:20.254 UTC: //1765/00A9FBDE5401/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
040793: *Feb 21 14:11:20.254 UTC: //-1/xxxxxxxxxxxx/H323/cch323_create_call_info_type_container:
cch323_create_call_info_type_container: creating callInfoType container for callID = 1765
040794: *Feb 21 14:11:20.254 UTC: //1765/00A9FBDE5401/H323/cch323_update_call_info_from_dial_peer: Playout Mode: 1,Init 60, Min 40, Max 1000, Fax 300
040795: *Feb 21 14:11:20.254 UTC: //1765/00A9FBDE5401/H323/cch323_update_carriers_in_call_info: tg_label_flag 0x0
040796: *Feb 21 14:11:20.254 UTC: //1765/00A9FBDE5401/CCAPI/cc_process_call_setup_ind:
   Event=0x86DCD638
040797: *Feb 21 14:11:20.254 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
040798: *Feb 21 14:11:20.254 UTC: //1765/00A9FBDE5401/CCAPI/ccCallSetContext:
   Context=0x8634B634
040799: *Feb 21 14:11:20.254 UTC: //1765/00A9FBDE5401/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 1765 with tag 201010 to app "_ManagedAppProcess_Default"
040800: *Feb 21 14:11:20.254 UTC: //1765/00A9FBDE5401/CCAPI/ccCallProceeding:
040801: *Feb 21 14:11:20.258 UTC: //-1/00A9FBDE5401/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=911, Peer Info Type=DIALPEER_INFO_SPEECH
040802: *Feb 21 14:11:20.258 UTC: //-1/00A9FBDE5401/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=911
040803: *Feb 21 14:11:20.258 UTC: //-1/00A9FBDE5401/DPM/dpMatchPeersCore:
040804: *Feb 21 14:11:20.258 UTC: //-1/00A9FBDE5401/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
040805: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=911, Called Number=911, Peer Info Type=DIALPEER_INFO_SPEECH
040806: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
040807: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
040808: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
040809: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
040810: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
040811: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
040812: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
040813: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=911, Called Number=, Voice-Interface=0x0,
040814: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
040815: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
040816: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
040817: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
040818: *Feb 21 14:11:20.258 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
040819: *Feb 21 14:11:20.258 UTC: //-1/00A9FBDE5401/DPM/dpMatchPeersCore:
040820: *Feb 21 14:11:20.258 UTC: //-1/00A9FBDE5401/DPM/dpMatchPeersCore:
040821: *Feb 21 14:11:20.258 UTC: //-1/00A9FBDE5401/DPM/dpMatchPeersCore:
040822: *Feb 21 14:11:20.258 UTC: //-1/00A9FBDE5401/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
040823: *Feb 21 14:11:20.258 UTC: //1765/00A9FBDE5401/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=911, Params=0x86358504, Progress Indication=NULL(0)
040824: *Feb 21 14:11:20.258 UTC: //1765/00A9FBDE5401/CCAPI/ccCheckClipClir:
040825: *Feb 21 14:11:20.258 UTC: //1765/00A9FBDE5401/CCAPI/ccCheckClipClir:
040826: *Feb 21 14:11:20.258 UTC: //1765/00A9FBDE5401/CCAPI/ccCallSetupRequest:
040827: *Feb 21 14:11:20.258 UTC: //1765/00A9FBDE5401/CCAPI/ccCallSetupRequest:
   Guid=00A9FBDE-435E-7130-5401-73020A040382, Outgoing Dial-peer=911
040828: *Feb 21 14:11:20.258 UTC: //1765/00A9FBDE5401/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=Ball Reception - 4300
   ----- ccCallInfo IE subfields -----
   cisco-ani=3186411542
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
040829: *Feb 21 14:11:20.262 UTC: //1765/00A9FBDE5401/CCAPI/ccIFCallSetupRequestPrivate:
040830: *Feb 21 14:11:20.262 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040831: *Feb 21 14:11:20.262 UTC: :cc_get_feature_vsa malloc success
040832: *Feb 21 14:11:20.262 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040833: *Feb 21 14:11:20.262 UTC:  cc_get_feature_vsa count is 2
