Help :Nortel 61C PBX to Cisco IP Telephony Migration
hsiddiqi
I am trying to integrate my Nortel Option 61C with my  Cisco 2901 and CUCM. The telco carrier 2 PRI go into the Nortel, and then I have another PRI between the two PBXs.  I have asked my Nortel PBX vendor to follow the Document 12986 ( Case Study: Nortel 61C PBX to Cisco IP Telephony Migration ) Starting Step 9. http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_white_paper09186a00801115e0.shtml
My Nortel vendor mentions he has a D channel mismatch on his side.
On the Cisco Gateway, ISDN status indicates Layer 1 is shutdown.  The pins are correct as I had this up before I rebooted the cisco gateway.  Any suggestions will be helpful.
vg01#show isdn status
Global ISDN Switchtype = primary-dms100
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:23 interface
        dsl 0, interface ISDN Switchtype = primary-dms100
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        SHUTDOWN
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 1
    Total Allocated ISDN CCBs = 0
On my cisco side I have the following relevant config
card type t1 0 0
logging buffered 51200 warnings
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
no ipv6 cef
ipv6 spd queue min-threshold 62
ipv6 spd queue max-threshold 63
no ip source-route
ip cef
ip multicast-routing
isdn switch-type primary-dms100
voice-card 0
dspfarm
dsp services dspfarm
voice call carrier capacity active
voice rtp send-recv
application
global
service alternate DEFAULT
hw-module pvdm 0/0
controller T1 0/0/0
cablelength short 110
pri-group timeslots 1-24 service mgcp
ip ssh version 2
class-map match-any MetroQoS-VoIP-RTP-Trust
match ip dscp ef
class-map match-any MetroQoS-VoIP-Control-Trust
match ip dscp cs3
match ip dscp af31
policy-map MetroQoS-Policy-Trust
class MetroQoS-VoIP-RTP-Trust
priority percent 70
class MetroQoS-VoIP-Control-Trust
bandwidth percent 5
class class-default
fair-queue
interface Port-channel47
description BONDED-INTERFACE
ip address 192.168.124.4 255.255.255.0
service-policy output MetroQoS-Policy-Trust
hold-queue 150 in
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description PRIMARY-INTERFACE
no ip address
duplex auto
speed auto
channel-group 47
interface GigabitEthernet0/1
description SECONDARY-INTERFACE
no ip address
duplex auto
speed auto
channel-group 47
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip forward-protocol nd
voice-port 0/0/0:23
ccm-manager switchback immediate
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.15.11
ccm-manager config
mgcp
mgcp call-agent mcucm01 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Port-channel47
mgcp bind media source-interface Port-channel47
14 Replies 14
What is the controller status ?
Nortel has set the 23 channel for signalling?
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Thank your reply
I am not sure if Nortel has set the 23 channel for signalling. From the Cisco doc, it may be 19.
Below here is controller T1 status.
vg01#show controller T1
T1 0/0/0 is down.
  Applique type is Channelized T1
  Cablelength is short 110
  Receiver has remote alarm.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (365 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 365 Unavail Secs
  Total Data (last 69 15 minute intervals):
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 62100 Unavail Secs
Build the D-Channel
The D-channel is used for signaling between the two systems for call setup and teardown. You have to configure the new D-channel so that it knows:
•Clock source.
•Bandwidth allocation.
•Loop association.
The D-channel is built and administered in load 17. This example shows the new D-channel configuration. The bold text shows that the clock source is external, the new D-channel is associated with loop 19, and the bandwidth allocation for the D-channel is 64 KC.
Note: The bandwidth allocation for the D-channel is set with the D-channel transmission rate (DRAT) prompt.
ADAN DCH 1
CTYP MSDL
DNUM 9
PORT 2
DES CISCO-LOOP19
USR PRI
DCHL 19
OTBF 127
PARM RS422 DTE
DRAT 64KC
CLOK EXT
IFC D100
SIDE USR
CNEG 1
RLS ID **
RCAP ND2
T200 3
T203 10
N200 3
N201 260
K 7
T1 0/0/0 is down.
I have asked the Nortel vendor to follow the cisco doc
Build the D-Channel
•Clock source.
•Loop association.
