How can a wav file convert to g729 without using regular conversion tools?
AfsarAlunkal
Please help
paolo bevilacqua
How?
Hardly.
William Bell
Afsar,
If you want to take audio file format and convert it to another, then you will need a conversion tool of some type. I guess I don't know what you consider "regular". There is an online conversion tool here:
http://www.asteriskguru.com/tools/audio_conversion.php
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Bill,
Thank you.
I tried to convert some wav files to g729 with conversion tools but it didnt play on cisco3700.can u suggest some tools that might work..
Afsar