040834: *Feb 21 14:11:20.262 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040835: *Feb 21 14:11:20.262 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:2271382872,feature_id:1707
040836: *Feb 21 14:11:20.262 UTC: //1766/00A9FBDE5401/CCAPI/ccIFCallSetupRequestPrivate:
040837: *Feb 21 14:11:20.262 UTC: //1766/00A9FBDE5401/CCAPI/ccCallSetContext:
   Context=0x863584B4
040838: *Feb 21 14:11:20.262 UTC: //1765/00A9FBDE5401/CCAPI/ccSaveDialpeerTag:
040839: *Feb 21 14:11:20.262 UTC: //1765/00A9FBDE5401/H323/cch323_do_set_dialpeer_tag: gw_id=1
040840: *Feb 21 14:11:20.262 UTC: //1765/00A9FBDE5401/H323/cch323_do_call_proceeding: gw_id=1
040841: *Feb 21 14:11:20.262 UTC: //1765/00A9FBDE5401/H323/cch323_do_call_proceeding: gw_id=1
CRV Length             : 2
CRV Value              : 0x8154
Message Type           : 0x02: CALL_PROC
User-User: Length Of IE=57
Data 0521C0060008914A00042800B500001240013C05010000ADD9FC56E7E0110C110000A9FBDE435E7130540173020A0403820100010010800100
040842: *Feb 21 14:11:20.266 UTC: //1766/00A9FBDE5401/CCAPI/cc_api_call_proceeding:
040843: *Feb 21 14:11:21.514 UTC: //1766/00A9FBDE5401/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x86E100A0, Call Id=1766
040844: *Feb 21 14:11:21.514 UTC: //1766/00A9FBDE5401/CCAPI/cc_api_call_disconnected:
040845: *Feb 21 14:11:21.514 UTC: //1765/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
040846: *Feb 21 14:11:21.514 UTC: //1766/00A9FBDE5401/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=1766
040847: *Feb 21 14:11:21.514 UTC: //1766/00A9FBDE5401/CCAPI/ccCallDisconnect:
040848: *Feb 21 14:11:21.514 UTC: //1766/00A9FBDE5401/CCAPI/ccCallDisconnect:
040849: *Feb 21 14:11:21.514 UTC: //1766/00A9FBDE5401/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x86E100A0, Tag=0x0, Call Id=1766,
040850: *Feb 21 14:11:21.518 UTC: //1766/00A9FBDE5401/CCAPI/cc_api_call_disconnect_done:
040851: *Feb 21 14:11:21.518 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040852: *Feb 21 14:11:21.518 UTC: :cc_free_feature_vsa freeing 87628D50
040853: *Feb 21 14:11:21.518 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040854: *Feb 21 14:11:21.518 UTC:  vsacount in free is 1
040855: *Feb 21 14:11:21.518 UTC: //1765/00A9FBDE5401/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=100, Params=0x86349904, Progress Indication=NULL(0)
040856: *Feb 21 14:11:21.518 UTC: //1765/00A9FBDE5401/CCAPI/ccCheckClipClir:
   In: Calling Number=3186411542(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
040857: *Feb 21 14:11:21.518 UTC: //1765/00A9FBDE5401/CCAPI/ccCheckClipClir:
   Out: Calling Number=3186411542(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
040858: *Feb 21 14:11:21.518 UTC: //1765/00A9FBDE5401/CCAPI/ccCallSetupRequest:
   Destination Pattern=.T, Called Number=911, Digit Strip=TRUE
040859: *Feb 21 14:11:21.518 UTC: //1765/00A9FBDE5401/CCAPI/ccCallSetupRequest:
   Calling Number=3186411542(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=911(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=Ball Reception - 4300, Final Destination Flag=TRUE,
   Guid=00A9FBDE-435E-7130-5401-73020A040382, Outgoing Dial-peer=100
040860: *Feb 21 14:11:21.518 UTC: //1765/00A9FBDE5401/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
040861: *Feb 21 14:11:21.518 UTC: //1765/00A9FBDE5401/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x86E100A0, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=3186411542,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=911(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=100, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
040862: *Feb 21 14:11:21.518 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040863: *Feb 21 14:11:21.518 UTC: :cc_get_feature_vsa malloc success
040864: *Feb 21 14:11:21.518 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040865: *Feb 21 14:11:21.518 UTC:  cc_get_feature_vsa count is 2
040866: *Feb 21 14:11:21.518 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040867: *Feb 21 14:11:21.518 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:2271382872,feature_id:1708
