H323 Gateway (ISR 4321) Maximum call blocking using rejection rule
jrdiaz
Hello Everyone,
Good Day. Is there any document stating the maximum number of call blocking we can do on a H323 gateway (ISR 4321)? Also is the "Route Next Hop by calling Party Number" can be used as call blocking after reaching the call blocking limit of h323 gateway?
Thanks you so much :)
JP
HARIS_HUSSAIN
1) Below is the link  stating limit of voice translation rules it is 15 OR 100 rules in one voice translation rule
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/vcr3/vcr3-cr-book/vcr-r1.html#wp8518966320
Voice translation-rule configuration
Command History
Release
Modification
12.2(11)T
This command was introduced with a new syntax in voice-translation-rule configuration mode.
15.1(4)M
This command was introduced with an increase in the maximum value of the precidence variable from 15 to 100.
2) Yes You can use the Route Next Hop By Calling Number , If the Call is not blocked by the voice translation rule then you have to route it to CUCM. There is not upper cap on Number of Translation rule in CUCM but it depend on resources available.
Below discusssion will help
MAXIMUM TRANSLATION IN CUCM
A better approach will be to use CUCM it self as it will give higher limitations.
**DON'T Forgot to Rate or Accept a Solution if applicable.
Haris
HARIS_HUSSAIN
Command History
Release
Modification
12.2(11)T
15.1(4)M
Haris
Thank you so much!
