HLOG
bowmail
HI
I have 10 users with only CUCI Lync. can a cuci-lync user log in and out of huntgroups like using a HLOG softkey?
either from ccmuser, callmanager or other?
thanks
Chris Deren
Unfortunately no, this is only a phone feature. The CUCM System Guide lists what devices are supported, check it out for your CUCM version.
HTH,
Chris
Thanks chris.
To one further question - if we are using extension mobility and log into a phone then logout out of the hunt group does that setting stay with the user if they log into another phone? or will they be automatically logged back into the huntgroup when the logout of EM.
Well, you wll first need to see if you can assign EM DN to a hunt group, if you can then you should be technically able to logout while using EM.  If a phone has HLOG on, and then you login with EM that has different extension, the phone will no longer ring as that DN is not available, as soon as you logout with EM the phone should be able to ring.
HTH,
Chris