040868: *Feb 21 14:11:21.518 UTC: //1767/00A9FBDE5401/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
040869: *Feb 21 14:11:21.518 UTC: //1767/00A9FBDE5401/CCAPI/ccCallSetContext:
   Context=0x863498B4
040870: *Feb 21 14:11:21.518 UTC: //1765/00A9FBDE5401/CCAPI/ccSaveDialpeerTag:
040871: *Feb 21 14:11:21.518 UTC: //1765/00A9FBDE5401/H323/cch323_do_set_dialpeer_tag: gw_id=1
040872: *Feb 21 14:11:21.522 UTC: //1767/00A9FBDE5401/CCAPI/cc_api_call_proceeding:
   Interface=0x86E100A0, Progress Indication=NULL(0)
040873: *Feb 21 14:11:22.774 UTC: //1767/00A9FBDE5401/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x86E100A0, Call Id=1767
040874: *Feb 21 14:11:22.774 UTC: //1767/00A9FBDE5401/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
040875: *Feb 21 14:11:22.774 UTC: //1765/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
040876: *Feb 21 14:11:22.774 UTC: //1767/00A9FBDE5401/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=1767
040877: *Feb 21 14:11:22.774 UTC: //1767/00A9FBDE5401/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
040878: *Feb 21 14:11:22.774 UTC: //1767/00A9FBDE5401/CCAPI/ccCallDisconnect:
   Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
040879: *Feb 21 14:11:22.778 UTC: //1767/00A9FBDE5401/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x86E100A0, Tag=0x0, Call Id=1767,
   Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
040880: *Feb 21 14:11:22.778 UTC: //1767/00A9FBDE5401/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
040881: *Feb 21 14:11:22.778 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040882: *Feb 21 14:11:22.778 UTC: :cc_free_feature_vsa freeing 87628D50
040883: *Feb 21 14:11:22.778 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040884: *Feb 21 14:11:22.778 UTC:  vsacount in free is 1
040885: *Feb 21 14:11:22.778 UTC: //-1/xxxxxxxxxxxx/H323/cch323_post_call_statistics: callID=1765
040886: *Feb 21 14:11:22.778 UTC: //1765/00A9FBDE5401/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
040887: *Feb 21 14:11:22.778 UTC: //1765/00A9FBDE5401/CCAPI/ccCallDisconnect:
040888: *Feb 21 14:11:22.778 UTC: //1765/00A9FBDE5401/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
040889: *Feb 21 14:11:22.778 UTC: //1765/00A9FBDE5401/H323/cch323_do_call_disconnect: gw_id=1, discCause=34
040890: *Feb 21 14:11:22.778 UTC: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x9 internal event to H225 SM
CRV Length             : 2
CRV Value              : 0x8154
Message Type           : 0x5A: RELEASE_COMP
Cause: Length Of IE=2
Data 80A2
User-User: Length Of IE=34
Data 052580060008914A00041100110000A9FBDE435E7130540173020A04038210800100
040891: *Feb 21 14:11:22.778 UTC: //1765/00A9FBDE5401/H323/cch323_call_generic_cleanup: Disconnected flag 1
040892: *Feb 21 14:11:22.778 UTC: //1765/00A9FBDE5401/H323/cch323_store_call_history_entry: Call Active Playout Mode: 1,Init 60, Min 40, Max 1000, Fax 300
040893: *Feb 21 14:11:22.778 UTC: //1765/00A9FBDE5401/H323/cch323_store_call_history_entry: Call History Playout Mode: 1,Init 60, Min 40, Max 1000, Fax 300
040894: *Feb 21 14:11:22.782 UTC: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 2
040895: *Feb 21 14:11:22.782 UTC: //-1/xxxxxxxxxxxx/H323/cch323_cleanup_xport: hashDestroy for TcpFDTbl
040896: *Feb 21 14:11:22.782 UTC: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 3
040897: *Feb 21 14:11:22.782 UTC: //1765/00A9FBDE5401/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x867581A8, Tag=0x0, Call Id=1765,
040898: *Feb 21 14:11:22.782 UTC: //1765/00A9FBDE5401/CCAPI/cc_api_call_disconnect_done:
040899: *Feb 21 14:11:22.782 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040900: *Feb 21 14:11:22.782 UTC: :cc_free_feature_vsa freeing 87628E30
040901: *Feb 21 14:11:22.782 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040902: *Feb 21 14:11:22.782 UTC:  vsacount in free is 0
040903: *Feb 21 14:11:22.782 UTC: //-1/xxxxxxxxxxxx/H323/cch323_call_generic_cleanup: Freeing ccb (0x87BF6B7C)
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#
Ball#FAST BUSY
% Invalid input detected at '^' marker.
