Help to configure external DHCP for VoIP phones
max_gbp777
I am having difficulty getting the VoIP phones to DHCP through an external DHCP server. The initial/ current design was installed just to get the phones working. The current setup is working but the design does not conform to our security standards. I need help to configure the phones to DHCP from the external DHCP server.
(Our VoIP service supplier will not allow the use of the internal DHCP servers.)
We attempted the target setup but could not get the phones to DHCP. It does not look as if the phones DHCP requests are making it to the firewall. We did see SCCP traffic from the phones through the firewall logs.
Any assistance appreciated.
Thank you,
Max
Target Setup:
PC >> VoIP Phone >> 3750 switch >> Distrib Switch >> Server Farm Switch >> Firewall >> External VoIP DHCP server
We had a limited maintenance window so had revert changes in the end.
Access Switch Cisco 3750 Switchport configuration
interface FastEthernet1/0/1
switchport access vlan 10
switchport mode access
switchport voice vlan 20
no logging event link-status
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
priority-queue out
no snmp trap link-status
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input Priority_Data
Configuration on Distribution switch for Data VLAN
interface Vlan10
           description Department_Data
           ip address 10.1.10.3 255.255.255.0
ip helper-address 10.1.4.17
           ip helper-address 10.1.4.19
           no ip redirects
           standby 10 ip 10.1.10.1
           standby 10 preempt
Configuration on Distribution switch for VoIP VLAN
interface Vlan20
           description Department_VoIP
           ip address 10.1.20.3 255.255.255.0
ip helper-address 10.118.118.212
            no ip redirects
           standby 10 ip 10.1.20.1
           standby 10 preempt
Initial/ Current Setup (This setup is currently working):
PC >> VoIP Phone >> 3750 switch >> Distrib Switch >> Server Farm Switch >> External VoIP DHCP server
PC connects through VoIP phone, into switch (dual VLAN), server
VLAN 10 = PC VLAN (DHCP Server on LAN)
VLAN 20 = Phone VLAN (external DHCP Server ISP CPE router)
priority-queue out
interface Vlan10
           no ip redirects
           standby 10 preempt
No interface configuration on Distribution switch for Voice VLAN only named
            vlan 20
           name vlan_20_Voice
Configuration on Server Farm Switch:
vlan 20
           name vlan_20_Voice
interface GigabitEthernet1/47
description Trunk to Voice Gateway
no ip address
speed 100
duplex full
wrr-queue cos-map 1 1 1
wrr-queue cos-map 2 1 0
wrr-queue cos-map 3 1 4
wrr-queue cos-map 3 2 2
wrr-queue cos-map 3 3 3
wrr-queue cos-map 3 4 6
wrr-queue cos-map 3 5 7
switchport
switchport access vlan 20
switchport trunk allowed vlan 20
end
Thank you,
Max
Message was edited by: max_gbp777
ADAM CRISP
Level 4
Level 4
Hello.
I'm assuming you have Cisco phones - which means that the "switchport voice vlan 20" command configured CDP to tell the phone to tag frames in VLAN20. If this isn't the case, and you have for example Avaya phones, then you'll need to check out how to configure your Data DHCP server to tell the Avaya's to use VLAN 20 etc.
Your current setup is working, because the Vlan 20 DHCP packets get sent out of your Server farm switch, and make it to the external voip dhcp server.
When you convert to the firewall model, you're going to need to get your own infrastructre to proxy the DHCP messages and also to look at the connection through the firewall.
eg
This means setting up the ip helper address and not forgetting the ip forward udp bootpc/ps protocol command on a switch in vlan 20
so your Distribution switch needs to have:
int vlan 20
Please can you fix the Standby group for vlan 20. Using the same group name as vlan 10 is confusing.
You then need to set up the link via the firewall, This link probably isn't in Vlan 20 however you haven't posted your target switchport configuration for this one.
thanks
Adam
Hi Adam,
Thanks for the reply.
The phones are Cisco 7911Gs.
The ip helper address is configured on the VLAN 20 interface for the target solution.
I have not configured the: ip forward udp bootpc command on any of the switches though. How will this affect DHCP rquestes from data VLANs DHCPing to the internal DHCP server, etc.?
The firewall has been configured to relay DHCP requests. Having checked the firewall logs, it seems that the DHCP requests are not making it to the firewall....? We had some initial DHCP requests for the first few minutes, then none, even though I unplugged a few phones.
We did have SCCP and TFTP traffic traversing the firewall, but no reply traffic. I will ask the ISP to check the routing for the VoIP interface.
I think I need to run a sniffer to get more detail on what is actually happening. (need to check availability with the ISP for testing dates)
Any further input would gladly be received.
Thanks again for your help so far, much appreciated.
Kind Regards
Max
The IP helper command and the ip forward protocol are used together. - so you need to add in the forward-protocol part. (or at least I always have done) Having said that the command reference http://www.cisco.com/en/US/docs/ios/12_1/iproute/command/reference/1rdipadr.html#wp1018318 appears to say that some protocols are forwarded by default. I would check this with your sniffer
Once you've done this you hopefully will see the DHCP requests come from your switch to the external dhcp via your firewall.
Adam
