Hotline configuration with IP Phone on CME
nguyendd
Hi all,
I would like to configure hotline feature between two IP phones on CME. When I go off-hook one phone, the other will ring, user just pick up and answer the call. My company use SIP and SCCP also, so please advice me the command to archive this feature.
Thank you very much
Hi.
Do what follows
ephone-dn 1 <-- this is the line where the call starts from
number 1000
intercom 2000 barge-in
ephone 1
button 1:1
autoline 1
In this case phone with extension 1000 will go off hook and dial 2000 immediately
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.
Do what follows
number 1000
ephone 1
button 1:1
autoline 1
Carlo
Hi Carlo,
Thanks for your reply, how about SIP configuration? Cause, my company use both SIP and SCCP.
Thank you
daniel.tang1
I have same problem. can you share me how to configure the SIP phone?
Best Regards,
