05-02-2016 08:56 AM - edited 03-17-2019 06:47 AM
Hi everybody,
I'm working on a CISCO 2821 voice gateway, the IOS version is 15.1(4)M5, RELEASE SOFTWARE (fc1).
The problem is that the command "show processes cpu" shows huge percentage (93%)
sintcvo01#sh proc cpu sorted | ex 0.0
CPU utilization for five seconds: 92%/9%; one minute: 93%; five minutes: 93%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
329 15490864 2496660 6204 32.58% 32.30% 32.31% 0 SNMP Traps
304 6171264 4830675 1277 12.64% 12.60% 12.62% 0 VTSP
292 5303860 1610546 3293 10.40% 10.36% 10.38% 0 ISDN
12 2640560 2713232 973 9.52% 9.44% 9.45% 0 AFW_application_
324 48127856 71585907 672 5.20% 5.17% 5.21% 0 IP SNMP
331 1187324 8532529 139 2.56% 2.62% 2.63% 0 ISDN L2 Process
326 23503104 35221937 667 2.32% 2.38% 2.33% 0 SNMP ENGINE
301 495492 564098 878 1.12% 1.11% 1.11% 0 CC-API_VCM
124 11899152 44269538 268 1.12% 1.17% 1.19% 0 IP Input
308 803896 1911925 420 0.71% 0.68% 0.69% 0 TSP
325 5118424 35204600 145 0.47% 0.46% 0.47% 0 PDU DISPATCHER
197 456 210 2171 0.47% 0.42% 0.11% 514 SSH Process
322 300732 234874 1280 0.39% 0.34% 0.34% 0 voice file acct
100 234284 295556637 0 0.39% 0.46% 0.47% 0 Ethernet Msec Ti
53 143916 1364510 105 0.23% 0.22% 0.23% 0 IF-MGR control p
Can you, guys, give me some tips to treat this issue?
thanks guys in advance.
05-02-2016 10:03 AM
Hi Amin,
Try disbaling SNMP logging/trap ,as you can see SNMP is taking a toll on CPU.
You can probably try a reboot after that,should fix it.thanks
05-08-2016 03:04 PM
Hi Deepak,
thank you for your feedback.
how do you disable SNMP process on the router?
05-08-2016 04:06 PM
You can try below.
no
05-09-2016 07:55 AM
Indeed, I the thing now is that a big portion of the CPU resources is taken by hidden processes.
how to gain back this big portion of CPU?
Thanks in advance, Deepak.
05-09-2016 09:18 AM
You can raise a TAC case for CPU profiling of your router which can give you exact details around the CPU processes cuasing this.
Refer to below doc.
https://supportforums.cisco.com/document/61366/troubleshooting-high-cpu-snmp-engine-process-ios
http://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/15095-highcpu.html