ADAN DCH 1
CTYP MSDL
DNUM 9
PORT 2
DES CISCO-LOOP19
USR PRI
DCHL 19
OTBF 127
PARM RS422 DTE
DRAT 64KC
CLOK EXT
IFC D100
SIDE USR
CNEG 1
RLS ID **
RCAP ND2
T200 3
T203 10
N200 3
N201 260
K 7
Ok
But i see here that the layer 1(physical layer is down)
Most propably that the cable that you use is not the correct
Did you use a cross-over T1 cable?
http://support.red-fone.com/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=1
Some other issues that you have to check when the layer 1 is down
*clock reference
*framing
*line coding
*switch type
Ensure one side of the connection is providing clock and the other site is deriving clock
Ensure both sides are configured with the same framing and line coding
Did you manage to solve your issue?
Hi ,
Issue not resolved as yet.
The integration was set up correctly and Layer 1 was up with primary isdn switch type ni 2.
I was able to make calls from the cisco phones to the phones hanging off the Nortel PBX.  However I was not able to make calls from the cisco ip phones to any external PSTN numbers.
I was also able to recieve calls on the cisco ip phones internal & external.
telco pri(2) ---- Nortel PBX ------cross over cable---------------cisco VG-----------CAT5-------------CUCM
Since I was not able to make calls from the cisco ip phones to any external PSTN numbers, the Nortel PBX vendor and I agreed to try primary isdn switch type DMS-100(follow the above doc)
I am to provide clocking, I have changed that to LINE, Internal, and now they are not working at all.
Will different setting on clocking , USER, NETWORK affect layer 1 ?
For sure affect layer 1..
If you put network then you are giving the clocking. By put user then nortel must give the clocking.. if you sent the calls for pstn ( route pattern 9! To the mgcp connection with nortel then nortel must perform the other steps
I have set the clocking to internal and the  Layer 1 has changed to ACTIVE,.
Layer 2 awaiting establishment ?
#show isdn status
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
    Layer 3 Status:
    The Free Channel Mask:  0x807FFFFF
    Number of L2 Discards = 0, L2 Session ID = 114
Try in gw:
no mgcp
mgcp
Sorry to jump in late, Clock was our issue with this.
only the PBX that has the Provide PRI should provide the clock. if Cisco provides the Clock but Nortel has the provider PRI this will bomb in about 30 days, clocks will go out of sync and call flow will die altogether.
We will be finishing our converstion from Nortel PBX's here in 60 Days.
So the Cisco Phones can Call Nortel,
Nortel can call Cisco.
Cisco cannot call PSTN.
     Easy Fix, you must pass the out dialing digit to the Nortel.So if the Nortel is required "9" for PSTN, dont strip the 9 on the cisco side, send it to Nortel.
I cannot make calls from cisco to Nortel either way , I get a fast busy.
Separately,
I have specified the following for my PBX vendor:
Build the D-Channel (taken from http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_white_paper09186a00801115e0.shtml)
  • Clock source. (Cisco GW is providing the clocking )
  • Bandwidth allocation.
  • Loop association. (Loop 19)   <----- What do I need to specify on the Cisco Gateway ?  Do I need to specify which is my D Channel.  19 ? I am using MGCP  (see above config)
Here are a couple of screen shots of our PRI Setup.
Here is are some specifics of the Nortel setup of the PRI.