preference 1
voice-class codec 1
incoming called-number .
preference 2
voice-class codec 1
preference 1
port 4
dial-peer voice 911 pots
preference 1
destination-pattern 911
port 4
forward-digits 3
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 101 in
login local
length 0
end
Ball#
Ball#
Gerhard,
Could you run the call again buth this time with only debug vpm signal
undebug all
debug vpm signal
I want see what is happening on the actual FXO interface
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
041076: *Feb 21 15:57:38.205 UTC: htsp_timer_stop3 htsp_setup_req
041077: *Feb 21 15:57:38.209 UTC: htsp_process_event: [4, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
041078: *Feb 21 15:57:38.209 UTC: [4] set signal state = 0xC timestamp = 0
041079: *Feb 21 15:57:38.209 UTC: htsp_timer - 1300 msec
041080: *Feb 21 15:57:38.461 UTC: htsp_process_event: [4, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
041081: *Feb 21 15:57:38.461 UTC: htsp_timer2 - 1000 msec
041082: *Feb 21 15:57:38.461 UTC: htsp_timer_stop
041083: *Feb 21 15:57:39.461 UTC: htsp_process_event: [4, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
041084: *Feb 21 15:57:39.461 UTC: htsp_timer_stop
041085: *Feb 21 15:57:39.461 UTC: htsp_timer_stop2
041086: *Feb 21 15:57:39.461 UTC: [4] set signal state = 0x4 timestamp = 0
041087: *Feb 21 15:57:39.461 UTC: htsp_process_event: [4, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
041088: *Feb 21 15:57:39.465 UTC: htsp_timer_stop3 htsp_setup_req
041089: *Feb 21 15:57:39.465 UTC: htsp_process_event: [4, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
041090: *Feb 21 15:57:39.465 UTC: [4] set signal state = 0xC timestamp = 0
041091: *Feb 21 15:57:39.465 UTC: htsp_timer - 1300 msec
041092: *Feb 21 15:57:39.717 UTC: htsp_process_event: [4, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
041093: *Feb 21 15:57:39.717 UTC: htsp_timer2 - 1000 msec
041094: *Feb 21 15:57:39.717 UTC: htsp_timer_stop
041095: *Feb 21 15:57:40.717 UTC: htsp_process_event: [4, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
041096: *Feb 21 15:57:40.717 UTC: htsp_timer_stop
041097: *Feb 21 15:57:40.717 UTC: htsp_timer_stop2
041098: *Feb 21 15:57:40.717 UTC: [4] set signal state = 0x4 timestamp = 0
041099: *Feb 21 15:57:40.717 UTC: htsp_process_event: [4, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
Ball#
Ball#
Ball#
Gerhard,
The FXO port is reporting that it does not have dial tone
Can you ensure that you have the right signal type configured to match your service provider
The default is loop-start
but it can be ground-start if that was asked for
Can you also ensure that you have only connected 2 wires on you FXO/RJ11
Only pins 3 & 4 should be connected to the lines tip & ring ( or A & B)
Alex.
Alex,
what doesn't make sense is why is the other call going throught then?   this office is remote to me... like a plane ride, so i don't have access to verify some of the things you've asked...   this was a snip from the previous post.
We only have 1 POTS line in the router on port 4.....
Calling Number=4300, Called Number=13188406637, Voice-Interface=0x0,
000184: *Feb 17 19:45:23.436 UTC: //-1/004955D92E01/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=201010
000188: *Feb 17 19:45:23.440 UTC: //-1/004955D92E01/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=13188406637
000189: *Feb 17 19:45:23.440 UTC: //-1/004955D92E01/DPM/dpMatchPeersCore:
000190: *Feb 17 19:45:23.440 UTC: //-1/004955D92E01/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
