Hardware Failure Alert with MCS
Sreeju S Kumar
  I am receiving the below error for one of my MCS in the cluster.
the following HardwareFailure events generated: hwStringMatch - HP Insight Management Agents Trap Alarm: Accelerator Board Status Change: Slot 1. hwStringMatch - HP Insight Management Agents Trap Alarm: Status is now Enabled.
Can anyone help me to understand what this error means.
Thanks in Advance.
Sreeju
Rob Huffman
Hi Sreeju,
We had this exact error not too long ago with the distinction that the status
went to "disabled" as shown below;
the following HardwareFailure events  generated: hwStringMatch - HP Insight Management Agents Trap Alarm:  Accelerator Board Status Change: Slot 1. hwStringMatch - HP Insight  Management Agents Trap Alarm: Status is now Disabled.
In your case the board has moved to an "Enabled" state which is a good thing Our issue was
the batteries associated with the Accelerator Board needed to be replaced so an RMA via
Cisco TAC was required. You aren't at this stage but keep an eye on things just in case.
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
Rob Huffman
Hi Sreeju,
Cheers!
Rob
"Talk about a dream
- Springsteen
Thanks Rob. I will keep that in mind and will closely monitor this error
