help for CUCM VR10
Hello.
Is that there is a version of CUCM VERSION 10 to download for testing without a license?
No, if you're a parnter, reach out to pre-sales for this info
If you're an end customer, you will need to reach a Cisco partner, as they'll be the ones placing the order.
java
if this helps, please rate
Jaime Valencia
No, there is not, the system will only operate for 60 days without license, and then it will go into read only mode, with no changes allowed, until valid licensing is installed.
If you're with a Cisco partner, might want to look into the NFR kits
java
You have an idea about the price of the license?
java
