Bookmark
Subscribe
2412
High CPU usage on a voice gateway
amine..dahel
Hi everybody,
I'm working on a CISCO 2821 voice gateway, the IOS version is 15.1(4)M5, RELEASE SOFTWARE (fc1).
The problem is that the command "show processes cpu" shows huge percentage (93%)
 sintcvo01#sh proc cpu sorted | ex 0.0
CPU utilization for five seconds: 92%/9%; one minute: 93%; five minutes: 93%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
 329    15490864     2496660       6204 32.58% 32.30% 32.31%   0 SNMP Traps
 304     6171264     4830675       1277 12.64% 12.60% 12.62%   0 VTSP
 292     5303860     1610546       3293 10.40% 10.36% 10.38%   0 ISDN
  12     2640560     2713232        973  9.52%  9.44%  9.45%   0 AFW_application_
 324    48127856    71585907        672  5.20%  5.17%  5.21%   0 IP SNMP
 331     1187324     8532529        139  2.56%  2.62%  2.63%   0 ISDN L2 Process
 326    23503104    35221937        667  2.32%  2.38%  2.33%   0 SNMP ENGINE
 301      495492      564098        878  1.12%  1.11%  1.11%   0 CC-API_VCM
 124    11899152    44269538        268  1.12%  1.17%  1.19%   0 IP Input
 308      803896     1911925        420  0.71%  0.68%  0.69%   0 TSP
 325     5118424    35204600        145  0.47%  0.46%  0.47%   0 PDU DISPATCHER
 197         456         210       2171  0.47%  0.42%  0.11% 514 SSH Process
 322      300732      234874       1280  0.39%  0.34%  0.34%   0 voice file acct
 100      234284   295556637          0  0.39%  0.46%  0.47%   0 Ethernet Msec Ti
  53      143916     1364510        105  0.23%  0.22%  0.23%   0 IF-MGR control p
Can you, guys, give me some tips to treat this issue?
thanks guys in advance.
5 Replies 5
Deepak Mehta
Hi Amin,
Try disbaling SNMP logging/trap  ,as you can see SNMP is taking a toll on CPU.
You can probably try a reboot after that,should fix it.thanks
Hi Deepak,
thank you for your feedback.
how do you disable SNMP process on the router?
You can try below.
no snmp-server enable traps or no snmp-server host.
Indeed, I the thing now is that a big portion of the CPU resources is taken by hidden processes.
how to gain back this big portion of CPU?
Thanks in advance, Deepak.
You can  raise a TAC case for CPU profiling of your router which can give you exact details around the CPU processes cuasing this.
Refer to below doc.
 https://supportforums.cisco.com/document/61366/troubleshooting-high-cpu-snmp-engine-process-ios
http://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/15095-highcpu.html
