Headset splitter w/o quick disconnect
billmatthews
Plantronics CS361N.  They connect directly to the headset port, no "Quick Disconnect" cables involved.
I need to get a second person the ability to listen into calls.  With my wired headsets (with quick disconnects) I could use a supervisor Y cord. (http://www.plantronics.com/us/product/y-adapter-trainer?skuId=sku4230029&utm_source=Google&utm_medium=ProductFeed&utm_campaign=ProductFeed&gclid=CNXDm9CHuLsCFS4aOgodVFsATw)
However I'm not sure what I would use for the standard phone wire.  Does a generic phone splitter work?  And then connect two CS361N?
Thanks!
Rob Huffman
Hi Bill,
You are most welcome
I can't open your link but here are a couple of other thoughts;
http://www.headsets.com/headset/Headsets.com-Wireless-Y-Adapter/
or
http://www.aiheadsets.com/464.html
Cheers!
Rob
"When it comes to luck you make your own  "
- Springsteen
Rob Huffman
Hi Bill,
A generic "phone splitter" won't work as the plugs will
be RJ11 but it does look like they made a part for this type of set up;
Part# - 39954-01
or
http://www.best4systems.co.uk/plantronics-cs60-cs70n-cs351n-cs361n-t-piece-training-adaptor.html#.UrGkRvuaW5c
Cheers!
Rob
- Springsteen
Thanks Rob, +5.
But I wonder why all the google results are UK sites? I can't find it on any US sites (even plantronics.com).  But that's exactly what I'm looking for.
I also found this option, but it requires the handset port (not headset): http://www.headsetsdirect.com/wireless-headset-training-adapter-03929-63.html
Rob Huffman
Hi Bill,
or
Cheers!
Rob
- Springsteen
