Help | Router 2800 IOS 15.1 SIP configuration | Problem no sip type ex
Help | Router 2800 IOS 15.1 SIP configuration | Problem no sip type exists only 7960
and can't register dn and firemware sip can't register
in ip phones
help me urgently
configuration
p dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool phone
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
option 150 ip 192.168.1.1
no ip domain lookup
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
ras retry all 1
sip
registrar server expires max 600 min 60
g729 annexb-all
encap clear-channel standard
voice class codec 100
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
codec preference 4 g711alaw
codec preference 5 clear-channel
voice class h323 1
call start slow
voice register global
mode cme
source-address 192.168.1.1 port 5060
max-dn 10
max-pool 10
load 7960-7940 P0S3-8-12-00.loads
authenticate register
tftp-path flash:
file text
create profile sync 0002131541424346
voice register dn 1
number 1004
name phone1
voice register dn 2
number 1005
name phone1
voice register pool 1
busy-trigger-per-button 1
id mac 18EF.639F.5207
session-transport tcp
type 7960
number 1 dn 1
voice-class codec 100
voice register pool 2
id mac 18EF.639F.5183
type 7960
number 1 dn 2
voice register pool 3
voice-card 0
license udi pid CISCO2811 sn FCZ100671TR
archive
log config
hidekeys
interface FastEthernet0/0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
no ip http server
tftp-server flash:P0S3-8-12-00.loads alias P0S3-8-12-00.loads
tftp-server flash:P0S3-8-12-00.sb2 alias P0S3-8-12-00.sb2
tftp-server flash:P003-8-12-00.bin alias P003-8-12-00.bin
tftp-server flash:P003-8-12-00.sbn alias P003-8-12-00.sbn
tftp-server flash:OS79XX.TXT alias OS79XX.TXT
tftp-server flash:SEP18EF639F5207.txt.xml
control-plane
6 Replies 6
Can you please share a little bit of more specific information on what it is that you’re wanting to achieve and what you’re actually problem is?
Response Signature
Is there a way to add type of sip phones knowing that they are not exite in router 2800
type ? There are no types of phones 3905 , 8841...
Is there a way to add them? Thank you
If you don't want to ask how can I do sip configuration with 7960
I've tried a lot but it doesn't work
Not in any other way than to update the version of IOS as CME is a part of that. I doubt that there are version(s) available on this old platform for these new models of phones.
A 7960 is natively a SCCP based phone, so it would likely be a little easier to set it up as such instead of using SIP. For this there are very good documentation available on cisco.com.
Response Signature
mais pour moi je vous configurer les téléphone sip 3905 et autre gamme sur un routeur cisco 2800
IOS disponible que je trouve de routeur est la version 15.1
c2800nm-ipvoicek9-mz.151-3.T.bin
- est-qu'ilya un possibilite de configurer les telephones sip sur ce
routeur 2800
- comment ajouter les types des telephones 3905 et 8841 sur
le pool puisque n'existe pas
merci d'avance
but for me I configure the sip 3905 and other range phones on a cisco 2800 router
Available IOS I find of router is version 15.1
- is there a possibility to configure sip phones on this
router 2800
- how to add the types of telephones 3905 and 8841 on
the pool since does not exist
thank you in advance
I have already answered your question. Any available phone models depends on the version of CME that you have and that in turn depends upon the version of IOS you have. As your router model is end of everything there is an endpoint of what models of phones that you can configure. If it’s not selectively in the configuration you cannot configure it.
Response Signature
