01-22-2014 03:55 AM - edited 03-16-2019 09:22 PM
I use cisco 2911 with 4 FXO port and 1 FXS port for my office. My IP phone is CP 3905
I configure for call internal/ external ok.
But when i change the dialpeer for outgoing PSTN, I not make a call from internal -> PSTN
I debug error and the error message "disconnect cause 11 " or disconnect text cause 17
When i make a call from internal to PSTN: I hear the busy tone. And I call for my mobile many time but i till hear the busy tone.
I call from PSTN to extension is ok. And call ext to ext is ok. But call from extension to PSTN have a busy tone
Please help me or have solution for solve this problem.
01-22-2014 06:23 AM
Please provide following debugs:
debug voice dialpeer
debug vpm signel
debug voice ccapi inout
Chris
01-22-2014 06:53 AM
Issue this command on the port you're using
test voice port x/x/x si-reg-read 29 1
It sounds like the polarity is reversed on that cable.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
01-22-2014 06:51 PM
I just checked all but not make outgoing call to PSTN.
I check dialplan, dialpeer for internal calll to mobile phone
Macro Exp.: 0908043018
VoiceEncapPeer2
peer type = voice, system default peer = FALSE, information type = voice
description = `',
tag = 2, destination-pattern = `^0.........',
voice reg type = 0, corresponding tag = 0,
allow watch = FALSE
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
rtp-ssrc mux = system
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 2, Admin state is up, Operation state is up,
Outbound state is up,
incoming called-number = `', connections/maximum = 0/unlimited,
DTMF Relay = disabled,
URI classes:
Destination =
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
mailbox selection policy: none
trunk-group:
id = `1', preference = `'
type = pots, prefix = `',
forward-digits default
session-target = `', voice-port = `',
direct-inward-dial = disabled,
digit_strip = disabled,
register E.164 number with H323 GK and/or SIP Registrar = TRUE
fax rate = system, payload size = 20 bytes
supported-language = ''
preemption level = `routine'
bandwidth:
maximum = 64 KBits/sec, minimum = 64 KBits/sec
voice class called-number:
inbound = `', outbound = `'
dial tone generation after remote onhook = enabled
mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
snr calling-number local=disabled, snr ring-stop=disabled, snr answer-to
o-soon timer=0
Time elapsed since last clearing of voice call statistics never
Connect Time = 0, Charged Units = 0,
Successful Calls = 0, Failed Calls = 22, Incomplete Calls = 22
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "11 ",
Last Disconnect Text is "user busy (17)",
Last Setup Time = 7491887.
Last Disconnect Time = 0.
Matched: 0908043018 Digits: 2
Have ideas for me to solve this problem.
01-23-2014 12:55 AM
01-23-2014 11:00 AM
I checked the logs. you called 0908043018 and I can see outgoing dial peer 2 was matched but for some reason immediately call was disconnected. Could you check whether fxo port is correctly applied in dial peer 2 also share "show run"
If possible provide below debugs for a call again
debug vpm signal
debug voip ccapi inout
Mohit SIngh
01-23-2014 11:11 AM
Are you sure your PSTN provider support ground start signaing? Generally they support loop start. Can you try using loop start
voice-port
no signal groundStart
signal loopstart
shut
no shut
Mohit SIngh
01-23-2014 06:25 PM
Thank MOHIT SINGH.
It's ok for outgoing call. But when i set up 2 months ago, i used signal groundstart, it's work fine.
