02-15-2013 05:37 AM - edited 03-16-2019 03:44 PM
I' ve created a cti route point in my cucm 8.6.2.
At the moment I' dont hava a Cue on my network, I've this question:
I'ts correctthat the cti route point are non registered? for the registration it's necessary to have a cue connecetd ad available on the network?
Thanks in advance .
Giancarlo
02-15-2013 05:40 AM
Yes, it's correct is not registered, only UCCX CTI port should be registered (at least I have only see this kind of CTI registered). No, CTI Point works as a "virtual phone" for forward call to wherever you want.
Please check this guide, it should help you:
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a00801f66ca.shtml
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
02-15-2013 05:41 AM
Hi Giancarlo,
That is most correct my friend If the application, (CUE
in this case) is not available CTI-RP's will always be unregistered.
Cheers!
Rob
EDIT:+5 to my friend Leo, for your great answer and for showing up my
horribly poor typing skills
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
