03-04-2011
08:01 AM
- last edited on
03-25-2019
08:05 PM
by
ciscomoderator
I've seen a very old post about this topic but without reply .I've configured a Blackberry MVS server connected to a CUCM 8.5.1 and using Unity Connection 8.5.1 as voicemail .When i'm calling from my Mobile Blackberry the Unity connection voicemail the beginning of welcome prompt is missing perhaps 3s are missing.
I think it's due to call flow establishment . I 've had this issue with an other voiceMail system on which we can configure a timer in order to introduce a delay before the beginning of the prompt .
Also i'm looking for the same timer on Unity Connection (nothing in cisco doc) ?
Solved! Go to Solution.
03-04-2011 09:34 AM
Delay After Answer ____ Milliseconds | Enter the wait time, in milliseconds, after a call is connected to Cisco Unity Connection and before Connection plays a greeting. Default setting: 0 milliseconds. |
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
03-04-2011 09:34 AM
java
03-06-2011 11:56 PM
Thanks a lot ,i'll test it.
Brgds
