H323 Gateway error
ayoussef.kamal
Gents,
I have the below repeated errors appear on H323 GW registered to CUCM 6.1
WHY??
088742: Jul 12 12:56:14.193 BST: %SKINNYSERVER-3-NOINIT: Can't initialize Skinny server
088743: Jul 12 12:56:14.193 BST: %SKINNYSERVER-3-NOINIT: Can't initialize Skinny server
There is a similar problem on this thread here and this can be caused by a few things. You dont seem to have any sccp configuartion so this may be memory related..
https://supportforums.cisco.com/thread/282652
I suggest you reboot the router. That should do it.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
5 Replies 5
Sharon Tom
do you have telephony-service or call-manager fallback configured on the router?
if so then it may be a problem with skinny stack. try doing "shut" "no shut" under telephony-service/call-manager fallback if configured.
if the issue still exists provide the following details:
sh version
sh run
sh sccp
Please find the below:
nikshah
might worth a shot
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCeh67334
check your ios version.
might have a socket leak. The show socket command should tell you how many socket are opened
check the ram on yr router could be a possible RAM issue.
Hope this helps
Niket
Kindly rate useful posts!!!
Thank you aokanlawon. You are
