Hold Music
eberrocal2
I thought this would be an easy thing but it's not working.  I need to have hold music play when an extension puts someone on hold.  I made the selection in Call Manager (User Hold MOH Audio Source and Network Hold MOH Audio Source) however it's not working, nothing is played.  Where do I make this change?  What do I need to check?  Thank you!
eberrocal2
I figured out what the issue was.  The file I was selecting for User Hold MOH Audio Source was corrupt or missing.  I selected a different file and it works now.
Nithin, thanks for the document.  I'm going to review it.  There's always more to learn!
VON CLAWSON
Level 3
Level 3
I see you got it working. But, just wanted to add to this. If you are adding an moh file you must add it to all servers. If you select a file and that file is not on the server that the phone is registered to, you will get an error.
Please rate if this helps.