1st  is a TNB on loop 79  channel 1    note you have 3 tie line T-1’s to CISCO 79,95, & 60
2nd Route data block for route 30, cicsco tie lines, all one group
3rd  A snapshot (frozen in time ) of loop 79  23 B-channels and 1 D-channel
4th  Programing of the D- channel
OVL000
OVL000
OVL000
>ld 20
PT0000
REQ: prt
TYPE: tnb
TN   79 1
DATE
PAGE
DES
DES  CISCO
TN   079 01
TYPE TIE
CDEN SD
CUST 0
TRK  PRI
PDCA 1
PCML MU
NCOS 6
RTMB 30 1
B-CHANNEL SIGNALING
TGAR 0
AST  NO
IAPG 0
CLS  UNR DTN CND ECD WTA LPR APN THFD HKD SPCD
     P10 VNL
TKID
AACR NO
DATE  5 AUG 2010
NACT
REQ:
REQ PRT
TYPE: ****
OVL000
OVL000
>ld
AUD000
21
PT1000
REQ: prt
TYPE: rdb
CUST 0
ROUT 30
TYPE RDB
CUST 00
ROUT 30
DES  CISCO
TKTP TIE
M911P NO
ESN  NO
CNVT NO
SAT  NO
RCLS EXT
VTRK NO
NODE
DTRK YES
BRIP NO
DGTP PRI
ISDN YES
    MODE PRA
    IFC  ISGF
    SBN  NO
    PNI  00000
    NCNA NO
    NCRD NO
    CHTY BCH
    CTYP UKWN
    INAC NO
    ISAR NO
    CPFXS YES
    DAPC NO
    INTC NO
MBXR NO
DSEL VOD
PTYP PRI
AUTO NO
DNIS NO
DCDR NO
ICOG IAO
SRCH LIN
TRMB YES
STEP
ACOD 7783
TCPP NO
PII NO
AUXP NO
TARG
CLEN 1
BILN NO
OABS
INST
IDC  NO
DCNO 0 *
NDNO 0
DEXT NO
ANTK
SIGO STD
ICIS YES
TIMR ICF  512
     OGF  512
     EOD  13952
     NRD  10112
     DDL  70
     ODT  4096
     RGV  640
     GRD  896
PAGE 002
     SFB  3
     NBS  2048
     NBL  4096
     IENB  5
     TFD  0
     VSS  0
     VGD  6
DRNG NO
CDR  YES
INC  NO
LAST NO
QREC NO
OAL  YES
AIA  YES
OAN  YES
OPD  NO
NATL YES
VRAT NO
MUS  NO
FRL  0 0
FRL  1 0
FRL  2 0
FRL  3 0
FRL  4 0
FRL  5 0
FRL  6 0
FRL  7 0
OHQ  NO
OHQT 00
CBQ  NO
AUTH NO
TDET NO
TTBL 0
ATAN NO
PLEV 2
ALRM NO
ART  0
SGRP 0
ARDN NO
AACR NO
REQ: ****
OVL000
>ld 60
DTI000
.stat 79
PRI*  TRK  LOOP 79 - ENBL
FFMT/LCMT/YALMT:  ESF/B8Z/FDL
TRACKING
SERVICE RESTORE: YES
YEL ALM PROCESS: YES
ALARM STATUS : NO ALARM
CH 01 - IDLE TIE   VOD  *           CH 02 - IDLE TIE   VOD  *
CH 03 - IDLE TIE   VOD  *           CH 04 - IDLE TIE   VOD  *
CH 05 - IDLE TIE   VOD  *           CH 06 - IDLE TIE   VOD  *
CH 07 - IDLE TIE   VOD  *           CH 08 - IDLE TIE   VOD  *
CH 09 - IDLE TIE   VOD  *           CH 10 - IDLE TIE   VOD  *
CH 11 - IDLE TIE   VOD  *           CH 12 - IDLE TIE   VOD  *
CH 13 - BUSY TIE   VOD  *           CH 14 - BUSY TIE   VOD  *
CH 15 - BUSY TIE   VOD  *           CH 16 - IDLE TIE   VOD  *
CH 17 - IDLE TIE   VOD  *           CH 18 - BUSY TIE   VOD  *
CH 19 - BUSY TIE   VOD  *           CH 20 - BUSY TIE   VOD  *
CH 21 - BUSY TIE   VOD  *           CH 22 - BUSY TIE   VOD  *
CH 23 - BUSY TIE   VOD  *           CH 24 - DCH 79
OVL000
OVL000
OVL000
>ld 22
PT2000
REQ  prt
TYPE adan dch 79
ADAN     DCH 79
  CTYP MSDL
  GRP  2
  DNUM 11
  PORT 1
  DES  CISCO
  USR  PRI
  DCHL 79
  OTBF 32
  PARM RS422  DTE
  DRAT 64KC
  CLOK EXT
  IFC  ISGF
    PINX_CUST 0
    ISDN_MCNT 300
  CLID OPT0
  CO_TYPE  STD
  SIDE USR
  CNEG 1
  RLS  ID  **
  RCAP COLP NDI CCBI PRI DV3I CTI  QMWI
  PR_TRIGS DIV 2 3
           CNG 2 3
  PR_RTN NO
  MBGA NO
  OVLR NO
  OVLS NO
  T310 120
  T200 3
  T203 10
  N200 3
  N201 260
  K    7
REQ  ****
OVL000
OVL000
OVL000
OVL000
Thank you all for suggestions etc.
I finally got this to work.
Using ISDN switch type 5 ESS and Network on the Cisco side, and USER on the Nortel side.
Glad to hear that
