08-28-2018 11:21 PM - edited 03-18-2019 12:30 PM
I need help configuring E1 Pri Dial-peer.
i have this output and already configured de outbound but the calls are not going out. I want the E1 to be my main outgoing source.
voice-port 0/0/0:15
echo-cancel coverage 64
cptone PT
description ## ISDN PRI ##
voice-port 0/1/0
cptone PT
connection plar opx 100
impedance complex2
description TDM-1
station-id name L00
caller-id enable type 1
voice-port 0/1/1
cptone PT
impedance complex2
description TDM-2
station-id name L01
voice-port 0/1/2
cptone PT
connection plar opx 201
impedance complex2
description TDM-1
station-id name L02
voice-port 0/1/3
cptone PT
impedance complex2
description TDM-2
station-id name L03
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer cor custom
name 0
name 02
name 082
name 084
name 086
name 087
dial-peer cor list Call-Nacional
member 02
member 082
member 084
member 086
member 087
dial-peer cor list Call-International
member 0
member 02
member 082
member 084
member 086
dial-peer cor list Call-Local
dial-peer cor list Call-Nacional-2
member 02
member 082
member 084
member 086
member 087
dial-peer voice 2 pots
corlist outgoing Call-Nacional
description ## DESTINY TDM-1 ##
destination-pattern 02T
port 0/1/0
forward-digits 8
dial-peer voice 3 pots
description ## DESTINY TDM-2 ##
port 0/1/1
forward-digits 8
dial-peer voice 4 pots
description ## DESTINY MOBILE 1 ##
destination-pattern 082T
port 0/1/1
forward-digits 9
dial-peer voice 5 pots
description ## Destino MOBILE 1 ##
port 0/1/0
forward-digits 9
dial-peer voice 6 pots
description ## DESTINY MOBILE 2 ##
destination-pattern 084T
port 0/1/0
forward-digits 9
dial-peer voice 7 pots
description ## DESTINY MOBILE 3 ##
port 0/1/1
forward-digits 9
dial-peer voice 8 pots
destination-pattern 087T
port 0/1/0
forward-digits 9
dial-peer voice 9 pots
destination-pattern 086T
port 0/1/1
forward-digits 9
dial-peer voice 10 pots
corlist outgoing Call-International
description ## Destino Internacional TDM-1 ##
destination-pattern 00T
port 0/1/0
forward-digits all
dial-peer voice 12 pots
corlist outgoing Call-Nacional-2
description ## Destino PHONE LINE TDM-1 ##
port 0/1/2
forward-digits 8
dial-peer voice 13 pots
description ## Destino PHONE LINE TDM-2 ##
port 0/1/3
forward-digits 8
dial-peer voice 14 pots
port 0/1/2
forward-digits 9
dial-peer voice 15 pots
port 0/1/3
forward-digits 9
dial-peer voice 16 pots
description ## Destiny MOBILE 1 ##
port 0/1/2
forward-digits 9
dial-peer voice 17 pots
port 0/1/3
forward-digits 9
dial-peer voice 18 pots
description ## Destiny MOBILE 2##
port 0/1/2
forward-digits 9
dial-peer voice 19 pots
port 0/1/3
forward-digits 9
dial-peer voice 20 pots
description ## DESTINY INTERNATIONAL TDM-1 ##
port 0/1/2
forward-digits all
dial-peer voice 200 pots
description ## In_TDM PRI ##
translation-profile incoming Inbound_TDM
incoming called-number 21XXXX..
direct-inward-dial
port 0/0/0:15
dial-peer voice 1 pots
trunkgroup OUTBOUND
description ##PSTN OUT###
forward-digits all
Solved! Go to Solution.
08-29-2018 07:13 AM
Is this CME?
You could use the below
trunkgroup OUTBOUND -- I do not see trunk group in the config and you can remove if it is not there
forward-digits all
voice-port 0/0/0:15
08-30-2018 12:50 AM
Yes, its CME.
I'm new into this, (coming from R&S).
I will try that.
08-29-2018 07:13 AM
Is this CME?
forward-digits all
voice-port 0/0/0:15
08-30-2018 12:50 AM
Yes, its CME.
I will try that.
11-19-2018 12:16 PM
Please your support i have 2 router isr 4331 and we have 2 phone 7811 connected on.router A and sccp phone 6921 connect on.router B. The destination-patern on router B is 5130. When 7811 try to call 6921 we hav not a problem. So when 6921 try to call only 4 digit was forwad and the router cannot now (.) Or other symbol. We observed this problem only on router isr. Can you help please
